A NAS volume that turns read-only after an unsafe shutdown is usually protecting damaged metadata or reacting to storage I/O errorsโnot simply changing permissions.
If your shares still open but uploads, app databases, or media scans fail, resist the urge to force a read-write remount. The safest path is to preserve readable data, identify whether the block occurs at the share, filesystem, pool, or drive layer, and then use the repair method built for that storage stack.
First, Freeze Changes and Protect Readable Data
Treat read-only mode as a warning, not the fault itself. Pause sync jobs, containers, media indexing, downloads, and backup rotation so repeated retries do not obscure the original errors or stress a weak drive.
If important files remain readable, copy the most irreplaceable data to separate healthy storage before attempting repair. In one reported case, a read-only filesystem after a power outage returned after temporary repair attempts, showing why recurrence should be treated as unresolved.
- Pause services and client writes.
- Copy critical readable files elsewhere.
- Save storage-status screens and event logs.
- Record the pool layout and filesystem type.
- Begin checks without changing the array.
This order preserves both data and evidence. A reboot, forced assembly, repair, or remount can change the state you need to diagnose, so do not make one the first experiment.
What Actually Became Read-Only?
A failed upload does not prove the entire volume is read-only. A share, dataset, application directory, filesystem, storage pool, or physical device can block writes, and each layer needs a different fix.
Compare the failure from the NAS dashboard and from more than one client. The pattern below separates an access problem from a storage-protection event before you touch the disks or run a filesystem repair tool.
| Visible result | Likely layer | First safe check | Next action |
| One user cannot save, but another can | Account, ACL, or share permission | Compare user and group access | Correct access without repairing storage |
| One app or share fails while others write | Dataset, share, or application | Check that service's path and quota | Fix the isolated service layer |
| Every local and network write fails | Filesystem or volume | Confirm mount and volume state | Read logs before repair |
| Pool is degraded, suspended, or missing a device | RAID, pool, controller, or drive | Inspect member and error status | Stabilize the lower layer first |
If the NAS itself can create a test file but clients cannot, stay above the filesystem layer. If local writes also fail and the dashboard reports a read-only volume, continue with logs and pool health.
Read the Logs Before They Disappear
The first useful evidence is the event immediately before the volume became read-only. Review the system event log, storage-manager history, and kernel messages for the affected boot and the boot before it.
Some filesystems stop writes after detecting an error. In a case where a system suddenly went read-only, responders warned that new journal entries might not reach disk. Capture current kernel messages before rebooting whenever possible.
Save entries containing filesystem errors, journal aborts, checksum failures, device resets, timeouts, or read/write I/O errors. Record the device identifier and timestamp; repeated faults on the same member matter more than a generic โunclean shutdownโ notice.
Check the Pool or RAID Before the Filesystem
A filesystem sits on top of a pool, RAID set, logical volume, controller, and drives. If that lower layer is incomplete or unstable, filesystem repair can read inconsistent data or add load at the worst time.
For Linux software RAID, a dirty and degraded RAID 5 or RAID 6 array can carry an undetectable-corruption risk; the dirty, degraded array rule explains why automatic startup may be refused. Do not force assembly merely to clear a dashboard warning.
Check whether every member is present, whether a rebuild or resilver is active, and whether read, write, or checksum counters are rising. Record the member order and exact status without forcing assembly, replacing a disk, or starting a scrub. Stabilize the pool before checking the filesystem above it.
Check Drive Health, Cabling, and Power
Review every HDD, SSD, and NVMe device, including cache and metadata devices. Use the NAS health page to inspect SMART or NVMe health, recent self-tests, temperatures, media errors, and whether any device disappeared after the shutdown.
Do not rely on one green โhealthyโ badge. Correlate health results with kernel I/O errors, device resets, and the time the volume changed state. A passing summary does not explain a fault recorded elsewhere in the storage path.
Power the NAS down cleanly before reseating an accessible data or power connection, and change only one variable at a time. If several drives vanish together or errors follow a port rather than a disk, stop blaming individual drives and investigate the shared path.
Match the Repair Tool to the Filesystem
Ext4 and XFS: Repair Offline with Native Tools
Ext4 uses e2fsck, while XFS uses xfs_repair; neither should be aimed at a mounted volume or an uncertain device path. If the NAS cannot unmount the volume safely, use its maintenance workflow or a supported recovery environment.
A practical filesystem troubleshooting guide separates ext-family checks from XFS repair and places checks on an unmounted filesystem. Preserve a backup, identify the exact device, and start with the filesystem's native non-modifying mode when one is available.
Btrfs: Prefer Read-Only Checks and Expert Guidance
Btrfs separates scrub, structural checking, and repair. A scrub validates checksums and may use a good replica, while a structural check examines filesystem objects; neither should be treated as a generic switch that makes a damaged volume writable.
The official Btrfs check warning recommends unmounting first and explicitly cautions against using --repair without experienced guidance. Start with readable-data recovery and a non-modifying check, then follow the NAS vendor's documented recovery path.
ZFS: Stabilize the Pool Before Scrubbing
ZFS does not use a traditional fsck workflow. Read pool status first, preserve critical files, and resolve missing or faulted devices before adding the sustained I/O load of a scrub.
An OpenZFS pool scrub verifies block checksums and may repair from good replicas, but it is I/O-intensive and cannot invent a valid copy when redundancy is exhausted. Start it only after the pool is stable and critical data is protected.
When to Restore Writesโand When to Stop
Restore read-write service only after the pool is stable, the relevant offline check or native recovery completes, and fresh logs show no recurring I/O or metadata error. Then start one low-risk service and test a disposable file before resuming normal workloads.
If a forced remount fails or the volume immediately returns to read-only, accept that result as new evidence. Repeating the same command does not remove the cause; it only increases writes, heat, and recovery pressure.
Stop DIY repair when multiple pool members are missing, error counters keep rising, a drive clicks or repeatedly disconnects, checksums are unrecoverable, or the only readable copy is critical. Preserve logs and device order, keep the system powered down if hardware is unstable, and contact qualified storage recovery or platform support.
Prevent the Next Unsafe Shutdown
Use a UPS that can signal the NAS to shut down automatically, not just a battery with unused communication ports. This NAS power-outage checklist covers shutdown communication, post-outage checks, and why stable power matters during recovery.
Keep recovery copies outside the live pool. RAID can preserve availability after some drive failures, but it follows live corruption and does not provide an earlier clean version; the distinction between RAID and backup recovery matters most when a repair does not succeed.
Finally, enable disk, pool, and UPS alerts; schedule checks or scrubs appropriate to the filesystem; and test a small restore periodically. A successful boot is useful, but a verified recovery path is what turns the next shutdown from a crisis into a controlled event.
Can a reboot fix a read-only NAS volume?
A reboot can complete journal replay or clear a temporary service state, but it is not proof that the storage is healthy. Check saved logs and pool status first, especially if the volume has already changed to read-only more than once.
Can I force a read-write remount long enough to copy files?
Prefer copying from the existing read-only state. A forced writable mount can trigger new metadata updates and may fail immediately if the kernel still sees errors. Use it only within a filesystem-specific recovery plan after protecting the best available copy.
What if SMART passes but the logs still show I/O errors?
Treat the logs as unresolved evidence. The fault may involve an interface, cable, backplane, controller, power path, or a drive problem not summarized by the overall SMART result. Isolate one component at a time and stop if errors continue.
The safest first check is the one that preserves options: protect readable data, identify the blocked layer, and let verified evidenceโnot a forced remountโchoose the next action.
