UPS Buying Checklist for a NAS and Network Stack
A UPS for a NAS should keep the storage path and the network control path alive long enough to ride through a short outage or shut down cleanly. Buy from measured watts, required runtime, signaling support, and battery serviceability rather than the largest VA number within budget.
Measure the Stack Under Its Worst Normal Load
Measure the NAS during disk activity plus the modem or optical terminal, router, switches, access points, and any controller required for graceful shutdown. Include PoE load if the switch powers cameras or access points.
Pass when the UPS continuous watt rating has comfortable headroom above measured peak and the expected load stays within the manufacturer’s runtime chart. Fail when sizing uses power-supply labels or VA alone instead of real draw.
An undersized UPS may overload exactly when disks are busy. An oversized unit is not automatically better if its idle efficiency, battery cost, or replacement availability is poor.
Choose Runtime From an Action Window
Use a vendor runtime tool, such as the UPS sizing and runtime selector, as an estimate and verify against the exact model’s load curve. Decide whether the goal is five minutes for shutdown, twenty minutes for common outages, or longer continuity for internet service.
Pass when the battery at expected age can cover detection delay, application stop time, storage shutdown, and a margin. Fail when the advertised runtime applies only to a much smaller load.
Long runtime may be better purchased through an external-battery model or a different power strategy. Do not put high-draw printers, heaters, or unnecessary displays on the protected outlets.
Verify Shutdown Signaling and Multi-Device Control
Confirm the NAS supports the UPS over USB, SNMP, or a network UPS service. If several hosts depend on one unit, define which device owns the signal and how the others receive a shutdown event.
Pass when the NAS can detect on-battery state, low battery, communication loss, and power restoration without a cloud service. Fail when the only integration is a desktop utility unavailable for the server OS.
Coordinate shutdown with the server’s roles described in this home-server OS guide. Databases and containers need time to stop before storage powers down.
Check Battery, Surge, and Outlet Design
Prefer a replaceable battery with a documented part number, local availability, clear test procedure, and realistic replacement cost. Check topology—standby, line-interactive, or online—against local power quality and equipment needs.
Pass when critical devices fit battery-backed outlets without unsafe adapters and network equipment remains powered until the NAS completes shutdown. Fail when a proprietary battery costs nearly as much as replacing the unit or cannot be sourced.
A UPS is not a whole-building surge or lightning solution. Use appropriate electrical protection and grounding, and keep data cables from creating an unprotected path where relevant.
Prove the Design With an Outage Test
After charging, start a representative workload and disconnect utility power at the UPS input using the manufacturer’s safe procedure. Verify alerts, network reachability, application stop order, NAS shutdown, and the state after power returns.
Pass when the sequence completes with reserve runtime and the server does not restart repeatedly during unstable power. Fail when any critical network device dies first, the USB signal drops, or shutdown exceeds the battery window.
Repeat the controlled test after battery replacement and periodically as the battery ages. Runtime is a condition to maintain, not a one-time specification.
Final Buying Rule
Buy the smallest serviceable UPS that supports the measured watt load, required aged-battery runtime, native shutdown path, and outlet topology with margin. Reject any model that cannot complete a tested shutdown while keeping the control network alive.
Should I size a UPS by VA or watts?
Check both, but measured watts and the UPS watt limit are essential. VA describes apparent power; the unit must remain within both ratings and meet runtime at the actual load.
Should the modem and router be on the UPS?
Usually yes if alerts, remote control, or coordinated shutdown depend on them. Include their power draw and any PoE devices in the runtime calculation.
Buying Guide
