Jellyfin bandwidth needs equal the peak bitrate of concurrent delivered streams plus protocol overhead and headroom; remote upload usually sets the stricter limit.
A home server may handle several local Direct Play sessions on gigabit Ethernet while the same mix fails remotely because upload capacity is shared with every stream and household task. Keep stream bitrates, client quality, path direction, and burst behavior separate when estimating a safe multi-user ceiling.
Start With Delivered Bitrate, Not File Size
Several users watch files with different source sizes and codecs. The relevant relationship is The network carries the delivered Direct Play, remux, or transcode bitrate, not the storage size of the source file.
The observable effect is Two files with similar duration can require very different bandwidth because encoded bitrate and quality differ. This is why the result changes with the stated condition. delivered bitrate
The boundary is specific: Averages hide peak scenes and segment bursts. The practical implication is Record per-session output bitrate and direction.
Add Protocol Overhead and Segment Bursts
Per-session bitrates are known. The relevant relationship is Segmented delivery and network protocols add headers and create short bursts above the media average.
The observable effect is A link can pass average throughput yet buffer when bursts exceed queue or upload margin. This is why the result changes with the stated condition. burst demand
The boundary is specific: Overhead varies with protocol, client, encryption, and segment size. The practical implication is Use a safety factor and measure the actual path when close to the limit.
Scale LAN and Remote Streams Separately
A conservative per-stream demand is available. The relevant relationship is Local sessions consume LAN and server egress; remote sessions also consume WAN upload, proxy, VPN, and sometimes relay capacity.
The observable effect is Local playback passes while remote sessions buffer at the upload limit. This is why the result changes with the stated condition. remote upload ceiling
The boundary is specific: A gigabit LAN does not increase a 20 Mbps upstream link. The practical implication is Calculate local aggregate and remote upload aggregate as separate totals.
Use Headroom Instead of a Bare Minimum
LAN and remote totals are calculated. The relevant relationship is Headroom absorbs bitrate peaks, TCP/TLS overhead, background traffic, and measurement error.
The observable effect is Streams remain stable when measured peak demand stays below the chosen link budget; buffering begins when the queue consumes the margin. This is why the result changes with the stated condition. simultaneous throughput test
The boundary is specific: No fixed percentage fits every ISP, VPN, or client. The practical implication is Reserve a documented margin and validate with simultaneous playback.
