Hardwareanforderungen für Smart Sec Cam: RAM, CPU, Speicher und Medienrollen, Aufbewahrung und Verarbeitung
Plane RAM, CPU, persistenten Speicher und Service-Abhängigkeiten für eine intelligente Sicherheitskamera – mit einer workloadbasierten Dimensionierung von ZimaOS, Backups und praxisnahen Hardware-Empfehlungen.
Smart Sec Cam hardware requirements at a glance
Camera-feed aggregation, recording and motion detection with separate capture devices. Metadata, actual media retention and stream processing are different workloads. Include only enabled decoding, remuxing, transcoding or rendering workers, and verify actual codec and device support. Client playback and remote providers do not automatically consume NAS model or graphics resources.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity.
Persist source media where retained, catalog/configuration state, processing caches and recoverable copies.
Required services
Use the documented Smart Sec Cam runtime and selected service topology. Metadata, actual media retention and stream processing are different workloads. Include only enabled decoding, remuxing, transcoding or rendering workers, and verify actual codec and device support. Client playback and remote providers do not automatically consume NAS model or graphics resources.
Main sizing variable
library/import size, concurrent streams, enabled processing, codecs, resolution and retained media
Practical Zima starting point
Plan the complete Smart Sec Cam workload before selecting a server.
    Choose the exact edition, stable release and supported container/runtime. Use the documented Smart Sec Cam runtime and selected service topology. Metadata, actual media retention and stream processing are different workloads. Include only enabled decoding, remuxing, transcoding or rendering workers, and verify actual codec and device support. Client playback and remote providers do not automatically consume NAS model or graphics resources.
    Test a representative busy operation: library/import size, concurrent streams, enabled processing, codecs, resolution and retained media Record peak resident memory, CPU, disk latency and completion time, including other containers.
    Place active state on reliable persistent storage. Persist source media where retained, catalog/configuration state, processing caches and recoverable copies. Budget working space for an upgrade or import and test recovery before relying on the deployment.
    Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment. Camera-feed aggregation, recording and motion detection with separate capture devices. Metadata, actual media retention and stream processing are different workloads. Include only enabled decoding, remuxing, transcoding or rendering workers, and verify actual codec and device support. Client playback and remote providers do not automatically consume NAS model or graphics resources. Separate camera devices perform capture using the supported Python setup. The Docker server aggregates video and detects motion; the NAS does not supply physical cameras or guarantee every input format.
  • Supported upstream runtime and architecture
  • Realistic peak activity
Reviewed November 20, 2026 against the linked upstream deployment documentation. Numerical values retain their stated minimum, recommendation or example scope; select release-compatible instructions before installation.
Review Smart Sec Cam official requirements
Camera-feed aggregation, recording and motion detection with separate capture devices. Metadata, actual media retention and stream processing are different workloads. Include only enabled decoding, remuxing, transcoding or rendering workers, and verify actual codec and device support. Client playback and remote providers do not automatically consume NAS model or graphics resources. Separate camera devices perform capture using the supported Python setup. The Docker server aggregates video and detects motion; the NAS does not supply physical cameras or guarantee every input format. Numerical examples above retain their stated deployment scope; co-hosted services and independent backups need additional capacity.
RAM guidanceNo fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below.Official guidance keeps its original test, recommendation or example scope.
CPU guidanceNo fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity.Core counts do not predict a fixed user, device or document capacity.
Storage planningPersist source media where retained, catalog/configuration state, processing caches and recoverable copies.Installation space is separate from retained content, working files and backups.
Service topologyUse the documented Smart Sec Cam runtime and selected service topology. Metadata, actual media retention and stream processing are different workloads. Include only enabled decoding, remuxing, transcoding or rendering workers, and verify actual codec and device support. Client playback and remote providers do not automatically consume NAS model or graphics resources.Include every stateful companion service in the host budget.
Persistent statePersist source media where retained, catalog/configuration state, processing caches and recoverable copies.An image rebuild or container replacement is not a backup.
Deployment boundaryCamera-feed aggregation, recording and motion detection with separate capture devices. Metadata, actual media retention and stream processing are different workloads. Include only enabled decoding, remuxing, transcoding or rendering workers, and verify actual codec and device support. Client playback and remote providers do not automatically consume NAS model or graphics resources. Separate camera devices perform capture using the supported Python setup. The Docker server aggregates video and detects motion; the NAS does not supply physical cameras or guarantee every input format.Check the linked project instructions for the selected edition and release.
Use observed Smart Sec Cam workload pressure to decide when an upgrade is warranted.
library/import size, concurrent streams, enabled processing, codecs, resolution and retained media Time the job and identify CPU, storage or external-service waits before replacing hardware.
Persist source media where retained, catalog/configuration state, processing caches and recoverable copies. Track primary state and backup retention separately.
Use suitable active storage
ZimaBoard 2 832 or ZimaCube 2 Pro according to the measured constraint.
Fix the observed bottleneck
Verify the supported upstream deployment
Camera-feed aggregation, recording and motion detection with separate capture devices. Metadata, actual media retention and stream processing are different workloads. Include only enabled decoding, remuxing, transcoding or rendering workers, and verify actual codec and device support. Client playback and remote providers do not automatically consume NAS model or graphics resources. Separate camera devices perform capture using the supported Python setup. The Docker server aggregates video and detects motion; the NAS does not supply physical cameras or guarantee every input format. Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment.
Review upstream deployment guidance ↗
Review Smart Sec Cam deployment details ↗
Which Zima hardware fits Smart Sec Cam?
Which workload best matches your Smart Sec Cam deployment?
Modest Smart Sec Cam deployment
ZimaBoard 2 832 Modest Smart Sec Cam workload library/import size, concurrent streams, enabled processing, codecs, resolution and retained media
ZimaCube 2 Pro More processing or shared-service headroom Use the documented Smart Sec Cam runtime and selected service topology. Metadata, actual media retention and stream processing are different workloads. Include only enabled decoding, remuxing, transcoding or rendering workers, and verify actual codec and device support. Client playback and remote providers do not automatically consume NAS model or graphics resources.
16 GB
10GbE plus 2.5GbE
Answers to Smart Sec Cam RAM, CPU, storage, Docker, database and ZimaOS sizing questions.
How much RAM should I plan for Smart Sec Cam?
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below. Include ZimaOS, the application and its companion services rather than reserving the entire machine for one container.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity. The workload to test is: library/import size, concurrent streams, enabled processing, codecs, resolution and retained media
Persist source media where retained, catalog/configuration state, processing caches and recoverable copies. Preserve a consistent database/file set and verify that your recovery procedure restores a working application.
Accelerator needs depend on the selected inference, synthesis, browser or media backend. Camera-feed aggregation, recording and motion detection with separate capture devices. Metadata, actual media retention and stream processing are different workloads. Include only enabled decoding, remuxing, transcoding or rendering workers, and verify actual codec and device support. Client playback and remote providers do not automatically consume NAS model or graphics resources. Separate camera devices perform capture using the supported Python setup. The Docker server aggregates video and detects motion; the NAS does not supply physical cameras or guarantee every input format.
Can I deploy it on ZimaOS?
Camera-feed aggregation, recording and motion detection with separate capture devices. Metadata, actual media retention and stream processing are different workloads. Include only enabled decoding, remuxing, transcoding or rendering workers, and verify actual codec and device support. Client playback and remote providers do not automatically consume NAS model or graphics resources. Separate camera devices perform capture using the supported Python setup. The Docker server aggregates video and detects motion; the NAS does not supply physical cameras or guarantee every input format. Measure the same representative operation before and after a configuration or hardware change.
ZimaBoard 2 832 is the editorial starting point for this modest deployment. Choose ZimaCube 2 Pro for measured memory/processing pressure or broader shared services; retained data determines storage expansion.
What sources informed this Smart Sec Cam hardware guide?
This guide was reviewed against the linked project deployment documentation on November 20, 2026. Zima device choices are editorial workload guidance, separate from upstream requirements and measured performance.
  1. Smart Sec Cam official setup / requirements
  2. Smart Sec Cam configuration / deployment
  3. Smart Sec Cam official repository and releases
  4. ZimaBoard 2 specifications
  5. Smart Sec Cam image source: public project material
