Output tokens often slow as context fills because each decoding step must address a larger KV cache and move more attention state through limited memory bandwidth.
A local model may begin a long voice or document session at ten tokens per second and gradually fall below that rate without changing weights or hardware. Every generated token extends the sequence state used by later attention. KV layout, attention implementation, precision, available VRAM, batch competition, and offload policy decide whether growth is gradual or becomes a sharp latency cliff.
Every New Token Extends the Attention History
Autoregressive decoding stores keys and values for each layer so previous tokens do not need to be recomputed. The cache grows roughly with layer count, KV heads, head dimension, sequence length, and bytes per element, making context length a direct memory variable.
paged KV storage organizes KV state into non-contiguous blocks to reduce allocation waste and enable flexible sharing. The mechanism improves capacity utilization, but the decoder still needs to access an expanding logical history unless another attention strategy reduces the active set.
Grouped-query or multi-query attention can shrink KV bytes by sharing key-value heads, while lower precision reduces bytes per element. Neither changes the fundamental fact that a longer retained history creates more state than a shorter one under the same model architecture.
Attention Becomes a Memory-Traffic Problem During Decode
Prefill processes many prompt tokens in parallel and can use GPU compute efficiently. Decode usually handles one new token per sequence, repeatedly reading model weights and cached attention state, so memory bandwidth and kernel launch overhead become more visible than raw arithmetic capacity.
IO-aware attention reduces attention memory traffic by tiling work so intermediate matrices remain in faster on-chip memory instead of repeatedly reaching high-bandwidth memory. This explains why attention implementation changes speed even when the mathematical result stays equivalent.
As the sequence length rises, more KV blocks must be traversed for full attention. Batch size can improve weight reuse, yet it also adds other sequences and their caches; a faster aggregate throughput number may coexist with worse inter-token latency for one household user.
Paging and Offload Turn Gradual Growth Into a Cliff
When the KV cache no longer fits its reserved VRAM, the runtime may evict blocks, reduce concurrency, reject the request, or fetch state from host memory. PCIe transfers and irregular access then add latency beyond the normal cost of a longer sequence.
bounded KV retention identifies important KV entries and discards less influential history under a bounded cache budget. Its results show that selective retention can limit memory growth, while also making output quality dependent on which past tokens the policy preserves.
The failure boundary is treating every slowdown as context length. Thermal throttling, another GPU workload, memory fragmentation, and scheduler preemption can produce the same curve. Hold model, prompt, batch, clocks, and concurrent services constant before attributing the slope to KV growth.
Plot Inter-Token Latency Against Retained Context
Run the same generation at 1K, 4K, 8K, 16K, and the largest supported context using identical sampling and output length. Record KV-cache bytes, free VRAM, attention kernel time, host transfers, batch occupancy, median ITL, p95 ITL, and tokens per second.
Use KV-cache growth to calculate expected KV growth, then repeat with a shorter retained window, a lower KV precision, and no concurrent requests. Mark the first length where paging, eviction, or a latency step appears instead of fitting one average line across the whole range.
Choose an operational context limit below the measured cliff and preserve extra headroom for other services. If compression or eviction changes answer quality on long-reference tests, publish that boundary rather than reporting only the restored token rate.
Why Does GPU Power Spike at the Start of a Local Inference Request?
See how GPU clock ramp, model prefill, kernel initialization, memory allocation, and sampling intervals create power spikes at inference start.
Why Does Vector Search Ranking Change While Multiple Index Segments Are Queried Together?
Learn how per-segment candidate limits, approximate graphs, score calibration, updates, and consolidation change private vector-search ranking.
Why Do Photo Deduplication Groups Split After Metadata Is Edited?
See how exact hashes, perceptual hashes, EXIF orientation, timestamps, thresholds, and pipeline versions cause private photo duplicate groups to split.
