A Printed Ten-Inch ZimaBoard 2 Rack with Four Drive Trays
Thank you to u/Gerrit3D for sharing a black-and-green, ten-inch rack built around a ZimaBoard 2 and four drive positions. The original photographs follow the project from printed rails and threaded inserts to drive trays, exterior panels and the assembled NAS enclosure.
The Reddit showcase is especially useful as a construction record. It reveals how the storage hardware fits together rather than showing only a finished front panel. The software, disk capacities and array configuration are not specified, so this story focuses on the physical work the creator actually shows.
A Printed Rack Gives the NAS a Defined Shape
The finished assembly places the ZimaBoard 2 above a vertical stack of drive trays. Green handles contrast with the black structure, making the individual storage positions easy to identify. The side panels continue the same color scheme, while patterned openings leave the internal arrangement partly visible.
That organization is the practical achievement. A small server board and several disks can quickly become a collection of loose components. Here, the rack gives each part a place and presents the drive positions together as one assembly. The front photograph also shows access to the board's network connections.
Gerrit3D’s black and green printed ten-inch rack with a ZimaBoard 2 above four drive trays
The assembled ten-inch rack places a ZimaBoard 2 above four green-handled drive positions. Original photograph by u/Gerrit3D.
The ZimaBoard 2 is the hardware reference for this project. Our printed Labrax backup-NAS story offers a related example of organizing storage around the same board family, with its own documented parts and purposes.
The Rail Photographs Explain the Construction
Before the completed rack appears, the creator shows black printed rails with rows of brass-colored threaded inserts. The repeated mounting positions connect the construction photographs to the finished rack's front edges. These details make the project more informative than a single photograph of a closed box.
The source does not identify the insert dimensions, filament or print settings. Those details should stay open. A reader can understand the method without being given an invented bill of materials or a guessed printer profile.
Gerrit3D’s printed rack rails with brass threaded inserts fitted along the mounting positions
Printed rails with threaded inserts during construction. The source does not specify insert size or filament. Original photograph by u/Gerrit3D.
For another builder, the relationship between the rails and trays is a useful starting point. Repeated mounting positions allow the enclosure to be organized around layers, while each layer still needs to match the components it supports. The photographs document one successful physical arrangement, rather than a universal dimensional standard for every ten-inch build.
Drive Trays Make the Storage Positions Visible
One construction view shows a hard drive resting in a tray with a green handle. Another shows trays stacked near the work area. These images explain how the repeated front handles relate to the disks inside the rack.
Visible element What it contributes
ZimaBoard 2 at the top A defined position for the compact server board
Printed rails and threaded inserts Repeated mounting positions for the assembly
Four drive positions An organized physical layout for storage
Green tray handles Distinct, identifiable fronts for the trays
Patterned side panels An exterior that continues the build's black-and-green design
A hard drive resting in one of Gerrit3D’s green-handled printed drive trays
A drive in its printed tray during assembly. The photograph shows the physical fit, rather than an array or capacity configuration.
A tray is a mechanical part of the storage system. It does not establish whether the operating system can see the disk, what data is stored there or whether redundancy is configured. Keeping those layers separate lets the construction story remain useful without turning the pictured drive count into an unsupported usable-capacity claim.
The Rear View Adds the Cabling to the Picture
The rear photograph shows the cabling that the tidy front view leaves out. It makes the enclosure's depth and the relationship between its storage positions more apparent. A rack layout has to accommodate these connections as well as the visible faces of its components.
Rear view of Gerrit3D’s printed NAS rack showing the storage and power cabling
The rear of the rack shows the connections and cable space behind the drive positions. Original photograph by u/Gerrit3D.
The source does not give a complete controller and power-supply specification. The board's official connection guide provides separate background on its SATA and PCIe interfaces. Four physical bays should not be read as four native SATA ports or proof of a particular expansion controller.
For someone adapting the enclosure idea, the installed cables belong in the physical fit check. A connector needs room behind its socket, and reaching a drive later should not require pulling on adjacent connections. These are considerations suggested by the visible assembly, not a reproduction procedure supplied by the creator.
The Photographs Document a Build, Not a Performance Test
The patterned panels and open areas are visible design features. The post does not supply airflow measurements, noise readings or a thermal comparison. Their appearance alone cannot establish a cooling result.
The same applies to the server role. The images show hardware, trays and wiring; they do not identify a running application stack or demonstrate a backup restore. Our small homelab story from u/jc-21 is a useful companion for thinking about service responsibilities alongside a physical inventory.
As another project develops beyond assembly, documenting where applications store their data becomes valuable. The Docker volumes documentation explains one approach to persistent application data for builders who choose containers. That is software-planning context, not a claim that this rack runs Docker.
Which Zima product is shown?
The project uses a ZimaBoard 2. The photographs do not establish its exact memory or onboard-storage SKU.
Does a four-bay layout establish the usable capacity?
No. Disk capacities, the storage configuration and its overhead are not specified in the source.
Are the print files linked?
No verified model-download link is supplied with the source material used here. The construction photographs remain the reference for this particular assembly.
Which operating system runs on the NAS?
The source does not confirm one. This story preserves that boundary instead of assigning a typical NAS operating system.
Conclusion
Gerrit3D's rack is a useful construction story because its photographs explain the rails, trays and connections behind the finished front. The ZimaBoard 2 and four drive positions become a coherent physical assembly. Keeping the unknown software and storage configuration separate makes the documented work easier to understand and avoids promising results the showcase does not demonstrate.
Zima Campaign Hub
