Source freshness affects a private home AI knowledge base because semantically relevant documents can still describe a household state that is no longer valid.
A local RAG system may index router settings, appliance manuals, medical notes, project files, service procedures, calendars, and family records over months or years. When a source changes, the old chunk does not automatically become less similar to the same question; it may remain an excellent semantic match. Reliable answers therefore require more than recent file dates. The system must track versions, authority, effective periods, deletions, and whether the user wants the current state or a historical one.
Semantic Relevance Does Not Reveal Which Fact Is Current
Embedding and keyword retrieval rank passages that resemble the query. They do not inherently know that one configuration, policy, address, or medication schedule replaced another.
Research on temporal validity shows why contradicted and duplicated facts can remain similarly retrievable even after one value has been superseded.
A newer source may therefore compete with an older source rather than automatically outrank it. Reranking for relevance alone can still promote the wrong version when both passages answer the same wording.
Freshness Requires More Than a Filesystem Modification Date
A modification timestamp shows that a file changed, but not which statement changed, when the new rule became effective, or whether the file is authoritative for the question.
IA-RAG models temporal intervals so retrieval can reason about duration, overlap, and validity rather than treating one coarse date as the complete time model.
Useful chunk metadata can include source version, ingestion time, effective-from and effective-to dates, owner, document status, and a link to the parent record. Those fields let the system distinguish current, expired, draft, archived, and historically valid evidence.
Copied files complicate the picture because their filesystem dates may reflect the copy operation rather than the age of the underlying information.
Old and New Chunks Can Coexist After an Update
Many pipelines append newly embedded chunks without removing the previous version. Search then returns near-duplicates whose wording differs only around the changed fact.
A controlled study of stale repository context found that obsolete retrieved evidence can actively steer a model toward an outdated state rather than behaving as harmless noise.
Use stable document IDs and chunk lineage so re-ingestion can retire or replace the correct prior records. A content hash can detect unchanged material, while a version relationship can preserve history without leaving every version equally eligible for current-state questions.
Deletion must also propagate into the index. Removing the source file while leaving vectors, summaries, or caches behind creates evidence with no current owner.
Supersession Preserves History Without Treating It as Current
A household may need both the latest router configuration and the configuration used before a failure. Deleting every old version would protect current search but destroy historical traceability.
T-GRAG uses a temporal knowledge graph to represent evolving information and resolve conflicts under temporal constraints.
A simpler home implementation can mark records as superseded, record the replacement, and exclude retired versions unless the query requests an earlier date or change history.
This approach separates archival retention from default retrieval eligibility. Old evidence remains inspectable without silently competing with the current source of truth.
Query Intent Determines Whether Newer Is Actually Better
Questions such as “What is the current backup schedule?” should favor the effective version. Questions such as “What schedule was active before July?” need the historical record.
Classic work on freshness and relevance shows that temporal need is a property of the query as well as the documents.
The assistant should detect explicit dates, words such as current or previous, and tasks involving change comparison. When temporal intent is unclear and conflicting versions exist, it should surface the conflict rather than choose silently.
Freshness Must Be Tested as an End-to-End Maintenance Contract
Create test cases where a fact changes, a file is renamed, one source is deleted, two authorities disagree, and the user asks both current and historical questions.
ZimaSpace’s private document search workflow separates ingestion, chunking, metadata, retrieval, and citations, which makes freshness failures traceable to the stage that retained the wrong evidence.
Measure update lag, stale-chunk rate, current-answer accuracy, historical-answer accuracy, deleted-source leakage, and citation version. Also verify that index backups and replicas receive the same retirement events.
A private knowledge base is fresh when a source change produces a predictable retrieval-state change, not merely when the indexing job ran recently.
Should older documents always be deleted from a private knowledge base?
No. Historical versions can be valuable, but they should carry validity metadata and remain excluded from current-state answers unless the query asks for history.
Can reranking solve stale-source problems?
Only when freshness or version authority is included in the ranking logic. A relevance-only reranker may prefer an obsolete passage that closely matches the question.
How often should a home knowledge base refresh?
The interval should follow source volatility. Calendars and device state may need event-driven updates, while stable manuals can be checked much less often.
What Is Embedding Drift, and When Does a Private Search Index Need Rebuilding?
Decode model, preprocessing, corpus, and query drift; distinguish monitoring from incompatibility; and decide when a private index needs rebuilding.
What Is Tokenizer Compatibility, and Why Can It Break Model Switching?
Decode vocabulary identity, special-token semantics, chat templates, cached tokens, adapters, and compatibility checks for local model switching.
What Is Model Residency, and When Should a Local AI Service Keep Weights Loaded?
Decode weight residency, cache levels, cold starts, eviction, multiplexing, memory pressure, and when a home AI service should stay warm.
