More available tools can reduce agent planning reliability when irrelevant or overlapping choices consume attention and blur the next valid action.
A home AI agent may begin with search, files, calendars, and messaging, then gradually inherit dozens of narrow integrations. The larger catalog looks more capable, yet a simple task can become less predictable because selection, argument construction, and recovery now share the same planning budget. The important variable is not total capability alone, but how many plausible tools remain visible at each step.
Tool Count Changes the Decision Surface Before Execution
Tool count affects planning before any API runs. Each visible name, description, schema, and example becomes a candidate action that the model must compare with its current state. Adding one clearly unrelated tool may do little, while adding several semantically adjacent tools creates more branches that look locally reasonable.
Research on tool-exposure problems distinguishes semantic relevance from causal necessity. A tool can sound related to the request yet be premature, non-executable, or unable to advance the current state toward the goal. The planner must therefore reject plausible distractions, not merely find something relevant.
This makes raw catalog size an incomplete predictor. Reliability is more closely tied to the number and similarity of tools exposed at the decision point, plus whether their prerequisites and effects are distinguishable. A large registry behind a selective router can be easier to plan with than a small flat menu of overlapping functions.
Overlapping Schemas Turn Selection Errors Into Plan Errors
Choosing the wrong tool is only the first failure mode. Closely related tools often reuse fields such as query, path, recipient, or date but assign them different meanings. Once the planner commits to one candidate, it may borrow argument patterns from a neighbor and produce a call that is syntactically plausible but operationally wrong.
A practical review of tool selection at scale describes wrong calls, schema mixing, and stalled tasks as catalogs grow. These mistakes propagate: a malformed observation changes the state available to the next planning step, so a local selection error becomes a longer incorrect trajectory.
The visible symptom is not always a hard failure. The agent may call a broad search instead of a precise lookup, repeat work through two similar connectors, or manufacture a missing parameter. Planning reliability should therefore include tool correctness, argument correctness, unnecessary-step rate, and whether the final state was reached without hidden detours.
Planning Reliability Depends on Organization, Not a Magic Limit
There is no universal tool count at which an agent becomes unreliable. Model capability, prompt format, description quality, task ambiguity, and the similarity among tools all move the boundary. Ten nearly identical database actions can be harder than fifty tools divided into clean, task-specific domains.
A survey of hierarchical tool retrieval describes domain, category, and API tiers that let selection proceed through a smaller search space. Hierarchy changes the comparison from every tool against every other tool into a sequence of narrower decisions, although a wrong early branch can still hide the correct option.
The relationship is therefore conditional: a larger catalog tends to raise confusion when exposure stays flat, but organization can absorb much of that pressure. Reliability improves when routing removes irrelevant domains, schemas use distinct names and effects, and the planner can recover from a rejected branch without restarting the whole task.
Dynamic Exposure Preserves Capability With Fewer Local Choices
Dynamic exposure separates what an agent may eventually use from what it should consider now. A registry can retain every integration while a router exposes only the tools whose prerequisites are satisfied and whose effects advance the current subgoal. The menu changes as observations fill missing state.
This is a useful extension of tool-execution boundaries: capability, permission, and planning visibility need not be identical. A home agent can discover a calendar event before seeing invitation tools, or draft a file change before gaining access to the action that commits it.
Staging reduces local branching without pretending the omitted tools do not exist. It also improves auditability because each exposure decision can be tied to state, risk, and goal progress. The boundary is router quality: an aggressive filter that hides a necessary tool protects attention but blocks completion, so recall of the valid next frontier must be measured.
Measure the Catalog Through Controlled Planning Tests
A meaningful test keeps the model, task set, tool implementations, and success criteria constant while changing only the visible catalog or routing policy. Use tasks that require one tool, several dependent tools, and deliberate recovery after a failed call. Repeated runs are necessary because a single successful trace can hide unstable selection.
A production-oriented account of tool routing at scale notes that larger menus can raise token cost and wrong-call risk. Track completion, first-choice accuracy, argument validity, redundant calls, retries, latency, and the point where the plan diverges from the intended state path.
The practical goal is not the smallest possible catalog. It is the largest useful capability surface that still produces stable trajectories under representative tasks. If reliability falls, first reduce simultaneous exposure and schema overlap; if completion falls, widen retrieval recall or add a fallback route rather than permanently removing useful tools.
