Choose the lowest-power Plex hardware that passes your real peak playback and storage workload with enough headroom for 24/7 operation.
Start With the Minimum Playback Workload
Direct Play and server-side conversion have radically different compute requirements. A household that mostly Direct Plays should not be sized like one that remotely transcodes 4K media every evening.
Intel N100 hardware transcoding handled several simultaneous conversions without heavy CPU pressure in the tested setup.
List the number of simultaneous local and remote streams, then mark which ones are expected to Direct Play or transcode. If you cannot describe the peak playback mix, postpone the hardware decision rather than buying excess CPU as insurance.
Verify the Exact Hardware-Acceleration Path
A low-power CPU is attractive only if its iGPU or media block works with the codecs and operating system you plan to use. Architecture and model generation can change support.
AMD Plex acceleration tests varied across the tested Ryzen generations, so model-specific verification matters.
Check recent tests for the exact CPU generation, host OS, HDR tone-mapping requirement, and codec mix. If the purchase depends on unverified future driver support, treat that feature as unavailable. Your shortlist should match the stream, storage, and acceleration requirements of a Plex server rather than a generic low-power target.
Measure 24/7 Power at the System Level
Processor TDP is not annual wall power. Drives, fans, NICs, memory, idle states, and companion services determine the energy used by an always-on server.
measured 24/7 mini-PC power makes wall draw and duty cycle more useful than TDP for annual energy cost.
Compare measured idle and transcode power for complete systems, then add the expected drive and accessory load. When a cheaper old platform idles far above a newer option, include the multi-year power difference in value rather than purchase price alone.
Buy Expansion Only for a Known Constraint
Extra bays, RAM, NIC speed, and CPU headroom can be useful, but each adds cost or power. The best low-power system leaves enough room for the next credible workload without turning into an oversized general-purpose server.
reused homelab hardware is most valuable when it already meets a measured workload and upgrade trigger.
Write down the next likely storage, stream, or service increase and price only the capacity needed for that scenario. If the upgrade has no defined trigger in the next ownership cycle, keep the simpler lower-power configuration.
Buying Guide
