A NAS running 24/7 is usually less expensive than people expect, but the bill depends on the average power draw, not the number printed on the power adapter. A small backup NAS may average around 15–25 watts, while a 4-bay, AI NAS, homelab, or older DIY server can sit much higher if drives, Docker apps, indexing, 10GbE, or local AI workloads keep it busy.
The useful question is not “How many watts does a NAS use?” but “What keeps my NAS awake all day?” Drive count, hard drive type, backup schedules, media indexing, virtual machines, local AI tools, and your local electricity rate decide whether 24/7 operation feels like a small utility cost or a real operating expense.
The Monthly Bill Is Usually Smaller Than the Anxiety
For many home users, a NAS running all day costs less than a streaming subscription. The math is simple: convert watts to kilowatts, multiply by hours, then multiply by your local electricity rate. The basic relationship is kW multiplied by hours equals kWh.
A 30W NAS running all day uses about 0.72 kWh per day, 21.6 kWh per month, or 262.8 kWh per year. At $0.20/kWh, that is about $4.32 per month or $52.56 per year. Use your own local rate, because electricity prices vary by region and customer type; the U.S. Energy Information Administration publishes electricity price by end-use sector for reference.
| Average Power | Monthly Energy | Yearly Energy | At $0.20/kWh |
| 15W | 10.8 kWh | 131.4 kWh | $26.28/year |
| 25W | 18 kWh | 219 kWh | $43.80/year |
| 40W | 28.8 kWh | 350.4 kWh | $70.08/year |
| 60W | 43.2 kWh | 525.6 kWh | $105.12/year |
This table is not a promise. It is a calculator shortcut. A quiet 2-bay backup NAS may live near the lower rows. A 4-bay media server, AI NAS, or homelab box with active services may spend more time in the middle or upper rows.
NAS Power Use Is Not One Number
A NAS has different power states. Idle power, active file-transfer power, drive standby, full-load CPU power, and startup current are not the same thing. Product pages often show a best-case low-power state, but your real bill comes from the average over days and weeks.
That average depends on what the NAS does while nobody is watching. Photo indexing, backup jobs, Time Machine, cloud sync, Docker logs, Plex or Jellyfin scans, surveillance writes, RAG indexing, and local AI services can keep the system from reaching deep idle.
A modern low-power CPU helps, but it is only one part of the system. Intel lists the Intel Processor N150 official specifications with a 6W processor base power. That is useful for efficient personal servers, but the final NAS draw still includes drives, memory, fans, network controllers, USB devices, and workload.
Drives Change the Bill More Than Many People Expect
Hard drives are often the biggest long-term variable. A NAS enclosure may be efficient, but each 3.5-inch HDD adds idle power, active read/write power, heat, vibration, and startup demand. A 4-drive NAS is not just a larger box; it is four spinning devices running for 8,760 hours a year.
Seagate’s Seagate IronWolf NAS drive power data shows why this matters: large NAS HDDs have separate operating, idle, standby, and sleep figures. Multiply that by two, four, six, or more drives, and the drive plan becomes a power plan.
| Drive Setup | Power Meaning | Practical Takeaway |
| 1–2 drives | Lowest baseline | Best for photos, files, backup, and simple private cloud |
| 4 drives | More idle draw and more heat | Better for media libraries, family storage, and RAID flexibility |
| 6+ drives | Higher always-on cost | Only makes sense when capacity or workflow needs it |
| Fewer larger drives | Often simpler and quieter | Can reduce drive count, noise, heat, and idle power |
If your NAS is mainly for backup and family photos, two larger drives may be more practical than many smaller drives. If your workflow needs capacity, redundancy, and parallel access, the extra draw may be justified.
The Real Cost Formula Is Simple
Do not calculate cost from the power adapter rating. A 60W or 90W adapter does not mean the NAS uses 60W or 90W all day. You need the average wall power during your actual workload.
Daily kWh = average watts × 24 / 1000
Monthly kWh = average watts × 24 × 30 / 1000
Yearly kWh = average watts × 24 × 365 / 1000
Yearly cost = yearly kWh × local electricity rate
For example, a NAS averaging 35W uses about 25.2 kWh per month. At $0.20/kWh, that is about $5.04 per month. At $0.35/kWh, the same NAS costs about $8.82 per month. The NAS did not change; the electricity rate did.
The best way to know your number is to measure it. Use a smart plug or wall power meter for at least 48–72 hours. Include a normal backup day, a quiet day, and a heavy-use day if your NAS runs media scans, Docker tasks, or AI indexing.
HDD Hibernation Sounds Better Than It Often Feels
Drive hibernation can save power, but only when the NAS can actually stay asleep. A cold backup box that wakes once a night may benefit. A NAS running media services, Docker containers, cloud sync, monitoring, or frequent backups may wake the drives so often that hibernation becomes less useful than expected.
There is also a comfort tradeoff. A sleeping drive may add delay when you open files, browse photos, stream media, or trigger a backup. If a service wakes the drive every few minutes, you may get neither deep savings nor smooth access.
If your NAS is a cold backup target, hibernation makes sense. If it is your media server, Docker host, private cloud, and AI workspace, stable low idle may matter more than chasing the lowest sleep number.
A 2-Bay NAS, 4-Bay NAS, and AI NAS Do Not Belong in the Same Cost Box
A lightweight 2-bay NAS and an AI NAS are both “NAS” devices, but they do not have the same power profile. The first is mainly storage. The second may also be a server, app host, model workspace, and local automation hub.
| NAS Type | Power Expectation | Best Fit |
| 2-bay home NAS | Low baseline | Photos, files, backup, light private cloud |
| 4-bay NAS | Medium baseline | Media library, family storage, Docker, long-term expansion |
| AI NAS / homelab NAS | Higher but workload-driven | Local AI, RAG, VM, 10GbE, team workspace |
| NAS plus network gear | Add router, switch, AP, or 10GbE power | Remote access and always-on services |
For a compact always-on home server, ZimaBoard 2 personal server fits lightweight backup, Docker, private cloud, and always-on service use. For larger local storage, AI workflows, RAG, Open WebUI, Ollama, and team files, ZimaCube 2 AI NAS is closer to a private infrastructure box than a simple storage appliance.
Power Saving Should Not Break the Reason You Bought a NAS
The wrong kind of power saving can make a NAS worse. If you bought the NAS for automatic backup, do not disable backup to save a few watts. If you rely on remote file access, do not schedule shutdowns that make the system unavailable when you need it. If Docker services are the point, do not chase sleep states that constantly interrupt them.
The better approach is to remove waste without breaking the workflow. Turn off services you do not use. Schedule heavy indexing, backup, scrub, and AI jobs for fixed windows. Avoid unnecessary USB devices, expansion cards, and always-on 10GbE if your network does not need them. Keep airflow clean so fans do not ramp up because of dust and heat.
Measure first, then optimize. Guessing from specs often leads to the wrong target. A single unused container, a busy sync task, or too many spinning drives can matter more than a small CPU difference.
When Higher Power Use Is Worth It
Not every extra watt is waste. More power can be worth it when the NAS replaces other systems or saves real time. A media server that transcodes smoothly, a local AI workspace that keeps documents private, or a 10GbE storage system that speeds up creative work can justify a higher baseline.
Higher power is easier to accept when it buys a specific workflow: Plex or Jellyfin transcoding, local AI with Ollama, RAG indexing, Docker apps, VM labs, project backups, fast file sharing, or team storage. It is harder to justify when the system sits mostly unused with too many drives and services running.
A NAS that uses more power but replaces a desktop running all day, several cloud tools, or repeated manual file movement may still be the better system. The key is to compare the full workflow, not only the wall-watt number.
How to Lower 24/7 NAS Power Without Guessing
Start with the biggest levers. Count drives before counting apps. Use fewer drives when capacity allows. Choose efficient drives for always-on storage. Turn off unused containers and background services. Schedule indexing and backup instead of letting them run randomly all day.
Then check the supporting hardware. Router, switch, access point, external USB drive, 10GbE adapter, and expansion enclosure may add to the same 24/7 footprint. If your NAS stays on to provide remote access, the network path may also need to stay on.
| Optimization | Why It Helps | Watch-Out |
| Use fewer larger drives | Reduces spinning devices | Keep redundancy and backup needs in mind |
| Schedule heavy jobs | Avoids constant background wake-ups | Do not overlap backup, scrub, and AI indexing |
| Disable unused services | Improves idle behavior | Check Docker, sync, media, and monitoring tools |
| Measure with a smart plug | Shows real average power | Measure normal days, not only idle time |
| Use hibernation selectively | Can reduce drive power | Active services may wake drives repeatedly |
Do not sacrifice backup for lower power. Saving a few dollars a year is not worth losing family photos, business files, project archives, or private AI data.
Final Takeaway
A 24/7 NAS is usually a small bill, but it is not a fixed bill. The real cost depends on average power, drive count, drive type, workload, sleep behavior, network gear, AI or VM use, and local electricity pricing.
For basic backup and file storage, the cost is often modest. For a 4-bay media server, AI NAS, or homelab system, power use becomes part of the operating plan. That does not make 24/7 NAS use a bad idea; it means the system should be sized for the job.
The better question is not “Is a NAS cheap to run?” The better question is “What private storage, backup, self-hosting, and AI workflows do I get for that always-on power?” If the NAS protects your data, removes manual work, keeps services online, or gives your AI workspace a private home, the electricity cost may be one of the smaller parts of the value.
How much electricity does a NAS use per month?
Use this formula: average watts × 24 × 30 / 1000. A 15W NAS uses about 10.8 kWh per month. A 40W NAS uses about 28.8 kWh per month. Multiply that by your local electricity rate.
Is it expensive to run a NAS 24/7?
For many home NAS setups, no. A lightweight NAS may cost only a few dollars per month. Larger 4-bay, 6-bay, AI NAS, 10GbE, VM, or Docker-heavy systems cost more because their average power draw is higher.
Should I turn off my NAS at night?
If the NAS is only used for occasional cold backup, scheduled shutdown can make sense. If it handles backups, remote access, Docker, media services, security cameras, or AI workflows, leaving it on is usually more practical.
Does HDD hibernation save much power?
It can, especially for cold backup NAS setups. It is less effective when services constantly wake the drives. For active home servers, stable low idle may be better than frequent sleep and wake cycles.
Does an AI NAS use more power than a normal NAS?
Usually yes, because it may run local models, RAG indexing, Open WebUI, Ollama, Docker, VM, and faster networking. That higher power use can still be worthwhile if it replaces cloud tools, desktop uptime, or manual workflows.
Open WebUI Tether: Connect Your Desktop to a Home AI Server Safely
Connect desktop models, files, and tools to Open WebUI with practical permission boundaries, sandbox checks, and troubleshooting.
