How Warm Cache Changes Repeated Plex Requests
Warm cache changes repeated Plex requests because data that was expensive to fetch once may already be available from faster memory or local cache.
That faster second request is useful production behavior, but it can mislead capacity testing. A poster, metadata object, filesystem page, or recently read file may return quickly without exercising the same storage path as the first request. The useful comparison labels cache state, working-set size, and memory pressure so repeated speed is not mistaken for unlimited server headroom.
The First Request Can Pull Data From Slower Storage
A first access may require the operating system or application to read data from SSD, HDD, or a network-mounted filesystem. That path includes device latency, filesystem work, and possibly metadata lookup before the requested bytes can be served to Plex or the client.
Linux normally uses unused memory to cache file data, so the first read can populate the page cache. Later reads may avoid some physical I/O as long as the needed pages remain resident and the application does not deliberately bypass the cache.
For a fair test, record which request is truly first after the data has not been accessed recently. Do not assume a server reboot is the only way to create a colder state, and do not force cache eviction on a production system just to chase a synthetic benchmark.
Repeated Requests May Hit RAM or Application Caches
Once the same data has been requested, several layers may answer more quickly. The operating system can retain file pages, a client can keep artwork or interface data locally, and an application can reuse generated or transformed objects rather than rebuilding them for every request.
Repeated reads are one of the clearest places where cached pages hide storage latency. That does not make the measurement invalid; it means the result describes a warm working set rather than the backing deviceโ€™s uncached performance.
Plex-specific cache behavior can also appear around generated images. A repeated image request can reuse an earlier cache file, which is a concrete example of why repeated UI work may follow a different path from the first request.
Warm Cache Helps Metadata More Than Every Media Read
Browsing a library touches many small metadata and artwork objects, so keeping frequently reused data close to memory can noticeably change interface response. A long sequential movie stream, by contrast, may read data that is touched once and then replaced by later portions of the file.
Large Plex libraries can create sizable client-side metadata caches because artwork and library information are repeatedly revisited. Metadata caches can grow even when the video files themselves stay on the server.
The distinction matters when interpreting โ€œPlex feels faster.โ€ A warm poster grid does not prove that storage can sustain more concurrent streams, and a cached file segment does not prove the entire movie fits in memory. Name the request type before turning a warm response into a capacity claim.
Cache Eviction Can Make Performance Change Again
Warmth is temporary. As applications need memory, the operating system can reclaim cached pages, and client caches can evict older objects to make room for new ones. A request that was fast an hour ago may therefore return to the slower path without any hardware failure.
Page cache is designed to use available memory while yielding it when other work needs space. A practical explanation of cache reclamation under memory pressure helps explain why the same repeated request can change as the serverโ€™s working set and concurrent services change.
Test this by repeating the same request after a quiet interval and again while memory-heavy jobs are active. If latency grows only when the useful working set is displaced, the result points to cache residency and memory pressure rather than a suddenly slower disk.
Separate Warm-Cache Speed From Sustainable Capacity
Capacity testing should include at least a first or colder access, a repeated warm access, and a sustained workload larger than the useful cache. The goal is not to eliminate caching, but to understand which layer carried each result and whether the backing resources still have margin once reuse stops helping.
A warm result is valid when the production workload genuinely reuses the same data. It becomes misleading when a short benchmark is generalized to a much larger library, more clients, or a working set that no longer fits. Treat cache state as part of the test conditions, just like client, bitrate, and concurrency.
When the decision specifically concerns repeated NAS reads, compare SSD read cache versus direct disk. For Plex, the durable lesson is simpler: warm data changes latency, but only a larger sustained test shows what the server can maintain after the cache stops covering the backing path.
