The top 10 GitHub agent skills trending this week include OmniRoute, Orca, code-review-graph, Graphify, Hallmark, Pi, Grok Build, i-have-adhd, Agent-Reach, and OfficeCLI. This July 21–26, 2026 snapshot ranks agent-related projects selected from the GitHub Weekly Rank Top 20 by weekly Star growth. Some are installable skills, while others are agent tools, context systems, model gateways, or coding-agent runtimes that add practical capabilities to an AI workflow.
How This GitHub Agent Skills Ranking Was Built
The source data comes from the GitHub Weekly Rank for July 21–26, 2026. That leaderboard orders open-source repositories by the number of Stars gained during the week, rather than by lifetime Stars, downloads, installations, benchmarks, or editorial scores.
The source leaderboard covers all kinds of open-source projects. For this article, we filtered its Top 20 for repositories that directly provide a capability, interface, workflow, or knowledge layer for AI agents. The projects retain their relative order from the source ranking, but they are numbered from 1 to 10 within this agent-focused list.
| Agent Rank | GitHub Weekly Rank | Project | Weekly Star Growth | Agent Capability |
| 1 | 1 | OmniRoute | 11,190 | Multi-provider model routing |
| 2 | 2 | Orca | 7,205 | Parallel coding-agent management |
| 3 | 3 | code-review-graph | 6,281 | Local-first code context |
| 4 | 7 | Graphify | 4,906 | Queryable repository knowledge graphs |
| 5 | 8 | Hallmark | 4,810 | Design review for coding agents |
| 6 | 9 | Pi | 4,756 | Extensible agent runtime and CLI |
| 7 | 11 | Grok Build | 3,989 | Terminal-based coding agent |
| 8 | 16 | i-have-adhd | 3,270 | Concise, ADHD-friendly agent output |
| 9 | 17 | Agent-Reach | 3,083 | Cross-platform web research |
| 10 | 19 | OfficeCLI | 2,873 | Word, Excel, and PowerPoint automation |
Weekly Star growth shows where GitHub attention is moving, but it does not prove that a repository is secure, stable, compatible with your agent, or appropriate for production. Treat this as a discovery list and inspect each project before installation.
Top 10 GitHub Agent Skills Trending This Week
1. OmniRoute: Route Coding Agents Across AI Providers
OmniRoute ranked first on the complete GitHub weekly leaderboard with 11,190 new Stars. It provides one endpoint for connecting coding tools such as Codex, Claude Code, Cursor, Cline, and GitHub Copilot to multiple AI providers.
The practical capability is model routing. Instead of configuring every agent separately for one provider, a routing layer can centralize provider selection and fallback behavior. This is relevant to builders who switch models because of availability, task fit, context requirements, or usage limits.
Best for: developers using several coding agents or AI providers.
Check before use: provider credentials, routing rules, request logging, fallback behavior, data handling, and whether the advertised integrations match your current tools.
2. Orca: Manage a Fleet of Parallel Coding Agents
Orca gained 7,205 Stars and placed second on the weekly leaderboard. It is positioned as an agent development environment for running and managing multiple coding agents from desktop and mobile interfaces.
This addresses a different problem from model routing. Once several agents are working simultaneously, the user needs visibility into active tasks, results, failures, and handoffs. Orca is therefore more relevant to builders coordinating a fleet of agents than to someone running one short coding session.
Best for: parallel coding tasks and multi-agent supervision.
Check before use: supported coding agents, subscription requirements, workspace isolation, permission boundaries, mobile access, and how concurrent agents modify the same repository.
3. code-review-graph: Give Agents Persistent Code Context
code-review-graph ranked third after gaining 6,281 Stars. It builds a local-first code intelligence graph that can be accessed through MCP and CLI workflows.
The project attempts to reduce a common large-repository problem: an AI coding agent often reads individual files without understanding how modules, definitions, and dependencies connect. A persistent code graph can help the agent retrieve a smaller, more relevant context set during review or implementation.
Best for: large repositories, code review, dependency tracing, and context-efficient agent workflows.
Check before use: language coverage, parsing accuracy, graph refresh behavior, local storage requirements, MCP permissions, and how the project measures context reduction.
4. Graphify: Turn Repositories Into Queryable Knowledge Graphs
Graphify gained 4,906 Stars and occupied seventh place on the complete weekly leaderboard. It is presented as an AI coding-assistant skill for Codex, Claude Code, Cursor, Gemini CLI, and other agent environments.
Graphify can map more than application source code. Its scope includes documentation, SQL schemas, configuration, infrastructure, scripts, and other project materials. This makes it useful when the relationships an agent needs extend across code, data, and operational files.
Best for: repository exploration, architecture questions, schema relationships, and mixed code-and-document context.
Check before use: supported file types, parsing limits, graph size, indexing time, local-data handling, and whether every generated relationship can be traced to its source.
5. Hallmark: Reduce Generic AI-Generated Interface Design
Hallmark gained 4,810 Stars and ranked eighth on the source leaderboard. It is an installable design-oriented skill for Codex, Cursor, and Claude Code.
The project targets generic AI-generated interfaces by giving coding agents a more opinionated design-review workflow. This can help when an agent produces technically functional pages that still suffer from weak hierarchy, repetitive cards, excessive decoration, inconsistent spacing, or predictable visual patterns.
Best for: landing pages, dashboards, frontend review, and reducing generic AI interface output.
Check before use: whether its design rules match your brand system, accessibility requirements, component library, responsive behavior, and existing repository instructions.
6. Pi: Build on an Extensible Agent Harness
Pi gained 4,756 Stars and ranked ninth in the weekly source data. It combines a unified multi-provider LLM API, an agent runtime with tool calling and state management, an interactive coding-agent CLI, and terminal UI components.
Pi is closer to an agent harness than a narrow task skill. It is useful for developers who want to assemble or extend their own coding-agent environment instead of installing one instruction package for a single workflow.
Best for: custom agent runtimes, terminal-based coding, tool calling, and multi-provider development.
Check before use: filesystem and process permissions, network access, provider authentication, sandboxing, containerization, dependency pinning, and the boundaries applied to shell commands.
7. Grok Build: Run a Coding Agent From the Terminal
Grok Build gained 3,989 Stars and ranked eleventh on the full weekly leaderboard. It is an open-source terminal-based coding-agent harness with a full-screen interface.
The agent can work with a codebase, edit files, execute shell commands, search the web, and manage longer tasks. It supports interactive use as well as headless operation for scripting or CI, making it more substantial than a single reusable agent skill.
Best for: terminal-first coding, repository edits, scripted agent work, and extensible CLI workflows.
Check before use: authentication, sandboxing, shell access, approval behavior, supported platforms, web-search permissions, and the difference between building from source and installing a released binary.
8. i-have-adhd: Make Agent Answers Easier to Scan
i-have-adhd gained 3,270 Stars and ranked sixteenth overall. Unlike the larger runtimes in this list, it is a focused behavioral skill designed to stop coding agents from burying the answer inside lengthy explanations.
This does not give an agent a new external tool. It changes how information is organized and presented, making the result more concise and easier to scan. That can be useful for developers who want the decision, command, error, or next action surfaced quickly.
Best for: concise responses, clearer action items, and ADHD-friendly output structure.
Check before use: whether aggressive brevity removes technical context, warnings, assumptions, or evidence needed for complex engineering decisions.
9. Agent-Reach: Add Cross-Platform Research Capabilities
Agent-Reach gained 3,083 Stars and ranked seventeenth on the full weekly leaderboard. It provides a CLI through which an AI agent can search or read content from platforms including GitHub, Reddit, YouTube, Twitter, Bilibili, and Xiaohongshu.
The capability is useful when an agent needs evidence from several public platforms rather than ordinary webpage search alone. Potential workflows include gathering user reports, comparing community reactions, finding videos, and locating repository discussions.
Best for: cross-platform research, community discovery, content monitoring, and gathering user-generated evidence.
Check before use: platform terms, login or cookie handling, rate limits, scraping behavior, data freshness, regional accessibility, and whether retrieved content can be traced to its original source.
10. OfficeCLI: Let Agents Work With Office Files
OfficeCLI gained 2,873 Stars and ranked nineteenth in the source leaderboard. It is built to let AI agents read, edit, and automate Word, Excel, and PowerPoint files through a command-line interface.
This extends an agent beyond source-code workflows. A CLI-based Office layer can support report generation, spreadsheet updates, document inspection, and presentation automation without depending on a locally installed copy of Microsoft Office.
Best for: document automation, spreadsheet workflows, report production, and presentation updates.
Check before use: format fidelity, formulas, charts, macros, embedded media, tracked changes, password-protected documents, temporary files, and validation of the final rendered output.
Which Trending GitHub Agent Skill Should You Try?
| Your Main Need | Project to Evaluate | Reason |
| Switch between AI providers | OmniRoute | Centralizes provider routing and fallback |
| Manage several coding agents | Orca | Focuses on parallel agent coordination |
| Improve code-review context | code-review-graph | Builds a persistent local code graph |
| Map code, schemas, and documentation | Graphify | Creates a broader repository knowledge graph |
| Improve AI-generated interfaces | Hallmark | Adds a focused design-review skill |
| Build a custom agent environment | Pi | Provides an extensible runtime and CLI |
| Use a terminal coding agent | Grok Build | Combines code editing, commands, search, and long tasks |
| Make agent responses more concise | i-have-adhd | Changes output structure instead of adding tools |
| Research across social and content platforms | Agent-Reach | Adds cross-platform reading and search |
| Automate Word, Excel, and PowerPoint | OfficeCLI | Provides agent-oriented Office file operations |
If you want to compare other agent skills by platform and task, the AI Agent Skill Finder provides another way to narrow the available options.
How to Audit a Trending GitHub Agent Skill
Confirm What the Repository Actually Is
Do not assume every trending project is a portable SKILL.md. This list includes focused skills, command-line tools, knowledge-graph systems, routing layers, and complete agent runtimes. Their installation methods and risk profiles are different.
Inspect Installation Commands
Review shell commands before running them. Check whether installation downloads binaries, adds global packages, modifies configuration, launches containers, starts background services, or asks for administrative access.
Review Credentials and Data Paths
Identify which API keys, browser sessions, repository tokens, files, and external accounts the project can access. A model router may handle provider credentials, while a research tool may interact with cookies or platform accounts.
Check Permission Boundaries
A coding-agent runtime may be able to edit files and execute commands with the permissions of the user who launched it. Use a disposable repository, container, virtual machine, or restricted environment when the project does not provide sufficient isolation.
Validate the Output
Do not treat successful execution as proof of correctness. Review code changes, render edited Office files, verify extracted sources, inspect generated graphs, and confirm that model routing behaves as configured.
Look Beyond Weekly Star Growth
Fast Star growth can reveal emerging interest, but it can also follow a launch, announcement, or social-media spike. Check commit activity, open issues, release history, licenses, security policies, maintainers, documentation, and unresolved reports before production use.
Conclusion
The top GitHub agent skills trending this week show that the ecosystem is expanding beyond isolated prompt files. The fastest-rising projects add model routing, parallel-agent management, persistent code context, knowledge graphs, design review, agent runtimes, web research, output control, and Office automation.
OmniRoute led the complete July 21–26, 2026 GitHub weekly ranking, while focused skills such as Hallmark and i-have-adhd demonstrated that a narrow behavioral workflow can gain attention alongside larger agent platforms.
The right choice is not automatically the repository with the most new Stars. Start with the capability your workflow lacks, verify that the project truly provides it, and audit its scripts, credentials, permissions, and output before connecting it to valuable code or private data.
What are the top 10 GitHub agent skills trending this week?
For July 21–26, 2026, the ten agent-related projects selected from the GitHub Weekly Rank Top 20 are OmniRoute, Orca, code-review-graph, Graphify, Hallmark, Pi, Grok Build, i-have-adhd, Agent-Reach, and OfficeCLI.
Is this ranking based on total GitHub Stars?
No. The source ranking orders projects by Stars gained during the week. Total Stars may show a repository’s accumulated visibility, but they do not determine the order used here.
Are all ten repositories installable agent skills?
No. Hallmark and i-have-adhd are closer to focused skills. Other entries are model gateways, agent environments, code-context systems, CLI tools, or complete agent runtimes. The broader “agent skills” label refers to capabilities they add to agent workflows.
Which project is best for AI coding-agent context?
code-review-graph focuses on persistent local code intelligence, while Graphify maps a wider collection of code, documentation, schemas, configuration, and other project materials. The better choice depends on the scope of context your agent needs.
Which trending project is best for multiple AI providers?
OmniRoute is the most relevant option in this list for routing coding agents across multiple AI providers through a centralized endpoint.
Which project is best for managing multiple coding agents?
Orca is designed around running and managing a fleet of parallel coding agents. Review its isolation and concurrency behavior before allowing several agents to modify the same repository.
Does fast GitHub Star growth mean a project is safe?
No. Star growth measures attention, not security. Inspect the code, installation process, permissions, credential handling, releases, issues, license, and output before using a trending repository.
How often should this weekly ranking be updated?
Because the source data changes weekly, the ranking and date should be refreshed whenever a new GitHub Weekly Rank period is used. Keep the date visible so readers know which snapshot the article represents.
Qwen3.8-27B With DSpine: How Draft Models Speed Up Inference
Understand Tencent’s DSpine draft model for Qwen3.8-27B, interpret draft acceptance, and design an end-to-end SGLang comparison.
Linum’s $21K Text-to-Image Experiment: What a 2B Model Can Generate
See what Linum’s 2B P-JiT research release demonstrates, how it compresses image tokens, and which output and training-cost claims need context.
Can 64 GB of RAM Really Run DeepSeek V4 Flash 284B Without a GPU?
Examine the reported 64 GB CPU-only DeepSeek V4 Flash run, including the custom quantization, memory budget, decode speed, and limits of the experiment.
