Add cameras only after the NVR passes channel, ingest-bandwidth, PoE, retention, decode, analytics, storage-health, and recovery checks using real camera settings.
Record the Current Camera and NVR Baseline
List every camera's resolution, frame rate, codec, average and peak bitrate, continuous or event schedule, audio, substream, and analytics. Record NVR channel count, licensed channels, incoming bandwidth limit, decode limit, and current CPU or accelerator use.
A free channel number does not prove the NVR can ingest or display the next high-resolution stream. Count bandwidth and decoding separately from the channel license.
- Capture daytime and night bitrate.
- Include rain or high-motion scenes.
- Check main and substreams.
- Record current retention and disk health.
Calculate Storage From Bitrate and Retention
Use measured bitrate, recording hours, camera count, and retention days; then add filesystem, database, and free-space margin. Resolution alone cannot predict storage because codec settings and scene complexity change the data rate.
A detailed 30-day CCTV storage calculation explains why night noise, rain, motion, codec, and RAID overhead must be included rather than sizing from a daytime average.
Model the added cameras and a worst normal week. If the new plan shortens retention below the household requirement, add capacity or reduce recording demand before installation.
Check PoE, Switching, and Cable Paths
| Resource | Pass condition | Stop signal |
| PoE budget | Peak draw plus margin | Average draw only |
| Switch uplink | Aggregate streams plus headroom | One saturated 100Mb path |
| Cable run | Tested link and weather protection | Errors or renegotiation |
| NVR ingest | Peak bitrate below limit | Channel count used as proxy |
| UPS | NVR, switch, and cameras covered | Cameras die before graceful shutdown |
Check per-port PoE standard and total power budget. Night infrared, heaters, or pan-tilt motors may draw more than the daytime idle measurement.
Keep camera traffic away from storage management where practical. A camera and NVR commissioning checklist illustrates why addressing, activation, recording schedules, and handover should be tested together.
Validate Detection, Playback, and Failure Behavior
Test live view, timeline scrubbing, export, event search, mobile access, and simultaneous playback after adding one representative camera. Analytics may consume a different resource from basic recording.
Disconnect one camera, one PoE port, and the storage target. Confirm that alerts identify the failed layer and recording resumes without silently changing retention or quality.
Back up configuration and critical clips outside the NVR. Continuous footage may be replaceable by policy, but evidence selected for retention should not share the same failure domain.
Use an Add-or-Upgrade Gate
Add cameras when measured peak ingest, PoE, decode, analytics, storage, and UPS capacity all retain margin. Expand disks when retention is the first failing boundary; upgrade compute only when decoding or analytics is measured at its limit.
Upgrade switching when packet loss or uplink saturation appears under the new aggregate stream load. The small-file and storage-path testing workflow can help separate browsing overhead from bulk recording throughput.
Stop when one more camera requires reducing required retention, disables failure alerts, or pushes the only storage pool near full. A larger channel count does not compensate for an untested recovery path.
Final Takeaway
Buy only when every hard requirement passes in the real room and network; otherwise wait, narrow the design, or choose a simpler platform.
Buying Guide
