Complete vector deletion requires removing every reachable derivative of a source, not merely hiding its identifier from normal similarity queries.
Deleting a private PDF may remove its document row while embeddings remain inside an HNSW file, cache, replica, snapshot, or evaluation set. A reliable system first maps the source to every chunk and derived artifact. It then blocks retrieval immediately, rewrites physical structures, invalidates caches, addresses backups and learned state, and records verifiable completion without retaining the sensitive content itself.
Lineage Identifies Every Object the Source Created
Ingestion assigns a stable source and version ID, then records chunk IDs, embedding IDs, metadata rows, lexical entries, thumbnails, summaries, cache keys, evaluation examples, and replica locations. Deletion begins from this graph rather than a filename search.
Research on recoverable deleted vectors shows that soft-deleted embeddings can remain physically recoverable from HNSW index files and proposes encryption-key rotation as a mitigation. The finding demonstrates why an API-level absence is not equivalent to erasure.
Shared chunks and deduplicated blobs need reference counts or ownership edges. Removing one user’s source must not erase a legitimately shared object, yet it must remove the deleted source’s permission, provenance, and retrievable association. This distinction remains visible during later household testing.
Tombstones Provide Immediate Exclusion Before Physical Rewrite
A deletion transaction marks every derived record inactive and advances an index generation so new queries filter it consistently across vector, lexical, metadata, and reranking stages. Caches include generation or deletion state in their keys.
streaming ANN deletions supports streaming additions, updates, and deletions in a graph-based approximate nearest-neighbor index. Its design illustrates why dynamic search needs explicit maintenance beyond building a static index once. The intermediate result must remain inspectable before automation follows.
Tombstones protect the online path but leave bytes until compaction rebuilds affected segments or the whole index. The new generation must be verified and atomically published before old files, temporary workspaces, and snapshots are reclaimed.
Caches, Backups, and Learned State Define the Hard Boundary
Deletion jobs must purge result caches, prompt caches, replicas, search exports, analytics tables, logs that copied content, and local temporary files. Backup policy may expire encrypted snapshots later rather than mutate immutable media immediately. That boundary should be measured separately under realistic operating conditions.
machine unlearning limits formalizes machine unlearning as removing a training point’s influence without full retraining and shows practical limitations of approximate approaches. This matters when deleted vector content also entered a learned reranker or adapter.
The failure boundary is promising deletion from artifacts the system cannot enumerate or rewrite. A signed deletion record can prove which generations and keys were removed, but not that an undocumented export vanished. Unknown derivatives must remain a visible compliance failure, not a silent success.
Run a Deletion Recovery Challenge
Ingest a unique canary phrase and image into a test source, then locate every chunk, vector, metadata row, cache entry, replica, backup generation, summary, log copy, and learned dataset edge before requesting deletion. The practical consequence appears when several sources compete for limited context.
Apply the tombstone boundary in vector tombstone boundary, compact the index, expire or cryptographically erase covered backups, and query through vector, lexical, metadata, cache, direct-file, and restored-snapshot paths. Inspect raw index storage for the canary.
Pass only when current systems cannot retrieve or reconstruct the source and the deletion record names every completed and pending artifact class. If a backup must remain, isolate its key and publish the exact expiration or legal-hold boundary.
Why Does GPU Power Spike at the Start of a Local Inference Request?
See how GPU clock ramp, model prefill, kernel initialization, memory allocation, and sampling intervals create power spikes at inference start.
Why Does Vector Search Ranking Change While Multiple Index Segments Are Queried Together?
Learn how per-segment candidate limits, approximate graphs, score calibration, updates, and consolidation change private vector-search ranking.
Why Do Photo Deduplication Groups Split After Metadata Is Edited?
See how exact hashes, perceptual hashes, EXIF orientation, timestamps, thresholds, and pipeline versions cause private photo duplicate groups to split.
