Why Does Local AI Latency Oscillate With a Home Server Fan Curve?
Local AI latency can oscillate with a fan curve when delayed cooling repeatedly pushes processor clocks above and below thermal or power thresholds.
Inference converts electrical power into heat faster than the chassis and heatsink can shed it. A fan controller reacts to a delayed temperature reading, often using steps and hysteresis, while CPU or GPU firmware independently adjusts voltage and frequency. If workload, thermal inertia, and control delays align, requests alternate between boosted, throttled, cooled, and boosted states.
Inference Heats the Device Faster Than Cooling Responds
A burst begins at high clocks while the silicon is cool, then junction temperature rises through the package and heatsink. Sensors, smoothing windows, controller polling, and fan spin-up delay airflow, so cooling response trails the workload that caused it.
A study of thermal inference degradation on edge inference measures performance degradation during sustained heating. The result connects thermal state to latency even when the model and input stay unchanged. This distinction remains visible during later household testing.
Short requests may finish before throttling, while later requests inherit accumulated heat. Idle gaps can partially reset the cycle, making periodic traffic look more variable than one continuous benchmark. The intermediate result must remain inspectable before automation follows.
Fan Steps and DVFS Thresholds Form Coupled Control Loops
The fan curve maps measured temperature to speed, while firmware maps temperature, current, and power to frequency. Each loop has thresholds and hysteresis; crossing them changes cooling or compute rate in discrete steps. That boundary should be measured separately under realistic operating conditions.
Research on fan control stability shows that delayed and imperfect temperature measurements complicate stable fan control. A controller that reacts strongly after a delay can overshoot, cool below a lower threshold, slow the fan, and repeat.
Latency follows effective clocks and memory frequency, not fan RPM directly. Fan changes can also coincide with power-limit decisions, so correlation alone does not establish that airflow rather than shared firmware policy caused the clock change.
Queueing Can Amplify a Small Clock Oscillation
When service rate falls during throttling, requests accumulate. The queue adds waiting time to already slower inference; after cooling restores clocks, the server drains the backlog and appears suddenly fast again. The practical consequence appears when several sources compete for limited context.
The thermal-aware inference management system jointly manages thermal behavior and inference scheduling, demonstrating that temperature-aware decisions can protect latency rather than treating cooling as an unrelated facility concern. This dependency should remain explicit in the final interface.
The failure boundary is blaming the fan curve for any periodic latency. Background jobs, batch formation, storage scrub, network polling, garbage collection, or power-price schedules can align with the same period. Frequency and queue metrics must bridge temperature to response time.
Overlay the Thermal Control Loop on Request Latency
Replay identical requests at a fixed interval while recording arrival, queue time, inference time, token rate, CPU and GPU clocks, package power, temperature sensors, throttle flags, fan command, actual RPM, and ambient temperature on one timeline.
Use thermal soak testing for the longer thermal-soak baseline. Compare the normal curve with a fixed safe fan speed and a gentler curve while preserving workload, power limits, model state, and enclosure. The result must therefore be checked against the original evidence.
Call the control loop causal when latency follows clock changes that follow temperature and fan response, and the oscillation weakens under a stable cooling policy. Tune hysteresis or airflow without disabling thermal protection; persistent throttling may indicate inadequate cooling capacity.
