Buy enough RAM for the full home-server workload with headroom; Plex does not scale by a simple number of gigabytes per user or terabyte.
Start With the Dedicated Plex Baseline
A dedicated server that mostly Direct Plays can have modest active memory demand, while a multi-app host needs room for the OS, containers, filesystem cache, and overlapping jobs.
The right baseline is the measured peak resident and cache pressure during normal use, checked with memory saturation signals rather than a fixed percentage target.
Record memory use during the busiest playback hour, a library scan, and a restart. Add headroom only after identifying whether the server actually approaches memory pressure.
Library Growth Can Increase Cache Value Without Requiring Full In-Memory State
More metadata and database pages create a larger working set, but unused state does not have to reside in RAM permanently. The operating system can cache frequently reused data opportunistically.
More RAM can reduce repeated storage access when frequently reused pages stay cached without requiring the entire Plex database to be allocated in application memory.
If navigation is slow after restart but fast when warm, extra RAM may improve cache persistence. If it stays slow while memory is plentiful, investigate storage or query behavior instead.
More RAM Does Not Guarantee Faster Plex Queries
A large free-memory pool cannot fix a query path that is CPU-, database-, or storage-limited. Slow search can persist even when the host has ample RAM, so memory capacity should not be treated as the default explanation.
A modern host can still hit high CPU during Plex search with ample memory, so additional RAM should be justified by pressure, swapping, or cache churn rather than query latency alone.
Increase RAM only when swap, reclaim, cache churn, or companion services prove memory is constrained. Otherwise keep the purchase focused on the measured limiter.
Buy for the Whole Host, Not Plex in Isolation
Downloaders, indexers, backup tools, VMs, and local AI can consume more memory than Plex itself. The safe tier is the one that supports the combined peak without routine swapping.
List every always-on service and peak overlap in the home media-server workload before choosing the DIMM configuration.
Prefer an upgrade path with spare slots when growth is uncertain. Paying for unused 32GB or 64GB today is less useful than ensuring the platform can add memory when a measured workload creates the need.
Buying Guide
How to Choose a Home Server for Jellyfin and Kodi
Kodi can reduce Jellyfin transcode demand when clients Direct Play well, so size the server from fallback conversion, storage, network, and shared services.
How to Choose SSD, HDD, and Backup Capacity for Jellyfin
Size Jellyfin storage by role: SSD for active app data and scratch, HDD for media capacity, and independent backup space for retained recovery points.
Before Buying a Jellyfin Server: Can Your Old PC Pass the Workload?
Reuse an old PC only after it passes the real Jellyfin workload, power, noise, storage, and recovery checks a new server would need to...
