What Causes False Package-Delivery Alerts in a Home NVR?
False package-delivery alerts usually arise when object classification, tracking, and delivery-zone logic agree on the wrong visual event.
A doorbell camera does not observe delivery as one fact. It detects a box-like object, estimates its location, tracks whether it becomes stationary, associates nearby people, and applies a time or zone rule. Shadows, planters, bags, partial views, compression noise, and track loss can satisfy different stages, producing an alert even when no parcel remains.
Look-Alike Objects and Image Conditions Trigger the Classifier
A package detector learns visual patterns from boxes, bags, labels, edges, and context. Low light, rain, infrared illumination, glare, insects, and compression reduce detail, while mats, planters, toys, and shadows can resemble training examples. This distinction remains visible during later household testing.
Research on occlusion and detection noise reports that occlusion and noise degrade surveillance detection. The signature is low or unstable package confidence concentrated in particular lighting, weather, or frame regions. The intermediate result must remain inspectable before automation follows.
If the raw detector never labels a package but an alert still appears, the classifier is not the cause. Inspect per-frame labels before changing confidence thresholds or retraining data. That boundary should be measured separately under realistic operating conditions.
Perspective and Tracking Turn Brief Shapes Into Persistent Objects
Wide-angle views stretch edge objects and hide depth. A person carrying a bag can occlude it, then reveal a box-like region that receives a new track ID; a shadow or moved object may remain classified after the person leaves.
A study of persistent-object tracking uses background modeling and surrounding-area comparison to distinguish abandoned from removed objects. It demonstrates why persistence requires temporal evidence beyond one detection. The practical consequence appears when several sources compete for limited context.
Repeated alerts with changing track IDs indicate association or occlusion failure, while one stable false track points to classification or background change. The distinction prevents global threshold changes from masking a tracker defect. This dependency should remain explicit in the final interface.
Zone and Event Rules Can Convert Correct Detections Into Wrong Delivery Claims
A correct package detection outside the doorstep can cross a polygon because of box jitter, lens correction, or coordinate mismatch. Delivery logic may also alert on object appearance without requiring a person transition, dwell time, or stable post-delivery state.
An explanation of package-detection event logic separates motion, person, and package detection in a doorbell workflow. The chain shows that package classification alone does not prove a completed delivery. The result must therefore be checked against the original evidence.
The failure boundary is a real parcel briefly hidden after delivery. An alert that seems false from one thumbnail may be correct in the preceding track. Review the event window and final zone state, not only the trigger frame.
Label the Detector, Tracker, and Delivery Rule Separately
Collect true deliveries and false alerts across daylight, infrared, rain, shadows, and partial occlusion. Record raw label confidence, box coordinates, zone overlap, track ID, dwell time, person association, lens-correction state, trigger rule, and final parcel presence.
Compare tracking behavior with home NVR tracking. Replay the same clips while changing only package threshold, track persistence, zone margin, or delivery rule so improvements can be attributed to one layer. This distinction remains visible during later household testing.
Classify each failure before tuning: visual false positive, track fragmentation, coordinate error, or event-rule error. Preserve recall for small real parcels by fixing the responsible stage instead of raising one global confidence threshold. The intermediate result must remain inspectable before automation follows.
