Read-ahead can shorten sequential model loading by prefetching future pages, but oversized windows can waste cache and shared-storage bandwidth.
When several home AI workers open the same multi-gigabyte model from a NAS, demand reads may stall on each missing page. Prefetch can keep later pages ready, yet every client may also request data it never uses or duplicate another client’s traffic. The outcome depends on access order, memory mapping, page-cache reuse, model sharding, concurrency, storage latency, and where caching occurs.
Read-Ahead Converts Sequential Demand Into Earlier I/O
Without useful cache state, a loader reaches a page and waits while storage returns it. Read-ahead recognizes sequential access and issues requests for later pages before the process demands them. If prediction and timing align, computation consumes the current region while storage fills the next one.
The Linux page cache applies read-ahead and grows or shrinks its window based on observed access. It helps buffered sequential reads because future pages can already be resident when the loader reaches them.
The benefit is largest when storage latency would otherwise create gaps and the model is read in a predictable order. It is smaller when the file is already cached, direct I/O bypasses the page cache, the loader explicitly preloads everything, or the runtime touches mapped pages in an irregular pattern.
Memory Mapping Makes Page-Fault Order Part of Loading
Memory mapping can make model startup appear fast because the runtime creates address mappings before every weight page is resident. Physical I/O occurs as pages are touched. The apparent load time therefore depends on whether the benchmark stops after mapping or continues until inference has faulted in the working set.
memory-mapped model weights can incur storage delays on missing-page faults, and irregular access can produce many small reads. Read-ahead helps when touch order remains sequential enough for prediction; otherwise it may fetch the wrong regions.
Measure both time to create the model object and time to first completed token. A change that moves I/O from startup into the first request has not removed loading work. Warm-cache tests should be separated from cold-cache tests because page reuse can dominate the result.
Oversized Windows Pollute Cache and Consume Shared Bandwidth
A prefetch window that extends beyond the loader’s near-term working set transfers pages that may be evicted before use. Those pages occupy client memory, displace other cache entries, and consume bandwidth on the NAS link and storage backend. The waste becomes more visible when loaders start different models concurrently.
too much read-ahead can pollute caches with useless data, while too little causes later demand reads; both hurt performance. A fixed default cannot be optimal for sequential loading, sparse expert access, and mixed storage traffic at the same time.
Shared storage magnifies mistakes because each client makes local predictions without necessarily knowing what other clients are fetching. If server-side caching cannot coalesce those reads, synchronized startups can turn aggressive prefetch into a traffic burst that delays every loader and unrelated NAS work.
Cache Location Determines Whether Loaders Share the Benefit
A client page cache benefits processes on that machine, while a NAS cache can benefit multiple clients but still requires network transfer. GPU memory is another separate destination. The same model bytes may therefore be cached at the server, client RAM, and accelerator without one layer eliminating movement at the others.
With model sharding, workers may read only assigned regions rather than the whole file. Whole-file read-ahead can undermine that advantage by fetching shards a worker will never use, whereas shard-aligned access can keep prefetch inside the useful range.
Concurrent processes on one host may share file-backed pages, but separate hosts cannot share client RAM. Test the actual topology: local SSD, NAS over Ethernet, distributed cache, or copied model files. The same read-ahead setting can reduce local stalls and still increase total network bytes.
Tune Read-Ahead With Cold, Warm, and Concurrent Loads
Keep model file, runtime, storage path, and hardware fixed while testing several windows. Record cold time to first token, warm restart time, bytes read from storage, network throughput, page faults, cache pressure, and latency for other NAS workloads. Repeat with one loader and the expected concurrent count.
A practical discussion of prefetch and cache shows that these layers interact rather than acting as independent switches. Improvements must be attributed to useful early reads, server caching, or client reuse instead of a single startup number.
The best setting is workload-specific. Increase read-ahead while it reduces cold stalls without materially raising unused bytes or concurrent interference; reduce it when access is sparse, sharded, or cache pressure is high. Re-evaluate after runtime, model format, shard layout, or storage topology changes.
