If you’re looking for an affordable and versatile single-board computer (SBC), two options you may consider are the Pine A64 and the ZimaBoard. Both of these SBCs offer a lot of features and functionality for their price, but they also have their differences.
In this article, we’ll take a closer look at the Pine A64 Board and ZimaBoard, and compare their technical specifications, performance, operating system support, price, use cases, pros and cons, user reviews and feedback, and frequently asked questions. By the end of this article, you should have a better idea of which board is right for you.
The Pine A64 Board is a low-cost SBC designed for developers, hobbyists, and DIY enthusiasts. It features a quad-core ARM Cortex-A53 CPU with 64-bit architecture, 2GB of RAM, Gigabit Ethernet, USB 2.0 and USB 3.0 ports, HDMI output, and support for up to 128GB of microSD storage. The Pine A64 Board also has a Mali-400 MP2 graphics processing unit (GPU) that supports 1080p video playback.
The ZimaBoard, on the other hand, is a newer SBC that offers more advanced features and performance. It features an Intel Celeron CPU with 64-bit architecture, up to 8GB of DDR4 RAM, Gigabit Ethernet, USB 2.0 and USB 3.0 ports, and support for up to 32GB of eMMC storage.
Part 1:Purpose of the comparison: Pine A64 Board vs ZimaBoard
The purpose of this article is to compare the Pine A64 Board and ZimaBoard in terms of their technical specifications, performance, operating system support, price, use cases, pros and cons, user reviews and feedback, and frequently asked questions. By doing so, we hope to help you make an informed decision about which SBC to choose for your next project.
Choosing the right SBC is important because it can affect the performance and functionality of your project. If you choose a board that is not powerful enough, you may not be able to run the software you need or perform the tasks you want. On the other hand, if you choose a board that is too expensive, you may be wasting money on features you don’t need. By comparing the Pine A64 Board and ZimaBoard, we hope to help you find the right balance between price and performance for your needs.
Part 2: Technical Specifications zPine A64 Board i ZimaBoard
Jeśli zastanawiasz się między płytą Pine A64 a ZimaBoard, jednym z najważniejszych czynników do rozważenia są ich specyfikacje techniczne. W tej sekcji przyjrzymy się bliżej komponentom sprzętowym każdej z płyt, w tym procesorom, pamięci RAM, łączności, pamięci masowej oraz możliwościom graficznym.
A. Pine A64 Board
Procesor
Płyta Pine A64 jest napędzana czterordzeniowym procesorem ARM Cortex-A53 o architekturze 64-bitowej, działającym z częstotliwością 1,2 GHz. Ten procesor zapewnia niezawodną wydajność do podstawowych zadań obliczeniowych i uruchamiania lekkiego oprogramowania. Jednak może mieć trudności z bardziej wymagającymi aplikacjami i wielozadaniowością.
Pine A64 Board ma 2GB pamięci DDR3 RAM, co jest wystarczające do większości podstawowych zadań obliczeniowych i lekkiej wielozadaniowości. Jednak jeśli planujesz uruchamiać bardziej wymagające aplikacje lub używać płyty jako centrum multimedialnego, możesz uznać, że pamięć RAM jest ograniczająca.
Łączność
Pine A64 Board wyposażony jest w Gigabit Ethernet, co zapewnia szybką i niezawodną łączność sieciową. Posiada także porty USB 2.0 i USB 3.0, oferując opcje podłączania peryferiów i urządzeń. Dodatkowo ma wyjście HDMI z obsługą do rozdzielczości 1080p, co czyni go odpowiednim wyborem do zastosowań multimedialnych.
Pamięć masowa
Pine A64 Board obsługuje do 128GB pamięci microSD, co zapewnia wystarczającą przestrzeń do podstawowego przechowywania plików i zastosowań multimedialnych. Jednak pamięć microSD może nie być odpowiednia do bardziej wymagających aplikacji lub dużych plików.
Grafika
Pine A64 Board posiada GPU Mali-400 MP2, który obsługuje odtwarzanie wideo do 1080p. Choć jest to wystarczające dla większości podstawowych zastosowań jako centrum multimedialne, może nie być wystarczająco mocne do bardziej wymagających aplikacji graficznych.
B. ZimaBoard
Procesor
ZimaBoard jest napędzany przez procesor Intel Celeron z architekturą 64-bitową, działający z prędkością do 700MHz. Ten procesor jest znacznie mocniejszy niż CPU Pine A64 Board, co czyni go odpowiednim wyborem do bardziej wymagających zadań obliczeniowych i wielozadaniowości.
ZimaBoard obsługuje do 8GB RAM, co jest znacznie więcej niż w Pine A64 Board. Ta dodatkowa pamięć RAM pozwala na bardziej wymagające zadania obliczeniowe i wielozadaniowość bez ryzyka spowolnienia lub awarii płyty.
Łączność
ZimaBoard wyposażony jest w Gigabit Ethernet oraz 2 porty USB 3.0. Te opcje łączności czynią go wszechstronną płytą do różnych zastosowań, w tym centrów multimedialnych, konsol do gier i systemów automatyki domowej.
Pamięć masowa
ZimaBoard obsługuje do 32GB pamięci eMMC, która jest szybsza i bardziej niezawodna niż pamięć microSD w Pine A64 Board. To sprawia, że jest to lepszy wybór do bardziej wymagających aplikacji i większych plików.
Grafika
ZimaBoard posiada procesor graficzny Intel Celeron, który jest znacznie mocniejszy niż GPU Pine A64 Board. Czyni to go odpowiednim wyborem do bardziej wymagających aplikacji graficznych, w tym gier i zastosowań multimedialnych.
Ogólnie rzecz biorąc, ZimaBoard oferuje mocniejsze komponenty sprzętowe niż Pine A64 Board. Podczas gdy Pine A64 Board jest odpowiedni do podstawowych zadań obliczeniowych i lekkich zastosowań jako centrum multimedialne, ZimaBoard lepiej sprawdzi się w bardziej wymagających aplikacjach i podczas wielozadaniowości.
Część 3: Porównanie wydajności zPine A64 Board i ZimaBoard
Wybierając między Pine A64 Board a ZimaBoard, ważne jest, aby wziąć pod uwagę ich możliwości wydajnościowe. W tej sekcji porównamy wydajność obu płyt pod kątem wyników testów benchmarkowych, rzeczywistej wydajności, zużycia energii oraz rozpraszania ciepła.
A. Wyniki testów benchmarkowych
Testy benchmarkowe są przydatnym narzędziem do porównywania wydajności różnych komponentów sprzętowych. W tej sekcji przyjrzymy się wynikom testów benchmarkowych dla Pine A64 i ZimaBoard.
Według testów benchmarkowych, ZimaBoard przewyższa Pine A64 pod względem mocy obliczeniowej, szybkości pamięci i wydajności graficznej. Wynika to z mocniejszych komponentów ZimaBoard, w tym ośmiordzeniowego procesora i GPU Mali-T860 MP4.
B. Wydajność w rzeczywistych zastosowaniach
Chociaż testy benchmarkowe mogą dostarczyć przydatnych informacji o wydajności sprzętu, nie zawsze odzwierciedlają rzeczywiste scenariusze użytkowania. W tej sekcji porównamy wydajność w rzeczywistych zastosowaniach Pine A64 i ZimaBoard.
ZimaBoard oferuje lepszą wydajność w rzeczywistych zastosowaniach niż Pine A64. Wynika to z mocniejszych komponentów sprzętowych, które pozwalają na obsługę bardziej wymagających aplikacji i wielozadaniowości bez problemów.
C. Zużycie energii
Zużycie energii jest ważnym czynnikiem przy wyborze płyty, zwłaszcza jeśli planujesz jej długotrwałe użytkowanie. W tej sekcji porównamy zużycie energii przez Pine A64 i ZimaBoard.
Płyta Pine A64 ma stosunkowo niskie zużycie energii, z typowym poborem mocy około 2-3 watów. Czyni to ją odpowiednim wyborem do zastosowań, gdzie efektywność energetyczna jest priorytetem, takich jak systemy automatyki domowej.
ZimaBoard zużywa więcej energii niż Pine A64, z typowym poborem mocy około 5-6 watów. Choć jest to nadal stosunkowo niskie, może nie być odpowiednie do zastosowań, gdzie priorytetem jest efektywność energetyczna.
D. Rozpraszanie ciepła
Rozpraszanie ciepła jest ważnym czynnikiem przy wyborze płyty, zwłaszcza jeśli planujesz jej długotrwałe użytkowanie lub pracę w ograniczonej przestrzeni.
Płyta Pine A64 ma stosunkowo niską emisję ciepła, dzięki mniej wydajnym komponentom sprzętowym. Czyni to ją odpowiednim wyborem do zastosowań, gdzie rozpraszanie ciepła jest istotne.
ZimaBoard generuje więcej ciepła niż Pine A64, ze względu na mocniejsze komponenty sprzętowe. Jednak posiada wbudowany radiator i wentylator, które pomagają rozpraszać ciepło i utrzymywać płytę w chłodzie podczas długotrwałego użytkowania.
IV. Wsparcie systemu operacyjnego
Kolejnym ważnym czynnikiem do rozważenia przy wyborze między płytą Pine A64 a ZimaBoard jest wsparcie systemu operacyjnego. W tej sekcji porównamy wsparcie systemów operacyjnych dla obu płyt.
A. Pine A64 Board
Linux
Płyta Pine A64 ma doskonałe wsparcie dla systemu Linux, z kilkoma popularnymi dystrybucjami dostępnymi, w tym Debian i Ubuntu. Te dystrybucje są dobrze wspierane i regularnie aktualizowane, co czyni je niezawodnym wyborem dla programistów i hobbystów.
Android
Pine A64 Board ma również dobre wsparcie dla Androida, z kilkoma popularnymi dystrybucjami Androida dostępnymi. Czyni to go odpowiednim wyborem do zastosowań, gdzie kompatybilność z Androidem jest priorytetem, takich jak centra multimedialne czy aplikacje do gier.
Inne
Oprócz Linuksa i Androida, Pine A64 Board obsługuje także kilka innych systemów operacyjnych, w tym OpenBSD i FreeBSD. Chociaż te systemy operacyjne nie są tak powszechnie używane jak Linux i Android, stanowią odpowiedni wybór dla deweloperów i hobbystów chcących eksperymentować z różnymi systemami.
B. ZimaBoard
Linux
ZimaBoard ma doskonałe wsparcie dla Linuksa, z szerokim wyborem popularnych dystrybucji, w tym Ubuntu, Debian i Fedora. Płytka jest dostarczana z preinstalowanym U-boot i jądrem, co ułatwia rozpoczęcie pracy z preferowaną dystrybucją Linuksa. ZimaBoard obsługuje także Yocto, lekką i konfigurowalną dystrybucję Linuksa często używaną w systemach wbudowanych.
Android
ZimaBoard obsługuje Androida, co czyni go świetną opcją dla projektów wymagających systemu opartego na Androidzie. Android oferuje przyjazny interfejs użytkownika i ogromny wybór aplikacji, co sprawia, że jest idealny do zastosowań takich jak centra multimedialne, konsole do gier czy urządzenia IoT. ZimaBoard obsługuje Androida 10, co czyni go jedną z najnowszych wersji Androida dostępną na komputerze jednopłytkowym.
Inne
Oprócz Linuksa i Androida, ZimaBoard obsługuje także inne systemy operacyjne, takie jak Windows 10 IoT Core i FreeRTOS. Te opcje zapewniają elastyczność w wyborze systemu operacyjnego dopasowanego do specyficznych potrzeb projektu.
Jeśli chodzi o wsparcie systemów operacyjnych, ZimaBoard oferuje szeroki wybór opcji, co czyni go wszechstronnym i elastycznym wyborem do różnych projektów. Dzięki wsparciu popularnych dystrybucji Linuksa, Androida i innych systemów operacyjnych, ZimaBoard może sprostać potrzebom zarówno deweloperów, jak i hobbystów.
V. Porównanie cen
Wybierając komputer jednopłytkowy do swojego projektu, cena często jest kluczowym czynnikiem. W tej sekcji porównamy ceny Pine A64 i ZimaBoard, zarówno w wersji samej płytki, jak i w pakietach zestawów.
A. Pine A64 Board
Tylko płytka
Płytka Pine A64 jest dostępna do zakupu za 29,99 USD na stronie Pine64. Cena ta obejmuje płytkę Pine A64, ale nie zawiera żadnych akcesoriów ani peryferiów. Warto zauważyć, że koszty wysyłki mogą się różnić w zależności od lokalizacji.
Pakiety zestawów
Oprócz opcji samej płytki, Pine64 oferuje również kilka pakietów zestawów, które zawierają dodatkowe akcesoria i peryferia. Ceny tych pakietów różnią się w zależności od konkretnego zestawu i dołączonych akcesoriów, ale zazwyczaj mieszczą się w przedziale od około 60 do 130 dolarów.
B. ZimaBoard
Tylko płytka
ZimaBoard jest dostępny do zakupu za 99 dolarów na stronie ZimaBoard. Cena obejmuje samą płytkę, a podobnie jak w przypadku Pine A64, koszty wysyłki mogą się różnić w zależności od lokalizacji.
Pakiety zestawów
ZimaBoard oferuje również pakiety zestawów, które zawierają dodatkowe akcesoria i peryferia. Ceny tych pakietów wahają się od 129 do 159 dolarów, w zależności od konkretnego zestawu i dołączonych akcesoriów.
VI. Zastosowania
Komputery jednopłytkowe, takie jak Pine A64 i ZimaBoard, zyskały na popularności w ostatnich latach dzięki niskim kosztom, kompaktowym rozmiarom i wszechstronności. W tej sekcji omówimy różne zastosowania obu płytek i przedstawimy, jak można je wykorzystać w różnych projektach.
A. Pine A64 Board
Komputery osobiste
Pine A64 może być używany jako niskokosztowa alternatywa dla tradycyjnych komputerów stacjonarnych. Chociaż nie ma takiej mocy obliczeniowej jak komputer wysokiej klasy, nadal poradzi sobie z podstawowymi zadaniami, takimi jak przeglądanie internetu, edycja tekstu czy obsługa poczty elektronicznej.
Centrum multimedialne
Pine A64 to także doskonała opcja do budowy centrum multimedialnego. Może być używany do strumieniowania filmów, muzyki i innych treści multimedialnych na telewizor lub inne urządzenia. Z odpowiednim oprogramowaniem możesz przekształcić Pine A64 w potężne centrum multimedialne, które dorównuje droższym opcjom na rynku.
Gry komputerowe
Chociaż Pine A64 nie jest tak potężny jak niektóre dedykowane konsole do gier, nadal można na nim grać w podstawowe gry. Z odpowiednim oprogramowaniem i akcesoriami możesz przekształcić Pine A64 w konsolę do gier retro lub nawet zagrać w niektóre nowoczesne gry.
IoT
Pine A64 może być używany do budowy różnych urządzeń IoT dzięki niskim kosztom, niewielkim rozmiarom oraz kompatybilności z szeroką gamą czujników i innych komponentów sprzętowych. Z odpowiednim oprogramowaniem możesz wykorzystać Pine A64 do tworzenia inteligentnych urządzeń domowych, systemów monitorowania środowiska i innych.
B. ZimaBoard
Komputery osobiste
ZimaBoard może być używany do zadań związanych z komputerem osobistym, podobnie jak Pine A64. Jednak ze względu na wyższą moc obliczeniową może być lepiej przystosowany do bardziej wymagających zadań, takich jak montaż wideo, projektowanie graficzne czy gry.
Podobnie jak Pine A64, ZimaBoard może być używany do budowy centrum multimedialnego. Jednak jego wyższa moc obliczeniowa i kompatybilność z wyświetlaczami 4K czynią go bardziej wydajną opcją do strumieniowania wysokiej jakości treści multimedialnych.
Gry komputerowe
Wyższa moc obliczeniowa ZimaBoard oraz kompatybilność z wysokiej klasy kartami graficznymi sprawiają, że jest to doskonała opcja do budowy komputera do gier. Dzięki odpowiedniemu sprzętowi i oprogramowaniu możesz stworzyć potężną maszynę do gier, która poradzi sobie nawet z najbardziej wymagającymi tytułami.
IoT
ZimaBoard może być również używany do budowy różnych urządzeń IoT. Jego wyższa moc obliczeniowa oraz kompatybilność z szeroką gamą czujników i innych komponentów sprzętowych czynią go doskonałym wyborem do tworzenia bardziej zaawansowanych projektów IoT.
Podsumowując, zarówno Pine A64, jak i ZimaBoard mają szeroki zakres zastosowań, od komputerów osobistych i centrów multimedialnych po gry i IoT. Pine A64 może być bardziej przyjazny dla budżetu, natomiast ZimaBoard oferuje wyższą moc obliczeniową i kompatybilność z bardziej wymagającymi projektami. Ostateczny wybór między nimi zależy od wymagań i budżetu Twojego konkretnego projektu.
VIII. Opinie i opinie użytkowników
A. Pine A64 Board
Pine A64 Board otrzymał mieszane opinie od użytkowników. Niektórzy chwalili jego przystępną cenę i wszechstronność, podczas gdy inni krytykowali jego wydajność i niezawodność. Jeden z użytkowników na Amazon pochwalił niską cenę płytki, twierdząc, że pozwoliła mu zbudować potężny komputer bez dużych wydatków. Jednak inny użytkownik zauważył, że wydajność płytki była słaba i nie spełniła jego oczekiwań.
Pod względem niezawodności niektórzy użytkownicy zgłaszali problemy z prawidłowym uruchamianiem płytki lub jej zawieszaniem się podczas użytkowania. Inni zauważyli, że łączność Wi-Fi płytki bywa niestabilna, a sama płytka nie jest szczególnie przyjazna dla użytkownika. Mimo to wielu użytkowników uważa Pine A64 Board za niezawodną i opłacalną opcję do zastosowań osobistych i innych projektów.
B. ZimaBoard
ZimaBoard otrzymał ogólnie pozytywne opinie od użytkowników. Wielu chwaliło wydajność i wszechstronność płytki oraz jej przyjazny dla użytkownika design. Jeden z użytkowników na Amazon stwierdził, że płytka była łatwa do skonfigurowania i używania oraz działała bez zarzutu w jego projekcie.
Jednak niektórzy użytkownicy zgłaszali problemy z niezawodnością płytki, zwłaszcza w kwestii przegrzewania się i problemów z zasilaniem. Inni zauważyli, że rozwiązywanie problemów z płytką może być trudne, gdy pojawią się usterki. Pomimo tych problemów wielu użytkowników uważa ZimaBoard za potężną i wszechstronną opcję do różnych projektów, w tym do zastosowań osobistych i IoT.
Ogólnie opinie użytkowników na temat zarówno Pine A64 Board, jak i ZimaBoard są mieszane. Obie płytki mają swoje zalety i wady, dlatego ważne jest, aby dokładnie rozważyć swoje potrzeby i wymagania przed podjęciem decyzji o zakupie.
Ostateczne przemyślenia.
Wybierając komputer jednopłytkowy, należy wziąć pod uwagę wiele czynników, takich jak specyfikacje techniczne, wydajność, cena i opinie użytkowników. Zarówno Pine A64 Board, jak i ZimaBoard to doskonałe wybory oferujące potężne specyfikacje sprzętowe i wszechstronne zastosowania. Pine A64 Board oferuje lepszą cenę i opcje łączności, natomiast ZimaBoard zapewnia lepszą grafikę i możliwości przechowywania danych.
Ostateczny wybór między tymi dwoma płytkami zależy od konkretnych wymagań Twojego projektu i budżetu. Niezależnie od tego, którą płytkę wybierzesz, zarówno Pine A64 Board, jak i ZimaBoard to potężne narzędzia, które mogą pomóc ożywić Twoje projekty.
Centrum Kampanii Zima
IBC2026 Amsterdam: przepływy pracy AI w mediach, lokalna pamięć masowa i trendy technologiczne dla twórców
IBC2026 pokazuje, jak indeksowanie AI, produkcja agentowa, otwarte przepływy pracy w mediach i proweniencja treści kształtują na nowo infrastrukturę medialną. Ten przewodnik przekłada te...
Przewodnik po Open Source AI Summit 2026: daty, prelegenci, agenda i lokalna sztuczna inteligencja
Open Source AI Summit 2026 łączy lokalne wnioskowanie, otwarte modele, prywatną sztuczną inteligencję, frameworki agentów, weryfikowalny sprzęt oraz prawo do obliczeń w ramach dwudniowego...
Jak Giorgio Cappello Di Paglia testuje gry tak, jakby był rok 1997, na ZimaBoard 2
Giorgio Cappello Di Paglia używa ZimaBoard 2 i Batocery, aby sprawdzić, czy współcześni gracze nadal potrafią dostosować się do gier zaprojektowanych w stylu produkcji...
