active users, client-side processing, sync frequency and retained attachments Time the job and identify CPU, storage or external-service waits before replacing hardware.
Imports, processing and simultaneous users.Erforderliche Hardware: RAM, CPU, Speicher & Aufgaben, Synchronisierung & Client-Arbeit
Der Plan umfasst RAM, CPU, persistenten Speicher und Service-Abhängigkeiten, eine workloadbasierte ZimaOS-Dimensionierung, Backups und praktische Hardwareempfehlungen.
Will Be Done hardware requirements at a glance
Offline-first task manager with weekly planning, project boards, real-time sync, Vim keybindings, desktop quick add, and import from popular task managers (alternative to TickTick, Todoist). Size the complete deployment around active users, client-side processing, sync frequency and retained attachments. Client applications and self-hosted sync backends have different footprints. Choose the documented web/server build rather than assuming a desktop binary is a headless container.
- RAM
- No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below.
- CPU
- No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity.
- Storage
- Persist tasks/notes, user settings, attachments and configured synchronization state.
- Required services
- Use the supported runtime and service topology in the linked deployment source for the selected release. The repository references SQLite, Redis / Valkey. These may include optional integrations or alternatives; install only the services required by the selected deployment.
- Main sizing variable
- active users, client-side processing, sync frequency and retained attachments
- Practical Zima starting point
- ZimaBoard 2 832 with SSD-backed active state is an editorial starting point for modest use. Include the OS and all companion services; it is not a measured capacity guarantee.
Plan the complete Will Be Done workload before selecting a server.
Official requirements
Choose the exact edition, stable release and supported container/runtime. Use the supported runtime and service topology in the linked deployment source for the selected release. The repository references SQLite, Redis / Valkey. These may include optional integrations or alternatives; install only the services required by the selected deployment.
Confirm your needs
Test a representative busy operation: active users, client-side processing, sync frequency and retained attachments Record peak resident memory, CPU, disk latency and completion time, including other containers.
Leave room to grow
Place active state on reliable persistent storage. Persist tasks/notes, user settings, attachments and configured synchronization state. Budget working space for an upgrade or import and test recovery before relying on the deployment.
Run it on ZimaOS
On ZimaOS, use a compatible amd64 container through Custom Install and reproduce all required services, volume mappings and device access. Client applications and self-hosted sync backends have different footprints. Choose the documented web/server build rather than assuming a desktop binary is a headless container.
- Exact edition and stable release
- Compatible amd64 image/runtime
- All required companion services
- Realistic peak activity
- Persistent data and file ownership
- Free host ports and reachable URLs
- Working space and backup retention
- Successful database/file restore
Reviewed November 2, 2026 against the linked upstream deployment documentation. Numerical values retain their stated minimum, recommendation or example scope; select release-compatible instructions before installation.
Client applications and self-hosted sync backends have different footprints. Choose the documented web/server build rather than assuming a desktop binary is a headless container. Numerical examples above retain their stated deployment scope; co-hosted services and independent backups need additional capacity.
| RAM guidance | No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below. | Official guidance keeps its original test, recommendation or example scope. |
| CPU guidance | No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity. | Core counts do not predict a fixed user, device or document capacity. |
| Storage planning | Persist tasks/notes, user settings, attachments and configured synchronization state. | Installation space is separate from retained content, working files and backups. |
| Service topology | Use the supported runtime and service topology in the linked deployment source for the selected release. The repository references SQLite, Redis / Valkey. These may include optional integrations or alternatives; install only the services required by the selected deployment. | Include every stateful companion service in the host budget. |
| Persistent state | Persist tasks/notes, user settings, attachments and configured synchronization state. | An image rebuild or container replacement is not a backup. |
| Deployment boundary | Client applications and self-hosted sync backends have different footprints. Choose the documented web/server build rather than assuming a desktop binary is a headless container. | Check the linked project instructions for the selected edition and release. |
Use observed Will Be Done workload pressure to decide when an upgrade is warranted.
Shared hosts and background work.Persist tasks/notes, user settings, attachments and configured synchronization state. Track primary state and backup retention separately.
Long-lived installations and growing collections.Plan hardware growth with confidence
Use suitable active storage
SATA or PCIe SSD according to measured data growth.Add memory for the complete stack
ZimaBoard 2 832 or ZimaBoard 2 1664 according to the measured constraint.Separate capacity from compute
ZimaCube 2 when a broader multi-drive workload justifies it.Fix the observed bottleneck
Check service configuration, I/O and network behavior before selecting a stronger CPU.Can it run on ZimaOS?
Custom install Will Be Done in ZimaOS
Use the supported runtime and service topology in the linked deployment source for the selected release. The repository references SQLite, Redis / Valkey. These may include optional integrations or alternatives; install only the services required by the selected deployment. Persist: Persist tasks/notes, user settings, attachments and configured synchronization state.
Custom install Will Be Done in the ZimaOS app ↗Use the official Will Be Done deployment instructions
Keep the selected stable release, persistent paths and companion services aligned with upstream documentation.
Review Will Be Done official installation ↗Check workload-specific deployment details
Review Will Be Done deployment details ↗Which Zima hardware fits Will Be Done?
Which workload best matches your Will Be Done deployment?
- Workload optionZimaBoard 2 832
- Workload optionZimaBoard 2 1664
| ZimaBoard 2 832 | Modest Will Be Done workload | active users, client-side processing, sync frequency and retained attachments |
This is an editorial host choice, not an official app minimum or a guaranteed user/device capacity. | Get Now |
| ZimaBoard 2 1664 | More processing or shared-service headroom | Use the supported runtime and service topology in the linked deployment source for the selected release. The repository references SQLite, Redis / Valkey. These may include optional integrations or alternatives; install only the services required by the selected deployment. |
Size the combined stack and active working set; more RAM does not fix remote API limits or missing dependencies. | Get Now |
“ZimaCube 2: Not just another NAS, tested with 25TB storage, local AI agents, 4K transcoding, and real homelab workflows.”Read full review
“The ZimaBoard 2 is a compact x86 server board that can be turned into a mini NAS, home server, media box, or self-hosting hub.”Read full review
“ZimaCube 2: A modern, high-performance NAS with plenty of room to grow—built for users who want more than basic storage.”Read full review
“Coverage focused on ZimaCube 2's open hardware foundation, no monthly fee, and self-hosting flexibility.”Read full review
Answers to Will Be Done RAM, CPU, storage, Docker, database and ZimaOS sizing questions.
How much RAM should I plan for Will Be Done?
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below. Include ZimaOS, the application and its companion services rather than reserving the entire machine for one container.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity. The workload to test is: active users, client-side processing, sync frequency and retained attachments
Persist tasks/notes, user settings, attachments and configured synchronization state. Preserve a consistent database/file set and verify that your recovery procedure restores a working application.
Can I deploy it on ZimaOS?
Client applications and self-hosted sync backends have different footprints. Choose the documented web/server build rather than assuming a desktop binary is a headless container. Measure the same representative operation before and after a configuration or hardware change.
What sources informed this Will Be Done hardware guide?
This guide was reviewed against the linked project deployment documentation on November 2, 2026. Zima device choices are editorial workload guidance, separate from upstream requirements and measured performance.
