A home NVR can associate the same person or other supported object across different cameras by linking local tracks with appearance embeddings and spatiotemporal evidence.
The output should be treated as a global track hypothesis, not as proof of real-world identity. A driveway camera, doorbell, and indoor camera see different angles, lighting, resolution, and occlusion, so the system must decide whether two separated tracklets are similar enough and physically plausible enough to belong together.
Cross-Camera Re-ID Begins After Detection and Local Tracking
Object detection answers what is visible in one frame, while single-camera tracking links detections across nearby frames. Cross-camera re-identification begins when a track disappears from one view and a candidate appears elsewhere, where the original local track ID is no longer sufficient.
MICRO-TRACK, an open-set multi-camera system, describes a pipeline where local tracking creates short-lived identities and a re-identification stage links people across cameras under real-world constraints. Its open-set Re-ID pipeline is useful for a home NVR because residential cameras are also open-set: the system cannot assume every future visitor already exists in a closed gallery.
The related ZimaSpace analysis of false cross-camera matches covers the visible failure symptom. The architecture here explains why it happens: detection confidence, local track quality, embedding similarity, and transition logic all contribute separate uncertainty.
Appearance Embeddings Provide Similarity, Not Identity Proof
A re-identification model converts a crop into a feature vector intended to remain similar for the same target across views and different for different targets. Clothing, body shape, color, texture, and other learned cues can help, but viewpoint, lighting, blur, pose, partial occlusion, and similar-looking people distort that representation.
A 2026 person-ReID study on viewpoint and occlusion limits treats viewpoint and occlusion as core re-identification challenges and explores body-part-aware features to preserve discriminative information. For a home NVR, that means one similarity threshold should not be assumed to work equally well from porch daylight to garage infrared.
Re-ID also does not automatically generalize from people to cars, pets, or packages. Those categories need representations and evaluation appropriate to the object class. A person embedding producing a confident-looking score for a dog is not a valid identity mechanism.
Time and Camera Topology Remove Visually Plausible but Impossible Matches
Appearance alone can connect the wrong tracks when two people wear similar clothes. Camera topology adds a second question: could this target physically travel from camera A to camera B in the observed interval? Entry direction, exit direction, likely paths, and travel-time windows can reject visually similar but impossible candidates.
Research on spatiotemporal ID reassignment combines cross-camera appearance matching with spatial-temporal consistency to improve global identity assignment. The mechanism is especially relevant in a home because the camera graph is small and often predictable: driveway โ porch โ hallway is more plausible than backyard โ upstairs in two seconds.
Topology can still be wrong when doors change state, cameras have blind zones, timestamps drift, or a person takes an unexpected path. Treat it as evidence that modifies an appearance score, not as a hard rule unless the physical transition really is impossible.
Reliability Is Camera-Pair Specific and Must Be Measured That Way
A single โRe-ID accuracyโ number hides the weakest transition. Porch-to-driveway may work in daylight while driveway-to-garage fails at night. Build a labeled sample for each important camera pair, including similar clothing, partial views, multiple people, IR mode, rain, and deliberate exit/re-entry.
A 2026 technical briefing on cross-camera evaluation metrics distinguishes recognition measures such as rank and mAP from tracking measures such as HOTA and ID-related errors. That distinction matters at home: a good embedding match does not guarantee a stable end-to-end track if local tracking switches identities before the handoff.
Use cross-camera Re-ID for search, continuity, and probabilistic association when each critical camera transition passes a labeled test. Keep a human-verifiable path for security-sensitive conclusions, and do not let a global track label become automatic evidence that a specific known person performed an action.
