A tool-execution trust boundary separates model-generated intent from privileged side effects so a local AI agent cannot turn arbitrary text into authority by itself.
This is narrower than a general privacy boundary around sensitive files. A home agent may reason over local context, propose a container restart, or generate tool arguments, but none of those outputs should automatically inherit permission to change the server. The trust boundary sits at the execution layer where schema validation, identity, resource scope, authorization, approval, and audit convert an untrusted proposal into a permitted action.
The Boundary Sits Between Model Intent and Privileged Execution
A language model can produce tool names and arguments, but those tokens are still generated content. The execution layer must treat them as a request to evaluate rather than as proof that the caller is authorized to perform the action.
Zero-trust architecture assumes that trust is not granted implicitly because a request originates inside a network or process boundary, and explicit resource-access decisions are the right mental model for local agent tool execution too.
The same principle applies even when the model runs on the home server. Locality protects data placement, but it does not make model output a trusted administrator command.
Tool Descriptions and Reasoning Stay on the Untrusted Side
Prompts, retrieved documents, web content, and tool descriptions can all influence the model's proposed action. If any of that text can directly create authority, prompt injection or a mistaken plan can cross into server control without an independent check.
Tools can represent arbitrary code execution, so tool invocation safety must remain separate from the model's selection of a tool.
Schema descriptions can constrain the shape of an action, but they remain part of the proposal surface. A field named `path` being syntactically valid does not establish that the agent may write to every path it can name.
This keeps the boundary clean: reasoning can be flexible and probabilistic on one side, while permission checks remain deterministic and enforceable on the other.
Authorization Narrows Which Resources and Operations Can Cross
Once a proposed call reaches the boundary, the executor should resolve the real identity, target resource, operation, and credential scope before doing work. Broad ambient credentials erase that distinction because every syntactically valid request becomes potentially reachable.
OAuth-based controls can protect protected resources and operations, reinforcing that tool connectivity and tool authority are separate concerns.
Narrow tool scope constrains reach; the trust-boundary view explains where those constraints must be enforced before side effects occur.
Validation, Approval, and Audit Complete the Crossing
Authorization answers whether an identity may perform an operation, but a safe boundary can also require schema validation, current-state checks, explicit user approval, rate limits, or an execution budget before releasing a high-impact action.
Confused-deputy and token-handling risks make authorization boundary failures an execution-layer concern rather than a prompt-engineering problem.
After the action crosses, record the approved parameters, identity, result, and observable side effect so later reconciliation can distinguish a failed request from an action that succeeded before the connection dropped.
The boundary is effective only when bypass paths are removed. If the agent also has an unrestricted shell, writable Docker socket, or administrator token, a carefully designed tool broker no longer defines the real trust boundary.
What Is Embedding Drift, and When Does a Private Search Index Need Rebuilding?
Decode model, preprocessing, corpus, and query drift; distinguish monitoring from incompatibility; and decide when a private index needs rebuilding.
What Is Tokenizer Compatibility, and Why Can It Break Model Switching?
Decode vocabulary identity, special-token semantics, chat templates, cached tokens, adapters, and compatibility checks for local model switching.
What Is Model Residency, and When Should a Local AI Service Keep Weights Loaded?
Decode weight residency, cache levels, cold starts, eviction, multiplexing, memory pressure, and when a home AI service should stay warm.
