RAG can cite an older file after sync because file arrival, successful ingestion, index activation, and current-version selection are separate state transitions.
A NAS interface may show the new copy immediately while the retrieval index still contains only the previous version. Even after the new document is embedded, both copies may remain searchable, and the older chunk can rank higher because its text, metadata, or vector is a closer match. A reliable system needs explicit version identity and atomic activation, not filename recency alone.
Synchronization Completes Before the Retrieval Pipeline Does
A sync client considers its work complete after bytes and metadata reach the destination. The indexer must still detect the change, wait for a stable file, parse or OCR it, split it, generate embeddings, write records, and publish an index generation.
A description of incremental index freshness separates change detection, content processing, and index updates. That staged model explains the freshness gap in which a file is present on storage but unavailable to retrieval. This distinction remains visible during later household testing.
Queues, retry backoff, locked files, unsupported formats, or partial-copy safeguards can lengthen the gap. Comparing NAS timestamps with index commit timestamps reveals more than checking whether the new filename exists. The intermediate result must remain inspectable before automation follows.
Both Versions Can Compete After the New Copy Is Indexed
If the updated file receives a new document ID without retiring the old one, retrieval treats them as independent evidence. Similar content produces nearly identical chunks, and small wording or chunk-boundary changes decide which one ranks first.
The freshness-aware retrieval approach studies freshness-aware retrieval for changing knowledge. Its premise shows why relevance alone is insufficient when multiple time-valid answers coexist. That boundary should be measured separately under realistic operating conditions.
Filesystem modified time is weak version identity because copying can preserve or rewrite it, clocks can differ, and renamed files can represent the same lineage. A stable document ID plus monotonic version or content lineage is safer.
Citation Assembly May Preserve a Stale Source Mapping
The generator may use a current chunk while a citation cache, preview service, or source table still resolves its logical ID to an older path. Conversely, the retrieval result itself may be stale while the displayed filename looks current.
A framework for data provenance mappings treats provenance as mappings from derived artifacts back to source inputs and transformations. Applying that chain to RAG distinguishes stale retrieval from stale citation presentation. The practical consequence appears when several sources compete for limited context.
The failure boundary is judging freshness from the citation label alone. Verify the cited bytes, version ID, content hash, indexed timestamp, retrieved chunk, and displayed source. A renamed old file and a truly current document can share a friendly name.
Test Version Activation With a Controlled File Update
Create a document whose old and new versions contain distinguishable facts. Record sync completion, watcher event, parser completion, embedding write, active-index generation, retired-version marker, retrieval result, citation resolution, and source preview while querying throughout the update.
Compare the implementation with RAG document versioning. The new version should become active atomically, and the previous one should stop participating in current queries without destroying the lineage needed to explain historical answers. This dependency should remain explicit in the final interface.
Pass only when current-version filters select the new bytes after activation and queries during ingestion return either the last complete version or an explicit updating state. If both versions rank, fix identity and retirement before tuning similarity.
Why Do SMB File Changes Reach an Incremental Indexer in Bursts?
See how SMB write caching, leases, CHANGE_NOTIFY, buffer overflow, reconnect, and indexer batching reshape steady edits into bursty ingestion events.
Why Does OCR Miss Faint Text After a PDF Is Recompressed?
Learn how PDF recompression changes faint pixels, why viewers can hide the loss, and how to test resolution, contrast, codec, and OCR preprocessing.
Why Does Local AI Latency Oscillate With a Home Server Fan Curve?
See how heat, fan control, clock limits, sensor lag, and workload timing create periodic local AI latencyโand how to prove the relationship.
