Why Does Vector Search Ranking Change While Multiple Index Segments Are Queried Together?
Vector ranking can change across multiple segments because approximate candidate discovery happens separately before a global top-k merge compares incomplete result sets.
A private index may keep a large base segment plus smaller segments for recent document updates. The query runs against each structure, collects a limited number of candidates, and merges their scores. Segment size, graph or partition quality, search budget, deleted records, score normalization, and update distribution determine which neighbors survive, even when every vector uses the same embedding model.
Each Segment Produces a Locally Incomplete Candidate Set
Approximate nearest-neighbor search explores only part of an index. When the corpus is split, each segment receives its own beam width, probe count, or top-k limit, and the global merger can rank only candidates returned by those local searches.
multi-level vector search combines hierarchical graph indexing with log-structured levels for dynamic vector updates. Its design shows that search strategy must account for where vectors reside across levels instead of treating segmented storage as one exact distance scan.
A small recent segment may return weak candidates because it has a reserved quota, while a large base segment may omit a true neighbor because its local budget is too narrow. Increasing final top-k cannot recover an item that no segment exposed.
Partition Quality and Freshness Differ Across Segments
Older segments may have well-optimized graphs or clusters, while fresh segments contain insertions and tombstones accumulated under a different data distribution. Their recall, traversal cost, and candidate density can therefore differ before scores reach the global merge.
streaming graph updates maintains real-time graph updates while preserving high recall and avoiding periodic full rebuilds. The work demonstrates why dynamic vector search requires explicit update rules rather than assuming a static graph remains representative.
Duplicate document versions can also occupy different segments and compete in top-k. Version filters applied after ANN search waste local candidate slots; pushing active-version and permission constraints into candidate generation reduces this hidden ranking pressure.
Global Score Merge Cannot Correct Missing or Incomparable Evidence
Cosine, dot-product, or distance values are mathematically comparable only when vectors and normalization match. Quantization, segment-specific transformations, or inconsistent score conversion can make equal-looking numbers represent different approximation error. This distinction remains visible during later household testing.
local partition rebalancing replaces expensive global rebuild behavior with local partition rebalancing as data shifts. Its evaluation reports search-latency and accuracy fluctuations in rebuild-oriented approaches, illustrating why consolidation policy changes observable ranking behavior. The intermediate result must remain inspectable before automation follows.
The failure boundary is expecting deterministic ordering among near ties. Floating-point kernels, concurrent updates, and approximate traversal can swap neighbors with almost identical scores even in one segment. Treat ranking change as a defect only when recall, evidence quality, or version correctness crosses a defined tolerance.
Measure Segment Contribution Before Consolidation
Create a frozen query set with exact nearest neighbors and relevant document judgments. Run every segment alone and together while varying local top-k, graph beam width, probes, deletion filters, and the proportion of new vectors.
Contrast the results with the post-compaction behavior in post-compaction neighbors. Record which segment contributed each final candidate, local rank, raw distance, normalized score, candidates filtered later, global recall, rank correlation, latency, and version correctness. That boundary should be measured separately under realistic operating conditions.
Increase local budgets only where omitted relevant neighbors justify the cost. If segments use incompatible embeddings or score transforms, rebuild or separate them; a global merge cannot calibrate away a broken representation after candidate generation.
