Home NAS apps and bulk archives compete because one storage pool must schedule two workloads that value completely different kinds of performance.
Apps generate small, latency-sensitive reads, database commits, logs, and metadata changes. Archive jobs move long sequential streams and try to consume every available megabyte per second. When both use the same pool, they share device queues, cache, filesystem allocation, writeback, parity work, and recovery risk—not only disk capacity.
Small App I/O Waits Behind Long Archive Queues
An archive copy can keep many large requests outstanding. That raises throughput by keeping the storage pipeline busy, but an app request arriving behind the queue may wait far longer than its own service time. The dashboard then feels slow even though the transfer window reports excellent bandwidth.
This is a latency-versus-throughput conflict. Current PostgreSQL storage testing describes how WAL, checkpoints, index reads, and concurrent clients deepen the same queue in a storage queue saturation benchmark. A home NAS has fewer clients, but a backup or archive worker can create the same contention pattern beside an application database.
The Shared Pool Has More Contention Points Than Its Disks
Requests first meet the application cache, operating-system page cache, filesystem, block scheduler, virtual pool, and device firmware. Compression, encryption, checksums, and parity may add CPU or memory pressure before a request even reaches the drives. A pool can therefore show moderate disk utilization while an upper layer is already delaying work.
Linux exposes storage controls because bandwidth alone cannot protect an interactive service. The I/O latency controller guide explains how queue depth and artificial delay can be adjusted when a protected workload misses its target. The design itself confirms the underlying problem: peers on the same device can harm one another without sharing files.
| Workload | I/O pattern | Primary goal | Effect on its neighbor |
| App database | Small random reads and synchronous writes | Low response and commit latency | Creates frequent queue transitions |
| Logs and metadata | Small appends and updates | Fast durable acknowledgment | Adds writeback and journal pressure |
| Bulk archive | Large sequential reads or writes | Maximum throughput | Deepens queues and occupies cache |
| Integrity scan | Long read sweep | Complete coverage | Evicts hot pages and consumes bandwidth |
Cache Helps One Workload While Another Evicts It
App databases and indexes benefit when a small hot working set stays in memory. A one-time archive scan can fill the page cache with data that will not be reused, pushing those hot pages out. After the archive finishes, the app may remain slow while it reloads its working set from storage.
This is not a reason to disable caching universally. It is a reason to recognize that one eviction policy is serving incompatible goals. Research on workload-specific page-cache eviction found meaningful throughput and tail-latency gains when applications could use policies suited to their access patterns. In a smaller server, scheduling, rate limits, or separate datasets can reduce the same collision.
Writeback and Maintenance Extend the Competition
A copy progress bar can stop while its dirty pages continue flushing. At the same time, checksums, compression, snapshot changes, or parity updates may still occupy the pool. An app that begins after the visible transfer ends can therefore inherit a full writeback queue and experience a delayed stall.
Backup software documents this side effect directly: throttling backup I/O limits pressure on latency-sensitive database work. The broader backup resource analysis also shows why storage, network, and processing limits must be considered together rather than blaming a single disk.
Separation Changes Scheduling and Failure Boundaries
Separate app and archive pools give each workload its own queue, cache policy, free-space behavior, and maintenance window. Separate datasets on one pool can improve record-size, snapshot, and quota policy, but they still share physical devices. I/O controls can protect latency without moving data, yet they intentionally reduce the competing job's throughput when the pool is saturated.
The right boundary depends on the symptom. If only archive windows cause app pauses, scheduling or throttling may be enough. If databases, thumbnails, and containers remain latency-sensitive all day, physical separation provides stronger isolation. The kernel's latency-based workload protection makes the trade-off explicit: storage can be work-conserving until a protected service misses its target, then bulk work must yield.
Will a faster SSD pool stop apps and archives from competing?
It raises the saturation point but does not remove shared queues, cache eviction, writeback, or maintenance. Enough concurrent work can still increase app latency on fast storage.
Are separate datasets the same as separate pools?
No. Datasets can separate policies and accounting, but requests still reach the same underlying devices. Separate pools create a stronger physical I/O boundary.
Should archive jobs always be throttled?
Only when they overlap with latency-sensitive work or destabilize the server. Off-hours scheduling may preserve full throughput; continuous mixed use may justify explicit I/O limits.
