Sun-Panel-Hardwareanforderungen: RAM, CPU, Speicherplatz und Web-Traffic und Inhalte
Plane RAM, CPU, persistenten Speicher und Service-Abhängigkeiten für Sun-Panel mit einer workloadbasierten Dimensionierung von ZimaOS, Backups und praxisgerechter Hardware-Auswahl.
Sun-Panel hardware requirements at a glance
Server application navigation dashboard with links, icons and saved settings. This interface does not include the applications, agent harnesses or model engines it displays. Separate browser/client work, static/server delivery and any enabled proxy or API roles; this workload alone does not establish a need for a stronger NAS or a dedicated GPU.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity.
Persist application configuration, stored content/uploads and configured database state.
Required services
Use the supported upstream Sun-Panel runtime and service topology. This interface does not include the applications, agent harnesses or model engines it displays. Separate browser/client work, static/server delivery and any enabled proxy or API roles; this workload alone does not establish a need for a stronger NAS or a dedicated GPU.
Main sizing variable
concurrent requests, plugins, generated pages and retained assets
Practical Zima starting point
Plan the complete Sun-Panel workload before selecting a server.
    Choose the exact edition, stable release and supported container/runtime. Use the supported upstream Sun-Panel runtime and service topology. This interface does not include the applications, agent harnesses or model engines it displays. Separate browser/client work, static/server delivery and any enabled proxy or API roles; this workload alone does not establish a need for a stronger NAS or a dedicated GPU.
    Test a representative busy operation: concurrent requests, plugins, generated pages and retained assets Record peak resident memory, CPU, disk latency and completion time, including other containers.
    Place active state on reliable persistent storage. Persist application configuration, stored content/uploads and configured database state. Budget working space for an upgrade or import and test recovery before relying on the deployment.
    Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment. Server application navigation dashboard with links, icons and saved settings. This interface does not include the applications, agent harnesses or model engines it displays. Separate browser/client work, static/server delivery and any enabled proxy or API roles; this workload alone does not establish a need for a stronger NAS or a dedicated GPU.
  • Supported upstream runtime and architecture
  • Realistic peak activity
Reviewed November 18, 2026 against the linked upstream deployment documentation. Numerical values retain their stated minimum, recommendation or example scope; select release-compatible instructions before installation.
Review Sun-Panel official requirements
Server application navigation dashboard with links, icons and saved settings. This interface does not include the applications, agent harnesses or model engines it displays. Separate browser/client work, static/server delivery and any enabled proxy or API roles; this workload alone does not establish a need for a stronger NAS or a dedicated GPU. Numerical examples above retain their stated deployment scope; co-hosted services and independent backups need additional capacity.
RAM guidanceNo fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below.Official guidance keeps its original test, recommendation or example scope.
CPU guidanceNo fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity.Core counts do not predict a fixed user, device or document capacity.
Storage planningPersist application configuration, stored content/uploads and configured database state.Installation space is separate from retained content, working files and backups.
Service topologyUse the supported upstream Sun-Panel runtime and service topology. This interface does not include the applications, agent harnesses or model engines it displays. Separate browser/client work, static/server delivery and any enabled proxy or API roles; this workload alone does not establish a need for a stronger NAS or a dedicated GPU.Include every stateful companion service in the host budget.
Persistent statePersist application configuration, stored content/uploads and configured database state.An image rebuild or container replacement is not a backup.
Deployment boundaryServer application navigation dashboard with links, icons and saved settings. This interface does not include the applications, agent harnesses or model engines it displays. Separate browser/client work, static/server delivery and any enabled proxy or API roles; this workload alone does not establish a need for a stronger NAS or a dedicated GPU.Check the linked project instructions for the selected edition and release.
Use observed Sun-Panel workload pressure to decide when an upgrade is warranted.
concurrent requests, plugins, generated pages and retained assets Time the job and identify CPU, storage or external-service waits before replacing hardware.
Persist application configuration, stored content/uploads and configured database state. Track primary state and backup retention separately.
Use suitable active storage
Fix the observed bottleneck
Verify the supported upstream deployment
Server application navigation dashboard with links, icons and saved settings. This interface does not include the applications, agent harnesses or model engines it displays. Separate browser/client work, static/server delivery and any enabled proxy or API roles; this workload alone does not establish a need for a stronger NAS or a dedicated GPU. Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment.
Review upstream deployment guidance ↗
Review Sun-Panel deployment details ↗
Which Zima hardware fits Sun-Panel?
Which workload best matches your Sun-Panel deployment?
Modest Sun-Panel deployment
ZimaBoard 2 832 Modest Sun-Panel workload concurrent requests, plugins, generated pages and retained assets
ZimaBoard 2 1664 More processing or shared-service headroom Use the supported upstream Sun-Panel runtime and service topology. This interface does not include the applications, agent harnesses or model engines it displays. Separate browser/client work, static/server delivery and any enabled proxy or API roles; this workload alone does not establish a need for a stronger NAS or a dedicated GPU.
Answers to Sun-Panel RAM, CPU, storage, Docker, database and ZimaOS sizing questions.
How much RAM should I plan for Sun-Panel?
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below. Include ZimaOS, the application and its companion services rather than reserving the entire machine for one container.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity. The workload to test is: concurrent requests, plugins, generated pages and retained assets
Persist application configuration, stored content/uploads and configured database state. Preserve a consistent database/file set and verify that your recovery procedure restores a working application.
Can I deploy it on ZimaOS?
Server application navigation dashboard with links, icons and saved settings. This interface does not include the applications, agent harnesses or model engines it displays. Separate browser/client work, static/server delivery and any enabled proxy or API roles; this workload alone does not establish a need for a stronger NAS or a dedicated GPU. Measure the same representative operation before and after a configuration or hardware change.
What sources informed this Sun-Panel hardware guide?
This guide was reviewed against the linked project deployment documentation on November 18, 2026. Zima device choices are editorial workload guidance, separate from upstream requirements and measured performance.
  1. Sun-Panel official setup / requirements
  2. Sun-Panel configuration / deployment
  3. Sun-Panel official repository and releases
  4. ZimaBoard 2 specifications
  5. Sun-Panel image source: public project material
