managed objects/nodes, API activity, reconciliation frequency, concurrent jobs and worker resources Time the job and identify CPU, storage or external-service waits before replacing hardware.
Imports, processing and simultaneous users.Temps-Hardwareanforderungen: RAM, CPU, Speicher und Controller sowie verwaltete Workloads
Plane RAM, CPU, persistenten Speicher und Service-Abhängigkeiten mit einer workloadbasierten Dimensionierung von ZimaOS, Backups und praktischen Hardware-Empfehlungen.
Temps hardware requirements at a glance
Application deployment and operations control with analytics, monitoring and separately hosted workloads. Control-plane resources do not include deployed applications, build jobs, managed databases or target hosts. Verify daemon access, cluster/host prerequisites and supported runtime. Retain configuration and restore data independently of image replacement.
- RAM
- No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below.
- CPU
- No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity.
- Storage
- Persist declarative configuration, credentials, workflow history, controller state and recovery copies.
- Required services
- Use the supported upstream Temps runtime and service topology. Control-plane resources do not include deployed applications, build jobs, managed databases or target hosts. Verify daemon access, cluster/host prerequisites and supported runtime. Retain configuration and restore data independently of image replacement. Upstream repository references include PostgreSQL, Redis / Valkey, MariaDB / MySQL, MongoDB, S3-compatible object storage. Confirm which are required in your selected mode rather than enabling all references by default.
- Main sizing variable
- managed objects/nodes, API activity, reconciliation frequency, concurrent jobs and worker resources
- Practical Zima starting point
- Conditional lab, data-storage or supporting-service hardware only; a complete production deployment requires a separately verified host meeting the upstream requirements. Application deployment and operations control with analytics, monitoring and separately hosted workloads. Control-plane resources do not include deployed applications, build jobs, managed databases or target hosts. Verify daemon access, cluster/host prerequisites and supported runtime. Retain configuration and restore data independently of image replacement.
Plan the complete Temps workload before selecting a server.
Official requirements
Choose the exact edition, stable release and supported container/runtime. Use the supported upstream Temps runtime and service topology. Control-plane resources do not include deployed applications, build jobs, managed databases or target hosts. Verify daemon access, cluster/host prerequisites and supported runtime. Retain configuration and restore data independently of image replacement. Upstream repository references include PostgreSQL, Redis / Valkey, MariaDB / MySQL, MongoDB, S3-compatible object storage. Confirm which are required in your selected mode rather than enabling all references by default.
Confirm your needs
Test a representative busy operation: managed objects/nodes, API activity, reconciliation frequency, concurrent jobs and worker resources Record peak resident memory, CPU, disk latency and completion time, including other containers.
Leave room to grow
Place active state on reliable persistent storage. Persist declarative configuration, credentials, workflow history, controller state and recovery copies. Budget working space for an upgrade or import and test recovery before relying on the deployment.
Run it on ZimaOS
Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment. Application deployment and operations control with analytics, monitoring and separately hosted workloads. Control-plane resources do not include deployed applications, build jobs, managed databases or target hosts. Verify daemon access, cluster/host prerequisites and supported runtime. Retain configuration and restore data independently of image replacement.
- Exact edition and stable release
- Supported upstream runtime and architecture
- All required companion services
- Realistic peak activity
- Persistent data and file ownership
- Free host ports and reachable URLs
- Working space and backup retention
- Successful database/file restore
Reviewed November 18, 2026 against the linked upstream deployment documentation. Numerical values retain their stated minimum, recommendation or example scope; select release-compatible instructions before installation.
Application deployment and operations control with analytics, monitoring and separately hosted workloads. Control-plane resources do not include deployed applications, build jobs, managed databases or target hosts. Verify daemon access, cluster/host prerequisites and supported runtime. Retain configuration and restore data independently of image replacement. Numerical examples above retain their stated deployment scope; co-hosted services and independent backups need additional capacity.
| RAM guidance | No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below. | Official guidance keeps its original test, recommendation or example scope. |
| CPU guidance | No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity. | Core counts do not predict a fixed user, device or document capacity. |
| Storage planning | Persist declarative configuration, credentials, workflow history, controller state and recovery copies. | Installation space is separate from retained content, working files and backups. |
| Service topology | Use the supported upstream Temps runtime and service topology. Control-plane resources do not include deployed applications, build jobs, managed databases or target hosts. Verify daemon access, cluster/host prerequisites and supported runtime. Retain configuration and restore data independently of image replacement. Upstream repository references include PostgreSQL, Redis / Valkey, MariaDB / MySQL, MongoDB, S3-compatible object storage. Confirm which are required in your selected mode rather than enabling all references by default. | Include every stateful companion service in the host budget. |
| Persistent state | Persist declarative configuration, credentials, workflow history, controller state and recovery copies. | An image rebuild or container replacement is not a backup. |
| Deployment boundary | Application deployment and operations control with analytics, monitoring and separately hosted workloads. Control-plane resources do not include deployed applications, build jobs, managed databases or target hosts. Verify daemon access, cluster/host prerequisites and supported runtime. Retain configuration and restore data independently of image replacement. | Check the linked project instructions for the selected edition and release. |
Use observed Temps workload pressure to decide when an upgrade is warranted.
Shared hosts and background work.Persist declarative configuration, credentials, workflow history, controller state and recovery copies. Track primary state and backup retention separately.
Long-lived installations and growing collections.Plan hardware growth with confidence
Use suitable active storage
SATA or PCIe SSD according to measured data growth.Add memory for the complete stack
ZimaBoard 2 832 or ZimaBoard 2 1664 according to the measured constraint.Separate capacity from compute
ZimaCube 2 when a broader multi-drive workload justifies it.Fix the observed bottleneck
Check service configuration, I/O and network behavior before selecting a stronger CPU.Can it run on ZimaOS?
Verify the supported upstream deployment
Application deployment and operations control with analytics, monitoring and separately hosted workloads. Control-plane resources do not include deployed applications, build jobs, managed databases or target hosts. Verify daemon access, cluster/host prerequisites and supported runtime. Retain configuration and restore data independently of image replacement. Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment.
Review upstream deployment guidance ↗Use the official Temps deployment instructions
Keep the selected stable release, persistent paths and companion services aligned with upstream documentation.
Review Temps official installation ↗Check workload-specific deployment details
Review Temps deployment details ↗Which Zima hardware fits Temps?
Which workload best matches your Temps deployment?
- Supporting hardware onlyZimaBoard 2 832
| ZimaBoard 2 832 | Conditional lab or supporting-service role | managed objects/nodes, API activity, reconciliation frequency, concurrent jobs and worker resources |
Conditional lab, data-storage or supporting-service hardware only; a complete production deployment requires a separately verified host meeting the upstream requirements. Application deployment and operations control with analytics, monitoring and separately hosted workloads. Control-plane resources do not include deployed applications, build jobs, managed databases or target hosts. Verify daemon access, cluster/host prerequisites and supported runtime. Retain configuration and restore data independently of image replacement. | Get Now |
| ZimaBoard 2 1664 | Conditional lab or supporting-service role | Use the supported upstream Temps runtime and service topology. Control-plane resources do not include deployed applications, build jobs, managed databases or target hosts. Verify daemon access, cluster/host prerequisites and supported runtime. Retain configuration and restore data independently of image replacement. Upstream repository references include PostgreSQL, Redis / Valkey, MariaDB / MySQL, MongoDB, S3-compatible object storage. Confirm which are required in your selected mode rather than enabling all references by default. |
“ZimaCube 2: Not just another NAS, tested with 25TB storage, local AI agents, 4K transcoding, and real homelab workflows.”Read full review
“The ZimaBoard 2 is a compact x86 server board that can be turned into a mini NAS, home server, media box, or self-hosting hub.”Read full review
“ZimaCube 2: A modern, high-performance NAS with plenty of room to grow—built for users who want more than basic storage.”Read full review
“Coverage focused on ZimaCube 2's open hardware foundation, no monthly fee, and self-hosting flexibility.”Read full review
Answers to Temps RAM, CPU, storage, Docker, database and ZimaOS sizing questions.
How much RAM should I plan for Temps?
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below. Include ZimaOS, the application and its companion services rather than reserving the entire machine for one container.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity. The workload to test is: managed objects/nodes, API activity, reconciliation frequency, concurrent jobs and worker resources
Persist declarative configuration, credentials, workflow history, controller state and recovery copies. Preserve a consistent database/file set and verify that your recovery procedure restores a working application.
Accelerator needs depend on the selected inference, synthesis, browser or media backend. Application deployment and operations control with analytics, monitoring and separately hosted workloads. Control-plane resources do not include deployed applications, build jobs, managed databases or target hosts. Verify daemon access, cluster/host prerequisites and supported runtime. Retain configuration and restore data independently of image replacement.
Can I deploy it on ZimaOS?
Application deployment and operations control with analytics, monitoring and separately hosted workloads. Control-plane resources do not include deployed applications, build jobs, managed databases or target hosts. Verify daemon access, cluster/host prerequisites and supported runtime. Retain configuration and restore data independently of image replacement. Measure the same representative operation before and after a configuration or hardware change.
What sources informed this Temps hardware guide?
This guide was reviewed against the linked project deployment documentation on November 18, 2026. Zima device choices are editorial workload guidance, separate from upstream requirements and measured performance.
