A NAS running all year uses electricity according to its average wall-power draw. The calculation is simple: a 10W system uses 87.6kWh per year, while a 50W system uses 438kWh. Your annual bill then depends on the electricity rate charged by your local utility.
There is no honest universal “NAS costs $X per year” figure. Drive count, drive model, SSDs, CPU platform, cooling, network hardware, backup jobs, media transcoding, containers, and local AI services can all change the average. The most useful number is the cumulative kWh measured at your own wall outlet.
How Do You Calculate NAS Electricity Use Per Year?
Use this formula to estimate annual electricity use:
Annual kWh = (Average Watts × 24 × 365) ÷ 1000
Then calculate the annual electricity cost:
Annual Cost = Annual kWh × Your Local Electricity Rate per kWh
For example, a NAS averaging 30W uses (30 × 24 × 365) ÷ 1000 = 262.8kWh each year. If your electricity rate is $0.20 per kWh, its estimated annual electricity cost is 262.8 × $0.20 = $52.56.
Why Can Two Similar NAS Systems Use Very Different Power?
The number and type of drives are major variables, but they are not the whole system. Motherboard power, CPU platform, memory, fans, power-supply efficiency, USB devices, network adapters, and the operating system all contribute to wall-power draw.
Drive specifications also vary significantly by capacity and model. One Seagate NAS HDD data sheet, for example, lists 8TB and 6TB models at 9.0W average operating power and 7.2W idle average, while a 4TB model in the same family is listed at 4.8W operating and 3.95W idle. See the NAS HDD operating and idle power specifications for why “four drives” is not enough information to estimate a NAS bill.
Workload changes the average too. A file archive may spend much of its time near idle, while continuous camera recording, media transcoding, large backups, virtual machines, Docker apps, or local AI indexing can keep CPUs, disks, and fans active for longer periods.
For the component-level explanation of 24/7 NAS power, see the factors behind 24/7 NAS power draw.
What Annual kWh Range Should You Expect?
The table below converts average wall power into annual electricity use. These are calculation examples, not claims about any particular NAS model.
| Measured average wall power | Annual electricity use | Annual cost at $0.15/kWh | Annual cost at $0.30/kWh |
| 10W | 87.6kWh | $13.14 | $26.28 |
| 25W | 219.0kWh | $32.85 | $65.70 |
| 50W | 438.0kWh | $65.70 | $131.40 |
| 100W | 876.0kWh | $131.40 | $262.80 |
A storage-focused, right-sized NAS may average toward the lower end of this table. A multi-drive DIY system, older desktop, server-grade platform, dedicated GPU, or always-on workload can average far higher. The relevant number is the average over real use—not the lowest idle reading or a brief peak during a benchmark.
Use your bill’s actual rate, including any time-of-use pricing if applicable. The same 219kWh annual load has a very different cost in regions with $0.10/kWh electricity versus $0.40/kWh electricity.
How Can You Measure Your NAS Accurately?
Use a wall-power meter or a smart plug that reports cumulative kWh. Connect it between the outlet and the NAS power supply, then leave it in place long enough to include ordinary idle time, file access, backups, media use, and any regular scheduled jobs.
Record at least two values: instantaneous watts for troubleshooting and cumulative kWh for annual cost. A 24-hour reading can be useful, but a week or longer is better when the NAS has weekly backups, irregular media use, or periods of heavy activity.
Do not multiply a CPU TDP by 8,760 hours. TDP is a processor thermal-design figure, not a measurement of the NAS’s total wall power. Likewise, do not add only the idle wattage printed on each drive specification; that excludes the rest of the system and misses real workload behavior.
When using timers or smart plugs, verify the plug’s current rating and whether an unexpected shutdown could interrupt writes, backups, or RAID activity. The plug-load monitoring guide is a useful reminder to match timers and plugs to the equipment’s electrical load.
How Much Does Your Local Electricity Rate Change the Cost?
Electricity rate is the second half of the calculation. Two households with the same 40W NAS both use 350.4kWh per year, but the annual cost is $35.04 at $0.10/kWh, $70.08 at $0.20/kWh, and $140.16 at $0.40/kWh.
Check whether your bill has one flat rate or separate peak, off-peak, delivery, and supply charges. For a simple estimate, use the effective total rate shown on your bill. For a more precise estimate, measure when high-power NAS jobs run and apply the appropriate time-of-use rate.
| Your input | Example |
| Average measured watts | 35W |
| Annual kWh | (35 × 24 × 365) ÷ 1000 = 306.6kWh |
| Local electricity rate | $0.22/kWh |
| Estimated annual cost | 306.6 × $0.22 = $67.45 |
How Can You Lower NAS Power Use Without Hurting Reliability?
Start by right-sizing the system. A low-power file server does not need the same CPU, GPU, cooling, or networking as a machine that continuously transcodes video, runs virtual machines, records cameras, and hosts AI services. Removing an unnecessary always-on workload can save more energy than tuning a single BIOS option.
Review recurring tasks such as media scans, backups, thumbnail generation, downloads, indexing, and container jobs. Schedule nonurgent work for predictable periods and avoid letting duplicate services repeatedly scan the same files.
Drive spindown can reduce power for a genuinely inactive archive, but it is not automatically right for every NAS. Frequent access, backup jobs, applications, camera recording, or a busy storage pool can repeatedly wake drives and reduce the practical benefit. Test the behavior before relying on it.
Scheduled shutdown can save electricity only when the NAS does not need to be available. Do not schedule power-off periods that interrupt backup windows, remote users, automatic photo uploads, RAID maintenance, or critical services. If you use a power-saving schedule, pair it with safe shutdown behavior and review keeping power-saving schedules safe during outages.
Which Hardware Path Fits a Power-Conscious NAS?
For basic storage, prioritize measured idle power, drive count, quiet cooling, and the services you truly need. For media, Docker, backups, cameras, or AI workloads, choose enough capacity for the work first, then measure the full system to find the largest energy contributors.
Be especially careful with old desktop and server hardware. Reuse can lower the purchase cost, but the long-term electricity, heat, and noise may outweigh that saving if the system stays on continuously. Compare its real wall-power average with a more compact alternative before committing it to 24/7 duty.
A compact platform such as the ZimaBoard 2 can be a fit for a small personal server or DIY NAS because it uses an Intel N150 platform with a stated 10W processor TDP, dual 2.5GbE, SATA, PCIe, and USB expansion. That 10W figure is not the annual NAS power draw: drives, memory, attached devices, conversion losses, and workload must still be measured at the wall.
For the broader choice between older server hardware, a mini PC, and dedicated NAS storage, see comparing old server hardware with a compact home server.
How many kWh does a NAS use in a year?
Multiply its average wall-power draw by 8.76 to estimate annual kWh. For example, a NAS averaging 25W uses about 219kWh per year, while one averaging 50W uses about 438kWh. Measure the real average for an accurate result.
Is it cheaper to turn a NAS off overnight?
It can reduce electricity use if the NAS is genuinely not needed during those hours. However, automatic shutdown may interrupt backups, uploads, remote access, maintenance tasks, and services. Use it only when the availability tradeoff is acceptable and the system can shut down cleanly.
Do more hard drives always mean much higher electricity use?
More drives usually increase power use, especially while they are spinning or active, but the increase depends on the specific drive models, capacity, activity pattern, spindown settings, and the rest of the NAS hardware. Use drive data sheets as a starting point, then confirm the full system’s wall-power draw with a meter.
Buying Guide
