Yes, Jellyfin can work reliably behind CGNAT or double NAT, but only when remote clients use a reachable tunnel, relay, or routable address path.
Local playback is unaffected because clients and server communicate inside the home network. Remote access fails when an upstream translator owns the public address and the user cannot create an inbound mapping through every NAT layer. A mesh VPN can establish an outbound-coordinated path, while a VPS relay provides a stable rendezvous at the cost of another bandwidth and latency dependency.
Why Ordinary Port Forwarding Stops at the Wrong Router
Port forwarding works only when the configured router receives traffic addressed to a public IP it controls. Under double NAT, another router sits upstream; under CGNAT, the provider shares a public address across customers and controls the upstream mapping.
Self-hosters note that DDNS cannot bypass CGNAT because a hostname can identify an address without granting an inbound route to the private server. Discovery and reachability are separate problems.
Jellyfin itself is not malfunctioning in this condition. The failed component is the unsolicited inbound path, which is why local sessions remain normal while external connection attempts time out.
Mesh VPNs Create an Outbound-Coordinated Private Path
A mesh VPN gives authenticated devices private addresses and attempts NAT traversal using outbound traffic from both ends. When direct traversal succeeds, media can flow peer to peer without exposing Jellyfinโs port to the public internet.
A current remote-streaming account describes Tailscale as mostly CGNAT-proof while acknowledging that severe NAT combinations may still require a relay. Reliability depends on the path actually selected, not the VPN label.
This model fits personal devices and small trusted groups because every client joins the private network. It is less convenient for arbitrary browser users who cannot install or authenticate a VPN client.
A VPS Relay Trades Reachability for Another Bottleneck
A public VPS can accept inbound connections and forward them through an outbound tunnel to the home server. This works even when direct traversal fails, but every media byte may cross the VPS network, making its egress, region, CPU, and tunnel stability part of playback.
A detailed VPS relay design uses WireGuard or Headscale-style routing to create that public rendezvous. The method solves addressability, not inadequate home upload.
A relay near neither endpoint may add latency, and metered egress can make high-bitrate streaming expensive. It should be evaluated as infrastructure rather than assumed to be a transparent substitute for a public IP.
Reliability Verdict and Test Criteria
The conditional โyesโ fails when all available paths relay through a slow region, the home upstream cannot sustain the delivered bitrate, or client onboarding is too complex for the intended users. NAT traversal success alone does not prove playback reliability.
The limited-upload comparison explains why a reachable direct-play path can still buffer. Lowering bitrate through transcoding may improve delivery while increasing server compute demand. A separate field report also supports using remote path verification instead of assuming the visible symptom identifies the bottleneck.
Run three tests before declaring success: verify the connection path is direct or record the relay region; stream at the highest normal bitrate for at least 30 minutes; and repeat after both endpoints change networks. Accept the design only if throughput, reconnection, and access control remain stable in all three.
