Agent retries multiply after reconnection when several clients, workflow layers, and queued operations all interpret the same outage as permission to try again.
A home agent may call a NAS API, smart-home bridge, browser tool, and message queue during one plan. When Wi-Fi or the router returns, the client library, tool wrapper, workflow engine, and user interface can each release a retry. Uncertain completion, synchronized timers, buffered events, and missing idempotency keys turn one interrupted step into several apparently valid attempts.
Independent Retry Layers Multiply One Failed Operation
An agent request can cross a gateway, planner, tool adapter, HTTP library, and device service. If three layers each allow three attempts, the downstream operation can see far more than three calls because retry budgets compose multiplicatively rather than additively.
layered retry amplification explains how retries add load to an already struggling dependency and why exponential backoff, jitter, timeouts, and a single retry point reduce amplification. The guidance maps directly to agent stacks with hidden client-library retries.
A reconnect often clears the transport error without clearing pending timers or queue deliveries. Each layer wakes with incomplete knowledge of the others, so central request IDs and one owned retry budget are more reliable than configuring similar policies independently.
An Interrupted Connection Hides Whether the Tool Succeeded
A response can be lost after the server completed the action but before the agent received confirmation. Retrying a read is usually harmless; retrying a door unlock, notification, file move, or purchase-like action can repeat a real side effect.
idempotent request identifiers uses caller-provided idempotency identifiers so a service can recognize repeated requests and return the original result instead of performing the action twice. This separates safe recovery from merely sending the same payload again.
The workflow must persist operation ID, target, arguments, attempt state, and acknowledged result across the network gap. Generating a new tool-call ID after reconnect defeats deduplication because the downstream service sees a new operation rather than a continuation.
Synchronized Recovery Can Become a Retry Storm
Many devices detect the same restored network edge and reconnect within seconds. Without randomized delay and admission control, their queued agent requests, subscriptions, and health checks create a load spike precisely when services are rebuilding state.
The recovery load shedding chapter describes cascading failure when retries, resource exhaustion, and recovery traffic reinforce each other. It recommends limiting work, shedding excess load, and testing overload behavior instead of assuming the recovered dependency can accept every backlog immediately.
The failure boundary is using backoff as a substitute for operation safety. Jitter spreads calls but cannot prevent duplicate side effects, and idempotency cannot make an obsolete action desirable. Expired intent, current authorization, and target state must be revalidated before replay.
Run a Reconnect Replay Challenge
Start a ten-step agent workflow containing reads, idempotent writes, and one non-repeatable action. Disconnect the network before send, after send, during execution, and after completion but before acknowledgment, then reconnect several clients simultaneously. This distinction remains visible during later household testing.
Apply the side-effect boundary in non-repeatable agent actions. Count attempts at every layer, unique operation IDs, duplicated effects, queue age, backoff distribution, stale actions rejected, and time until the service returns to normal load. The intermediate result must remain inspectable before automation follows.
Pass only when one logical operation produces at most one committed side effect and retry work remains inside a global budget. If the agent cannot determine the prior outcome, require reconciliation or human approval instead of guessing that another attempt is safe.
Why Does GPU Power Spike at the Start of a Local Inference Request?
See how GPU clock ramp, model prefill, kernel initialization, memory allocation, and sampling intervals create power spikes at inference start.
Why Does Vector Search Ranking Change While Multiple Index Segments Are Queried Together?
Learn how per-segment candidate limits, approximate graphs, score calibration, updates, and consolidation change private vector-search ranking.
Why Do Photo Deduplication Groups Split After Metadata Is Edited?
See how exact hashes, perceptual hashes, EXIF orientation, timestamps, thresholds, and pipeline versions cause private photo duplicate groups to split.
