Model caching changes response time by letting repeated requests reuse downloaded files, memory-resident weights, compiled kernels, or previously processed prompt state.
A home AI server does not have one universal cache. The model artifact may already exist on local storage, its file pages may remain in system RAM, weights may stay loaded in accelerator memory, compiled execution code may be reusable, and a repeated system prompt may still have valid KV state. Each layer removes a different part of the request path. The sections below separate those layers so a fast second reply is not mistaken for faster model generation or better hardware.
Model Caching Refers to Several Independent Layers
The first useful distinction is what has been cached. A downloaded checkpoint avoids network transfer, filesystem page cache avoids rereading some blocks from storage, resident weights avoid model loading, compiled artifacts avoid setup work, and prefix cache avoids recomputing shared prompt tokens.
Research on multi-tier caching treats model startup as movement through storage, host memory, and accelerator memory rather than one binary cold-or-warm state. A request can be warm at one layer and cold at another.
This explains why “the model is cached” is incomplete. The server may have the files locally but still need to allocate VRAM, load weights, compile kernels, and process the prompt before producing a token.
An Artifact Cache Removes Download and Repository Delay
When model files are already materialized on the home server, startup avoids authentication, repository metadata checks, remote bandwidth, and downloading multi-gigabyte shards. The runtime can begin from the local copy.
Netflix describes model artifact caching as necessary because downloading large weights during startup exceeds practical scheduler latency. The same mechanism matters at home when a container is recreated or a model is launched after a cleanup.
The artifact cache does not guarantee a fast first token. A local checkpoint can still sit on a slow disk, use many shards, require conversion, or compete with NAS reads and writes.
Filesystem Cache Can Make the Second Load Much Faster
After the operating system reads model files, clean file pages may remain in unused system RAM. A later launch can retrieve those bytes from memory instead of waiting for the storage device again.
MAIO improves LLM startup by optimizing the filesystem cache policy used during model loading. Its results show why two launches from the same NVMe path can have different read times depending on which model pages remain cached.
This cache is reclaimable. Backups, file serving, databases, or another model can displace those pages, so a response that was fast yesterday may return to storage-limited behavior after memory pressure or reboot.
Benchmarking without defining page-cache state mixes two storage regimes and can overstate the improvement from a drive upgrade.
Resident Weights Remove the Largest Reload Boundary
Keeping weights in RAM, unified memory, or VRAM lets the runtime move directly toward prompt processing. Unloading the model returns capacity to other apps but makes the next request pay the load path again.
ZimaSpace’s guide to model residency shows the characteristic pattern: one slow request after eviction followed by normal replies while the model remains warm.
Residency mainly changes readiness and time to first token. It does not necessarily increase the rate of output tokens once generation is running.
Keeping every model resident can also create the memory pressure that causes another model, KV cache, or home server app to be evicted.
Compile and Kernel Caches Remove First-Execution Work
Some runtimes specialize kernels, capture execution graphs, or compile code for the active model, GPU architecture, tensor shapes, and runtime configuration. The first compatible request may perform work that later requests reuse.
A practical cold-start analysis notes that runtime compilation can sit between loading weights and serving the first response. A persistent compile cache moves that cost away from later starts until a model, driver, runtime, or hardware change invalidates it.
This creates another warm state: the files and weights may already be present, yet the first new shape or execution path still causes a latency spike.
Prefix Caching Reduces Prefill but Not New-Token Decoding
A repeated system prompt, long document prefix, or shared instruction block normally requires the model to process the same tokens again before reaching the new user input. A prefix cache stores reusable attention state from that earlier prefill.
The Prompt Cache research reports lower first-token latency when requests reuse long prompt modules. The benefit grows with shared-prefix length because more prefill computation can be skipped.
It does not make arbitrary new prompts faster, and it does not remove the cost of decoding new output tokens. Cache hits depend on exact or supported prefix reuse, available cache capacity, and the runtime’s eviction policy.
Measure Cold and Warm Paths as Separate Response Classes
Test one fixed request after reboot, after model load, after an immediate repeat, after a long idle period, and after a competing workload. Record artifact download, storage read, model load, compilation, prompt evaluation, first token, and output-token rate separately.
Cold-cache analysis warns that warm-cache latency can hide a slower tail when some requests miss the cache. A household assistant should be evaluated by the mix users actually encounter, not only an immediate repeated benchmark.
Once the missed layer is identified, the remedy becomes specific: prefetch model files, preserve page cache headroom, extend model keep-alive, persist compile artifacts, or enable prefix reuse for stable shared prompts.
Does a cached model always use less RAM?
No. Some caches deliberately consume RAM or VRAM to reduce future work. They trade capacity for lower latency rather than reducing memory use.
Why is the first reply slow but later replies fast?
The first request may load weights, allocate runtime state, compile kernels, or process a long prompt. Later requests reuse one or more of those results.
Can clearing caches fix incorrect AI answers?
It can repair stale or corrupt runtime artifacts in some cases, but model caches normally affect loading and computation reuse, not the factual quality of unchanged weights and prompts.
What Is Embedding Drift, and When Does a Private Search Index Need Rebuilding?
Decode model, preprocessing, corpus, and query drift; distinguish monitoring from incompatibility; and decide when a private index needs rebuilding.
What Is Tokenizer Compatibility, and Why Can It Break Model Switching?
Decode vocabulary identity, special-token semantics, chat templates, cached tokens, adapters, and compatibility checks for local model switching.
What Is Model Residency, and When Should a Local AI Service Keep Weights Loaded?
Decode weight residency, cache levels, cold starts, eviction, multiplexing, memory pressure, and when a home AI service should stay warm.
