Stale Plex entries after a path change usually mean the server state and the new filesystem location have not been reconciled in the right order.
Did you move media to a new disk or mount and now Plex shows missing, duplicate, or outdated items? First prove the new path is visible to the Plex process, then update the library folder mapping and run a controlled scan. Avoid refreshing all metadata or rebuilding the library until filesystem access and the scan result are known.
Verify the New Path Before Touching Plex Metadata
The highest-probability cause is that Plex still points at the old folder, the new mount is not present inside the container, or permissions prevent the server from reading the replacement path.
A controlled library-path move can preserve item state when the new location is added and verified before the old path is removed; that is the baseline to establish for a Plex storage-path change.
If the Plex process cannot list a representative file at the new location, no amount of scanning or metadata refresh will make the library stable. Fix the host mount or permissions first.
Update the Library Folder and Scan for File Changes
Add or replace the library folder with the new storage path while keeping the old path available until the new one is confirmed. Then run Scan Library Files so Plex can reconcile additions, removals, and changed locations.
When measuring a Plex storage-path change, a media-server layout can keep write-heavy application state local while using network storage for bulk media, reducing latency and mount-risk exposure for app data.
Use Refresh Metadata only when descriptive metadata itself is wrong. Scanning answers “what files exist,” while refreshing answers “what metadata should those items have,” so using both blindly can create unnecessary work.
Clean Up Only After the New Path Is Stable
Once the scan is complete and playback from the new path works, remove the obsolete library folder reference. If stale entries remain, emptying trash or cleaning bundles may be appropriate only after you are sure the server is no longer temporarily missing the old storage.
Do not empty trash while the new mount is unreliable. A transient missing mount can make valid media look deleted, turning a path problem into unnecessary library churn.
Restart Plex or the container and confirm the new path remains mounted, the same items play, and a scan does not recreate duplicates. That restart is the persistence test for the fix.
Stop Before a Rebuild Unless State Is Truly Unrecoverable
A library rebuild should be the last resort because it can discard useful matching, watch, or organizational state. Most path changes can be resolved by restoring visibility and reconciling the library in place.
A repeatable two-bay versus four-bay NAS plan gives the benchmark a stable reference for storage paths, playback mode, and network assumptions.
Escalate to database or library repair only if the new path is readable, the folder mapping is correct, repeated scans cannot converge, and logs show a persistent server-state problem rather than a storage issue.
- Confirm the new path is readable by the Plex process
- Update the library folder before removing the old mapping
- Run Scan Library Files and let it finish
- Restart and confirm the new path persists
