After power loss, a RAID array may stay inactive because its metadata was detected but the system could not safely start it with the members and state available.
The term “inactive” most directly describes Linux md arrays, although other storage stacks have similar import or activation failures. Check device discovery, member metadata, dirty or degraded state, startup configuration, and power-path faults before attempting a forced start.
Understand What Inactive Means in Linux RAID
An inactive md array can have devices and some configuration attached while refusing normal I/O. It is not the same as a healthy array that is merely unmounted, and mounting commands cannot repair the missing activation step.
An inactive array state as configured but not active, with I/O returning errors. This state lets the system continue discovering or reconfiguring members without pretending the array is ready.
Inspect /proc/mdstat, the array detail, and every member superblock before changing state. The goal is to learn why activation stopped, not to turn “inactive” into “active” without confirming the member set.
One or More Members May Not Have Reappeared
A sudden outage can expose a marginal power lead, backplane, SATA cable, controller port, or drive that fails to initialize on the next boot. The array then sees fewer members than its metadata says should be present.
mdadm normally compares the available non-spare devices with the expected active count before starting. An array can remain partially assembled when expected devices are missing, even though enough metadata exists to create an md device entry.
Power down safely if hardware inspection is required, then check connectors, spin-up, controller detection, serial numbers, and SMART data. Restore missing connectivity before choosing degraded startup, because a transient path fault may be easier and safer to fix than reconstructing the array.
An Unclean Shutdown Can Leave the Array Dirty
Power loss can interrupt writes before every member and parity block reaches a consistent state. The array metadata then records that a resync, bitmap replay, journal replay, or other consistency action is required on the next start.
Linux md supports different consistency policies after an unexpected shutdown, including full resync, write-intent bitmap, journal, and partial parity log. The consistency policy determines how much work is needed before redundancy can again be trusted.
A dirty but complete array may start and resync normally. A dirty array that is also degraded requires much more caution, because missing data and uncertain parity can remove the information needed for reliable reconstruction.
Dirty and Degraded Parity May Trigger a Safety Refusal
RAID 5 or RAID 6 can be refused at startup when it is both dirty and missing a member. The refusal protects against a state where parity may be stale and the absent data cannot be checked against another copy.
A dirty-degraded startup guard exists because forcing that combination can create undetectable corruption. Therefore, forced degraded startup as an explicit administrator decision rather than normal boot behavior.
Do not bypass this guard until the missing member, backup status, and write history are understood. Restore the device path or clone failing members first; if recovery must continue, minimize writes and verify recovered files independently.
Boot-Time Discovery and Configuration Can Be Incomplete
The disks may all be healthy while startup still misses the array because device discovery finishes after the assembly attempt, the configuration lacks the array identity, or the initramfs contains stale RAID settings.
A RAID configuration file can describe devices and arrays so startup tools know what to scan and assemble. Accurate array configuration records are especially important when automatic discovery cannot reliably infer the intended set.
Compare the live member UUIDs with the installed configuration and boot environment. Correct stale configuration only after confirming the actual array identity; generating a new config from an incomplete member set can make the next boot consistently wrong.
External Metadata May Need Its Userspace Manager
Some arrays use external metadata formats managed by userspace rather than entirely by the kernel. After an abrupt outage, the container or monitor process may not have completed the acknowledgements needed for member state changes.
Externally managed metadata can suspend activity until userspace acknowledges an event. An inactive component set may therefore reflect a missing management step rather than failed data disks.
Identify the metadata format before applying generic md commands. Firmware-assisted or container formats may require the appropriate monitor, controller utility, or NAS recovery workflow so that metadata updates occur in the correct order.
Recover in the Lowest-Risk Order
Begin with read-only evidence: list block devices by stable ID, map serials to slots, examine member metadata, review the previous boot’s logs, and check whether every expected disk is present. Do not create a new array or zero superblocks.
Attempt the platform’s normal assembly after connectivity and configuration are corrected. Use read-only or read-auto modes when supported, and reserve degraded run or force options for cases where the exact missing member and consistency risk are understood.
After recovery, complete any resync or scrub, confirm backups, and investigate the outage path. A UPS, reliable power and cabling, current RAID configuration, stable device IDs, and alerting reduce the chance that the next power event presents the same inactive state.
| Inactive-state clue | Likely explanation | First check |
| Expected member absent | Drive or path did not initialize | Serials, power, cable, controller detection |
| All members present; array dirty | Interrupted writes require consistency work | Array status and consistency policy |
| Dirty and degraded parity | Automatic start blocked for safety | Restore member or clone before force |
| Members visible after boot only | Discovery or config timing problem | mdadm.conf and initramfs state |
How to Schedule a Coding Agent in Open WebUI on a Home Server
Set up a report-only coding agent automation in Open WebUI, select its terminal and workspace, and verify permissions, logs, and failure recovery.
