Storage latency affects multi-user Jellyfin when several reads and small state operations wait long enough to erode client buffer margin.
A disk may advertise enough sequential throughput for several streams and still respond poorly when users seek, metadata loads, scans run, or another service writes to the same device. Multi-user behavior is therefore about queueing as well as megabytes per second. Use the same streams and background load in each run so changes in wait time and queue depth can be attributed to storage.
Sequential Throughput Is Only One Part of the Storage Budget
Long media reads are friendly to disks, but startup, seeking, posters, database work, and concurrent files introduce smaller and less predictable operations. Those waits can become visible before the aggregate byte rate reaches the device maximum.
Latency and throughput describe different storage properties, so one sequential benchmark cannot prove that multi-user response time will remain low.
Measure a sustained file read and a seek-heavy or metadata-heavy task separately, then repeat them while several sessions are active.
App Data and Media Can Contend Even When They Are Different Workloads
Keeping database and metadata on the same slow volume as bulk media can let small state reads wait behind long transfers. The result may look like a sluggish interface while playback itself stays mostly stable.
Random-access behavior differs from sequential I/O, which matters when small state reads and long media transfers share a device.
Move only the app-data path to a lower-latency tier for a controlled comparison. If browsing improves while media throughput is unchanged, the state path was part of the problem.
Concurrent Users Turn Small Delays Into Queueing
Several users can open different files, seek, and request artwork at nearly the same time. Another container or backup job can add writes, turning isolated acceptable latency into sustained queue depth.
Co-located workloads can create measurable resource interference even when each application passes alone.
Run the same number of streams with and without the competing writer. A NAS media-center topology is easier to tune when app state, media, and background jobs have explicit storage roles.
Upgrade Storage Only After the Queue Is Reproducible
Buying SSDs does not fix a client codec problem or a saturated network. Storage is the right target only when the same user-visible delay tracks storage wait and improves when the I/O load is removed.
The USE method makes saturation and errors explicit, which helps separate a genuinely busy storage resource from one that is merely active.
Capture a repeatable multi-user test, identify the device that queues, and change one placement variable at a time. Stop upgrading when queueing falls but the symptom remains elsewhere.
