Before First Boot: A ZimaBlade 7700 NAS Plan with Six Drives
Thank you to u/DarkMauler93 for sharing a first ZimaBlade 7700 assembly with a six-drive hot-swap cage. The creator has the physical parts together and wants to learn how to turn them into a NAS, with TrueNAS, Jellyfin and a family Minecraft server among the intended uses.
The original Reddit discussion is explicit about its stage: the machine had not yet been powered up or configured when it was posted. That makes this a record of a beginner's hardware starting point and software plan, rather than a claim that a six-drive array or application stack was already running.
A Six-Drive Cage Gives the First Build an Ambitious Shape
The creator reports six 2 TB drives in the cage and identifies the board as a ZimaBlade 7700 in the discussion. The photograph shows the compact board beside the cage, with storage cables extending above the assembly and an expansion card in the arrangement.
The six disks represent 12 TB of nominal raw capacity before any storage layout or overhead. The creator estimates roughly 6 TB under a future RAID arrangement, but does not identify the layout or demonstrate a configured pool. That estimate should therefore remain a target, not a verified usable-capacity result.
DarkMauler93’s pre-boot ZimaBlade 7700 assembly with a six-drive hot-swap cage
The pre-boot ZimaBlade assembly and six-drive cage as originally shared. Photograph by u/DarkMauler93; the source does not show a configured storage pool.
The ZimaBlade hardware page is the relevant product reference. Our small homelab story from u/jc-21 offers a related example of connecting compact hardware to clearly identified service roles.
The Board, Expansion Card and Cage Have Different Jobs
The official ZimaBlade overview lists two native SATA ports and a PCIe interface. The photographed six-drive arrangement therefore needs to be understood as more than the board's native disk connections alone.
Part or goal What the source establishes
ZimaBlade 7700 The creator's chosen server board
Six 2 TB disks Reported drives fitted to the cage
Expansion hardware and cables Visible in the assembly; no complete controller specification supplied
TrueNAS The intended operating-system choice
Jellyfin and Minecraft Planned household applications
RAID usable capacity An estimate, with no completed pool shown
A disk cage holds and connects the drives, while the storage controller and operating system determine how they are presented to the server. Keeping those functions separate helps explain why an assembled photograph cannot establish a successful software setup.
Power Is One of the Questions Before First Boot
A reply asks about the cage's power inputs. That is a reasonable question for the pictured stage, but another person's reply is not evidence that the owner has verified the electrical arrangement. The source does not provide a complete power diagram or a measured startup test.
For another beginner adapting the idea, the practical task is to identify the requirements of the actual cage, controller and drives, then check the intended supply against those parts. A connector that fits physically does not by itself describe the available power or the demand when several disks start.
This story does not supply a wiring recipe or certify the photographed configuration. The creator is asking what should be understood before getting started. Recording the specific hardware and its documentation would make that question easier for an experienced helper to answer.
TrueNAS Is the Planned Software, Not an Installation Result
The owner says they intend to install TrueNAS. Replies discuss other people's experiences with storage operating systems, but those remain separate installations. Their preferences cannot be used to say that this owner subsequently chose or successfully configured a different system.
The TrueNAS getting-started documentation separates installation, storage setup and data sharing. That is useful background for the questions raised here. The exact release, boot device and pool layout still need to be chosen for a real installation; the source does not establish those choices.
The first software milestone would be a system that reliably identifies the intended disks. A later milestone would be a storage layout whose usable capacity and recovery behavior are understood. These are proposed checks for a similar project, not results attributed to this pre-boot build.
A Media Server and a Game Server Need Separate Validation
Jellyfin and Minecraft give the planned NAS recognizable household uses. They also create different questions. A media library needs to be reachable by its client, while a game server needs to load and preserve its world for the intended players.
Jellyfin's transcoding documentation explains why playback depends on the source file and client capabilities. A hardware photograph does not establish whether a particular stream will use direct playback or transcoding, nor how many streams will run successfully.
For a similar first deployment, trying one representative client task at a time would make problems easier to isolate. The source offers no measured playback result, game-server player count or application resource allocation, so none is promised here.
The Existing Unbacked-Up Data Gives the Project a Purpose
The creator mentions having about 2 TB of data without a backup. That provides a concrete reason for wanting a better storage arrangement. It also makes it important to distinguish acquiring disks from establishing a recoverable copy of those files.
A new array can be part of a storage plan without automatically becoming an independent backup. Before moving important files, another builder would need to know where an additional copy remains and how it could be read if the new system were unavailable. Those protections are not demonstrated in the original post.
Our ZimaBlade family photo-server story explores the ongoing work of operating household storage. It offers a useful companion to this earlier milestone, where the hardware is assembled and the operational questions are still being asked.
Was this server running when the owner posted?
No. The owner explicitly says it had not yet been powered up or configured.
Are six 2 TB drives equivalent to 6 TB of usable storage?
The nominal raw total is 12 TB. Usable capacity depends on the layout and overhead; no completed layout is verified in the source.
Were Jellyfin and Minecraft already deployed?
No. They were intended uses, with no successful installation or workload test documented.
Does the photo confirm the power arrangement works?
No. The discussion raises power questions, and the source does not provide a completed startup test or full wiring specification.
Conclusion
This ZimaBlade 7700 build captures the beginning of a NAS project: real hardware assembled around six disks, a clear household motivation and questions asked before configuration. Its value is in making the next decisions visible. Power, disk recognition, storage layout and recoverable data each need their own confirmation before the planned services become dependable household tools.
Zima Campaign Hub
