Home AI batching improves total throughput by combining compatible work, but each request may wait longer or share slower iterations with other users.
A single prompt can enter an idle accelerator immediately, while a family server often receives overlapping chats, document prompts, voice requests, and background jobs. The runtime may hold a request briefly to form a batch, add new sequences between decode iterations, or split long prefills into smaller chunks. Those choices keep more of the accelerator busy, yet they also change time to first token, inter-token delay, and fairness. The sections below explain where batching helps and when throughput gains stop improving the interactive experience.
Batching Converts Spare Accelerator Capacity Into Shared Work
One request may not use every parallel execution lane efficiently, especially during small matrix operations or short sequences. Combining several requests creates larger tensor operations that can use the accelerator more effectively.
Orca introduced iteration-level scheduling, allowing requests to join and leave between generation iterations instead of forcing one fixed batch to remain together until every sequence finishes.
The gain is measured as completed tokens or requests per unit of time. It does not guarantee that any one user receives a token sooner.
A Batch Window Adds Queue Time Before Compute Begins
A runtime that waits for more requests can build a larger, more efficient batch, but the earliest request pays that waiting time even when the accelerator was available.
The throughput-latency tradeoff becomes visible when larger batches improve device efficiency while extending queueing or iteration time.
Interactive home AI usually needs a short or adaptive batch window. Background embeddings can tolerate more waiting because their objective is completed work rather than conversational response.
Long Prefills Can Stall Short Decode Work
Prompt processing performs a large compute-heavy prefill, while active conversations return repeatedly for memory-bound decode steps. Mixing them in one batch can make a small interactive decode wait behind a long document prompt.
DistServe isolates prefill-decode interference because the two phases have different resource and latency characteristics.
Chunked prefill is a compromise: it divides a long prompt so decode requests can run between chunks, but the document takes more scheduling rounds to finish.
The best setting depends on whether the server prioritizes one long analysis job or several users already receiving streamed answers.
Mixed Sequence Lengths Make Every Batch Uneven
Requests differ in prompt length, output length, stop conditions, and model features. Some finish quickly while others remain active, so the batch composition changes continuously.
vLLM uses continuous batching with paged KV cache to admit new requests as capacity becomes available rather than waiting for a fixed batch boundary.
Even with efficient memory management, one very long response consumes decode slots and KV cache for many iterations. Batch size should therefore be expressed in token and memory budgets, not only request count.
Larger Batches Can Lower Per-User Token Rate
Total tokens per second may rise while each user receives a smaller share of decode iterations. A dashboard showing higher aggregate throughput can coexist with slower visible streaming.
ZimaSpace’s guide to family concurrency explains why one-user benchmarks do not predict the latency of several overlapping conversations.
Measure time to first token, time between tokens, and completion time per request alongside aggregate throughput. Otherwise batching can be tuned for a metric users never experience directly.
Set Different Batch Policies for Interactive and Background Work
Reserve short queue windows, bounded concurrency, and higher priority for voice and chat. Allow larger batches and lower priority for embeddings, indexing, summaries, and offline transformations.
Fair LLM serving research uses token-aware fairness so one request’s long input or output does not occupy a disproportionate share indefinitely.
Test at representative family load, not only at maximum batch size. The useful configuration is the highest throughput that still meets the first-token and streaming-latency targets of the interactive path.
When one accelerator cannot satisfy both classes, separate workers or schedules may be simpler than one universal batching policy.
Does batching always increase latency?
No. Efficient batching can shorten total queue drain time and prevent overload, but waiting for a batch and sharing longer iterations can increase an individual request’s latency.
Is batch size the number of users?
Not exactly. Runtimes may budget by active sequences, tokens, KV blocks, or total work, and one user can generate several concurrent requests.
Should voice requests be batched with embeddings?
Usually not under the same latency policy. Voice is interactive, while embedding jobs can wait and use larger batches during spare capacity.
