The best AI agent framework in 2026 is LangGraph for teams that need explicit control over long-running, stateful workflows. OpenAI Agents SDK is the better lightweight choice for straightforward tool use and agent handoffs, while CrewAI is the easiest framework to understand when a project naturally maps to a team of specialized roles. Google ADK and Microsoft Agent Framework are especially compelling for organizations already invested in their respective cloud and enterprise ecosystems.
There is no universal winner. An agent framework that feels elegant in a demo can become difficult to operate once a workflow needs persistence, approvals, retries, tracing, private data access, or a mix of deterministic code and model-driven decisions. The right choice depends less on how quickly you can produce a chatbot and more on how clearly you can control what happens after the first tool call.
This guide compares ten AI agent frameworks worth trying in 2026. We evaluated each one for orchestration control, multi-agent support, model flexibility, state and memory, observability, developer experience, and suitability for local or self-hosted deployment. Framework details were checked against official documentation on August 24, 2026.
Best AI Agent Frameworks in 2026: Quick Picks
- Best overall for controlled production workflows: LangGraph
- Best lightweight SDK: OpenAI Agents SDK
- Best for role-based multi-agent teams: CrewAI
- Best for Gemini and Google Cloud: Google Agent Development Kit
- Best for Microsoft and .NET teams: Microsoft Agent Framework
- Best for data-heavy and RAG agents: LlamaIndex
- Best for type-safe Python applications: Pydantic AI
- Best full-stack TypeScript framework: Mastra
- Best for modular retrieval pipelines: Haystack
- Best minimal framework for local models and code agents: smolagents
AI Agent Framework Comparison
| Framework | Primary Languages | Best For | Standout Capability | Main Tradeoff |
| LangGraph | Python, TypeScript | Stateful production agents | Durable graph execution | More orchestration code to design |
| OpenAI Agents SDK | Python, TypeScript | Lightweight agent applications | Handoffs, guardrails, and tracing | Complex workflows need added infrastructure |
| CrewAI | Python | Role-based multi-agent automation | Crews inside structured Flows | Role metaphors can add unnecessary agents |
| Google ADK | Python, TypeScript, Go, Java | Google Cloud and Gemini projects | Graph and multi-agent workflows | Features vary by language and version |
| Microsoft Agent Framework | Python, .NET; Go in preview | Enterprise and Azure applications | Unified AutoGen/Semantic Kernel successor | Newer ecosystem and migration work |
| LlamaIndex | Python | RAG and knowledge agents | Deep retrieval and data tooling | Broad API surface |
| Pydantic AI | Python | Typed business applications | Validated tools and structured output | Most attractive to Pydantic-native teams |
| Mastra | TypeScript | Full-stack TypeScript teams | Agents, workflows, memory, and evals | Smaller ecosystem than older leaders |
| Haystack | Python | Retrieval-first production systems | Composable agentic pipelines | Less role-centric than multi-agent tools |
| smolagents | Python | Learning, prototyping, and local models | Minimal CodeAgent abstraction | You assemble more production infrastructure |
How We Chose These AI Agent Frameworks
This is not a ranking based only on GitHub stars. Popularity can indicate community interest, but it does not tell you whether a framework can safely resume a failed workflow or make an agent's decisions observable. We prioritized seven practical questions:
- Control: Can developers combine deterministic application logic with model-driven decisions?
- Reliability: Does the framework support persistence, retries, checkpointing, or durable execution?
- Human oversight: Can a run pause for approval before a sensitive action?
- Observability: Can teams inspect prompts, model calls, tool use, handoffs, latency, and errors?
- Interoperability: Can the framework work with multiple models, tools, MCP servers, or existing application components?
- Deployment fit: Can it run in the environment your data and governance requirements demand?
- 2026 relevance: Is it actively documented, and has its strategic position changed since older comparison articles were published?
That last criterion matters. Microsoft now describes Microsoft Agent Framework as the direct successor to both AutoGen and Semantic Kernel's agent framework. Repeating an older list without accounting for that transition would make the comparison easier to write but less useful to someone starting a new project in 2026.
1. LangGraph โ Best Overall for Controlled, Stateful Agent Workflows
LangGraph is the strongest general recommendation when an agent must do more than complete a short tool-calling loop. It represents an application as a graph of state, nodes, and transitions, making it possible to combine predictable code paths with steps in which an LLM decides what to do next.
Its defining capabilities are durable execution, persistence, streaming, and human-in-the-loop control. A checkpointer can save graph state so a process can recover from failure, wait for an external decision, or resume a long-running task later. This is particularly useful for approval workflows, research pipelines, support operations, and agents that may run for minutes or hours rather than seconds.
LangGraph also benefits from the wider LangChain ecosystem. LangChain provides higher-level agent abstractions and integrations, while LangGraph supplies the lower-level orchestration runtime. Teams can start with a prebuilt agent and move down to explicit graph control when the application becomes more demanding.
Best for: Production workflows that need explicit state, branching, recovery, approvals, or auditability.
Watch out for: A graph gives you control because you must define that control. Small projects may not need the additional nodes, state schemas, and persistence decisions.
2. OpenAI Agents SDK โ Best Lightweight SDK for Tools and Handoffs
The OpenAI Agents SDK uses a deliberately small collection of primitives: agents with instructions and tools, handoffs or agents-as-tools for delegation, guardrails for validation, sessions for conversational state, and built-in tracing. Official SDKs are available for both Python and TypeScript.
The minimal API is its biggest advantage. A developer can define a specialist, expose typed tools, and route work to another specialist without first learning a large orchestration vocabulary. Built-in tracing records model generations, tool calls, handoffs, guardrails, and custom events, which gives the framework more production visibility than its small surface area might suggest.
The SDK is a particularly good match when OpenAI models, the Responses API, or realtime voice are central to the product. It can also work with other model providers, but teams should still test provider-specific behavior, structured output, and tool-call compatibility rather than assuming every model behaves identically.
Best for: Developers who want a concise Python or TypeScript SDK for tool-using agents, specialist delegation, guardrails, tracing, or voice experiences.
Watch out for: The core agent loop is intentionally lightweight. Durable, long-running processes may require an additional runtime or integration such as Temporal, Restate, or DBOS.
3. CrewAI โ Best for Role-Based Multi-Agent Teams
CrewAI organizes multi-agent systems around two main concepts. Crews are teams of autonomous agents that collaborate on a task, while Flows provide structured, event-driven control, shared state, and execution order around those teams.
This mental model is intuitive for workflows that already look like an organization: a researcher gathers evidence, an analyst evaluates it, and a writer produces a deliverable. CrewAI supports sequential and hierarchical processes, tools, memory, knowledge, structured outputs, guardrails, observability, and human-in-the-loop triggers. Its documentation recommends Flows as the structure for production applications, with agents doing bounded work inside crew steps.
Best for: Research, content operations, customer support, and business automations that divide cleanly into specialist roles.
Watch out for: Not every task needs a cast of agents. Multiple personas can increase latency, token use, and failure points without improving the result. Use a crew when specialization or independent checking adds measurable value.
4. Google Agent Development Kit โ Best for Gemini and Google Cloud
Google Agent Development Kit (ADK) is an open framework for building, evaluating, and deploying agents. It supports model-driven agents, custom tools, sessions, memory, callbacks, evaluation, and multi-agent composition. It is optimized for the Google ecosystem but is not restricted to Gemini models.
ADK 2.0 is an important 2026 update. It adds graph-based workflows for predictable execution paths, dynamic workflows expressed through code, and collaborative workflows with coordinators and subagents. Google lists ADK 2.0 for Python and Go, while the broader ADK documentation also provides TypeScript and Java support; feature parity should therefore be checked before committing to a language.
Best for: Teams using Gemini, Vertex AI, Google Cloud deployment, A2A-style multi-agent systems, or a mix of deterministic graphs and model reasoning.
Watch out for: The framework is evolving quickly, and ADK 2.0 introduced breaking changes from the 1.x workflow runtime. Verify the version and language-specific documentation before designing production architecture.
5. Microsoft Agent Framework โ Best for Enterprise and .NET Teams
Microsoft Agent Framework combines ideas developed through AutoGen and Semantic Kernel into Microsoft's new foundation for production agents and multi-agent workflows. It supports Python and .NET, with a separate Go SDK in public preview.
The framework targets systems that need more than a conversational loop: session-based state, middleware, telemetry, provider flexibility, graph workflows, checkpointing, restartability, human approval, and common orchestration patterns such as sequential, concurrent, handoff, and group collaboration.
For a new Microsoft-centered project, this is generally the framework to evaluate before starting with AutoGen or Semantic Kernel Agent Framework. Existing applications do not need to be rewritten immediately, but Microsoft now provides migration guides from both predecessors.
Best for: Azure, Microsoft Foundry, .NET, and mixed Python/C# organizations with enterprise governance or long-running workflow requirements.
Watch out for: It is a newer unified framework. Teams migrating from AutoGen or Semantic Kernel should budget for API and architecture changes, and Go users should account for preview status and incomplete feature parity.
6. LlamaIndex โ Best for RAG and Knowledge-Intensive Agents
LlamaIndex remains one of the most natural choices when an agent's main job is to reason over private documents, indexes, databases, or other knowledge sources. Its agent layer includes function-calling agents, ReAct-style agents, CodeAct agents, memory, multimodal input, and AgentWorkflow for multi-agent handoffs.
LlamaIndex Workflows adds an event-driven, step-based execution model. A step can retrieve data, call a model, request human input, update state, or dispatch concurrent work. Because branches and loops can be written in regular Python, it suits data pipelines that need more flexibility than a simple retrieval-then-generation chain.
Best for: Document assistants, enterprise search, agentic RAG, knowledge extraction, and agents grounded in large private datasets.
Watch out for: LlamaIndex covers ingestion, indexing, retrieval, agents, and workflows, so its API surface is broad. Choose only the modules your project needs and test retrieval quality separately from agent behavior.
If private data is the reason you are considering a knowledge agent, the deployment location matters as much as the framework. See our comparison of a local AI agent server versus SaaS automation tools before deciding where documents, embeddings, logs, and tool credentials should live.
7. Pydantic AI โ Best for Type-Safe Python Applications
Pydantic AI applies the design philosophy that made Pydantic and FastAPI popular to agent development. Agent dependencies, tool arguments, and final outputs can be typed and validated, reducing the amount of ad hoc parsing between probabilistic model behavior and deterministic application code.
Its agent object combines instructions, tools, dependencies, model settings, and an optional structured output type. Pydantic Evals supports code-first test cases, while Logfire integration records messages, tool calls, token usage, latency, and errors. Instrumentation is based on OpenTelemetry, so teams are not limited to a single observability backend.
Best for: Python teams building APIs, financial or operational workflows, structured extraction systems, and applications where validated outputs are more important than elaborate multi-agent theater.
Watch out for: Pydantic AI is model-agnostic, but its strongest developer-experience advantage appears when a codebase already embraces Python typing and Pydantic schemas.
8. Mastra โ Best Full-Stack TypeScript Agent Framework
Mastra is a TypeScript-first framework that combines agents, tools, structured workflows, memory, storage, tracing, evaluation, and a local development studio. Agents can be called directly, used in workflow steps, exposed through server adapters, or coordinated as multi-agent systems.
Mastra is attractive because many capabilities that otherwise require separate packages share one programming model. Its workflows support branching, parallel execution, suspension, resume, human approval, time travel, error handling, and scheduled execution. MCP support works in both directions: Mastra can consume MCP servers and expose agents, tools, workflows, prompts, and resources to MCP-compatible clients.
Best for: Node.js, React, Next.js, and TypeScript teams that want an integrated path from prototype to an observable agent application.
Watch out for: Mastra's ecosystem is younger than LangChain's. Confirm that critical databases, deployment targets, and observability systems have the integrations your production stack requires.
9. Haystack โ Best for Modular Retrieval and Agentic Pipelines
Haystack is an open-source Python framework for production AI agents, RAG applications, and multimodal search. Its reusable pipeline components make retrieval, ranking, generation, routing, and custom processing explicit rather than hiding them inside one agent abstraction.
The Agent component can retrieve information, generate responses, and perform actions through tools. A PipelineTool can expose an entire Haystack pipeline as one callable tool, which is useful when an agent should decide when to invoke a tested retrieval or processing subsystem. Pipelines also support loops, branches, asynchronous execution, serialization, and breakpoints for inspecting and resuming execution.
Best for: Search, RAG, document processing, and multimodal systems that are becoming agentic but still need inspectable data pipelines.
Watch out for: Haystack is less focused on the human-readable โteam of agentsโ metaphor than CrewAI. That is an advantage for pipeline engineers but may feel less immediate for users prototyping role-based collaboration.
10. smolagents โ Best Minimal Framework for Code Agents and Local Models
smolagents is Hugging Face's deliberately small Python agent library. Its two main abstractions are CodeAgent, which expresses actions as Python code, and ToolCallingAgent, which uses structured tool calls. The minimal design makes the core loop easier to inspect, modify, and teach than a large framework with many layers.
Its model interface is flexible, and its natural connection to the Hugging Face ecosystem makes it a strong option for experiments with open models and local inference. Code execution must be treated carefully: official documentation recommends sandboxed environments such as Docker or supported remote sandboxes rather than giving generated code unrestricted access to a host.
Best for: Learning how agents work, rapid Python prototypes, CodeAgent experiments, agentic RAG, and projects using local or open models.
Watch out for: Minimal abstraction also means minimal production infrastructure. You may need to add your own durable execution, authorization, monitoring, and deployment layers.
Which AI Agent Framework Should You Choose?
| If Your Priority Is... | Start With | Why |
| Durable, stateful production orchestration | LangGraph | Explicit graphs, persistence, interrupts, and recovery |
| A small SDK with tools and specialist delegation | OpenAI Agents SDK | Few primitives, built-in guardrails and tracing |
| A team of role-based specialists | CrewAI | Crews provide an intuitive collaboration model |
| Gemini and Google Cloud deployment | Google ADK | Native Google ecosystem path plus open model integrations |
| Azure, .NET, or migration from AutoGen | Microsoft Agent Framework | Microsoft's unified production framework |
| Agents grounded in documents and private data | LlamaIndex or Haystack | Retrieval and data pipelines are first-class concerns |
| Validated structured output in Python | Pydantic AI | Strong typing and runtime validation |
| An integrated TypeScript stack | Mastra | Agents, workflows, memory, evals, and Studio in one ecosystem |
| A transparent local-model prototype | smolagents | Small abstractions and first-class code agents |
Can You Run AI Agent Frameworks Locally?
Yes. Most frameworks in this list are libraries that can run inside your own Python or Node.js environment. Local execution does not automatically mean local AI, however. If the framework calls a cloud model API, prompts and retrieved context may still leave your network. A fully local stack also needs a local model runtime, local storage, controlled tool access, and an observability strategy that does not export sensitive traces.
A practical local setup can start with Docker containers for the agent service, a model server such as Ollama or another OpenAI-compatible endpoint, a database or vector store, and a reverse proxy or VPN for controlled access. Our guide to building a local AI server explains the hardware and deployment decisions behind that stack.
For lightweight always-on agents, ZimaBoard 2 provides an Intel N150 processor, up to 16GB of LPDDR5 memory, dual 2.5GbE, dual SATA, and an open PCIe 3.0 slot in a fanless x86 system. It is a sensible host for orchestration services, small local models, private retrieval, monitoring, and tool servers. See what worked and what failed when a creator let an AI agent run on ZimaBoard 2.
For larger document collections, more containers, faster storage, or GPU expansion, ZimaCube 2 offers six HDD bays, additional SSD capacity, Thunderbolt 4, PCIe expansion, and higher-performance configurations. The ZimaCube 2 local AI homelab review covers Ollama, RAG pipelines, Docker, and an upgrade path for workloads that grow over time.
Five Mistakes to Avoid When Choosing an Agent Framework
1. Selecting a Framework Before Defining the Workflow
Write down the states, tools, failure conditions, approval points, and data boundaries first. A single agent with three tools may be safer and cheaper than a five-agent crew.
2. Confusing Memory With Durable Execution
Conversation history helps a model remember prior messages. Durable execution preserves workflow progress across failures, restarts, or long approval delays. They solve different problems, and production systems often need both.
3. Ignoring Tool Permissions
An agent that can search documents is different from one that can execute shell commands, control a browser, or modify customer records. Apply least-privilege permissions, sandbox code, validate tool arguments, and require approval for irreversible actions.
4. Treating Traces as Optional
When a model chooses the wrong tool, a final answer rarely reveals why. Capture model calls, tool inputs and outputs, handoffs, latency, token use, and errors from the beginning. Observability is part of the application, not an accessory to add after launch.
5. Testing Only the Happy Path
Evaluate missing data, malformed tool output, rate limits, model refusal, duplicate execution, network failure, prompt injection, and interrupted approval flows. The best framework is the one whose failure behavior your team can understand and control.
FAQs About AI Agent Frameworks
What is an AI agent framework?
An AI agent framework is a software toolkit for building applications in which a language model can decide how to use tools, retrieve information, maintain state, and complete multi-step goals. More advanced frameworks add workflow orchestration, multi-agent delegation, persistence, human approval, evaluation, and tracing.
What is the best AI agent framework in 2026?
LangGraph is the best overall choice for controlled, stateful production workflows. OpenAI Agents SDK is better when you want a lightweight agent loop with tools, handoffs, guardrails, and tracing. CrewAI is a strong starting point for role-based multi-agent automation. The best choice ultimately depends on your language, deployment environment, data, and reliability requirements.
Is AutoGen still worth using in 2026?
Existing AutoGen projects can remain useful, but teams starting a new Microsoft-centered application should evaluate Microsoft Agent Framework first. Microsoft identifies it as the direct successor to AutoGen and Semantic Kernel Agent Framework and provides migration guidance for both.
Which AI agent framework is best for RAG?
LlamaIndex is the strongest starting point when agents need to work deeply with private documents, indexes, and knowledge bases. Haystack is an excellent alternative for teams that prefer explicit, modular retrieval pipelines. LangGraph can orchestrate either retrieval stack when the surrounding workflow needs durable state and complex control.
Which framework is best for beginners?
OpenAI Agents SDK and smolagents expose relatively small conceptual surfaces. CrewAI is also approachable when the task maps naturally to recognizable roles. Beginners should first build one agent with one or two tools before adding memory, multiple agents, or autonomous execution.
Do AI agent frameworks work with local LLMs?
Many do. LangGraph, CrewAI, Google ADK, LlamaIndex, Pydantic AI, Mastra, Haystack, and smolagents can be connected to local models directly or through compatible providers, depending on the framework and runtime. Always check tool-calling and structured-output support for the specific local model; endpoint compatibility alone does not guarantee equivalent agent behavior.
Are multi-agent systems better than single agents?
Not automatically. Multi-agent systems are useful when specialists need different instructions, tools, permissions, or independent review. For a narrow workflow, extra agents often add cost, latency, and coordination failures. Start with the smallest architecture that meets the requirement and add agents only when their role is measurable.
Final Verdict
If you want one framework to evaluate first in 2026, start with LangGraph for maximum workflow control or OpenAI Agents SDK for minimum abstraction. Choose CrewAI when specialist roles are central, Google ADK or Microsoft Agent Framework when your cloud ecosystem should shape the architecture, LlamaIndex or Haystack when retrieval is the core product, Pydantic AI when type safety matters most, Mastra for a TypeScript-first full stack, and smolagents when transparency and local experimentation are the priority.
The framework is only one layer. Reliable agents also need scoped permissions, durable state, evaluations, observable tool calls, and an infrastructure boundary appropriate for the data. If your next step is assembling the software around a local model, you may also want to compare the best DeepSeek Harness plugins for 2026.
