Slowbooks Pro Hardwareanforderungen: RAM, CPU, Speicherplatz, Geschäftsunterlagen und Hintergrundaufgaben
Planen Sie RAM, CPU, persistenten Speicher und Service-Abhängigkeiten für Slowbooks Pro mit einer auf Workloads basierenden ZimaOS-Dimensionierung, Backups und praktischen Hardware-Empfehlungen.
Slowbooks Pro hardware requirements at a glance
Accounting records in the supported multi-user Server Edition, with desktop clients treated separately. Persistent records, attachments and import/report workers need a consistent recovery set. Test representative data imports and reports rather than assuming registered-account count predicts load. Third-party financial or job integrations are independent services; hardware sizing does not establish financial or regulatory outcomes.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity.
Persist business database, uploaded documents, attachments, configuration and scheduled-job state.
Required services
Use the supported upstream Slowbooks Pro runtime and service topology. Persistent records, attachments and import/report workers need a consistent recovery set. Test representative data imports and reports rather than assuming registered-account count predicts load. Third-party financial or job integrations are independent services; hardware sizing does not establish financial or regulatory outcomes. Upstream repository references include PostgreSQL, SQLite, Redis / Valkey. Confirm which are required in your selected mode rather than enabling all references by default.
Main sizing variable
active modules, simultaneous transactions, reports, imports and background jobs
Practical Zima starting point
Plan the complete Slowbooks Pro workload before selecting a server.
    Choose the exact edition, stable release and supported container/runtime. Use the supported upstream Slowbooks Pro runtime and service topology. Persistent records, attachments and import/report workers need a consistent recovery set. Test representative data imports and reports rather than assuming registered-account count predicts load. Third-party financial or job integrations are independent services; hardware sizing does not establish financial or regulatory outcomes. Upstream repository references include PostgreSQL, SQLite, Redis / Valkey. Confirm which are required in your selected mode rather than enabling all references by default.
    Test a representative busy operation: active modules, simultaneous transactions, reports, imports and background jobs Record peak resident memory, CPU, disk latency and completion time, including other containers.
    Place active state on reliable persistent storage. Persist business database, uploaded documents, attachments, configuration and scheduled-job state. Budget working space for an upgrade or import and test recovery before relying on the deployment.
    Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment. Accounting records in the supported multi-user Server Edition, with desktop clients treated separately. Persistent records, attachments and import/report workers need a consistent recovery set. Test representative data imports and reports rather than assuming registered-account count predicts load. Third-party financial or job integrations are independent services; hardware sizing does not establish financial or regulatory outcomes. Use its multi-user Server Edition for the server role. Desktop-only features are separate, and Linux Docker support is optional. Persistent accounting data and attachments must be backed up consistently.
  • Supported upstream runtime and architecture
  • Realistic peak activity
Reviewed November 18, 2026 against the linked upstream deployment documentation. Numerical values retain their stated minimum, recommendation or example scope; select release-compatible instructions before installation.
Review Slowbooks Pro official requirements
Accounting records in the supported multi-user Server Edition, with desktop clients treated separately. Persistent records, attachments and import/report workers need a consistent recovery set. Test representative data imports and reports rather than assuming registered-account count predicts load. Third-party financial or job integrations are independent services; hardware sizing does not establish financial or regulatory outcomes. Use its multi-user Server Edition for the server role. Desktop-only features are separate, and Linux Docker support is optional. Persistent accounting data and attachments must be backed up consistently. Numerical examples above retain their stated deployment scope; co-hosted services and independent backups need additional capacity.
RAM guidanceNo fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below.Official guidance keeps its original test, recommendation or example scope.
CPU guidanceNo fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity.Core counts do not predict a fixed user, device or document capacity.
Storage planningPersist business database, uploaded documents, attachments, configuration and scheduled-job state.Installation space is separate from retained content, working files and backups.
Service topologyUse the supported upstream Slowbooks Pro runtime and service topology. Persistent records, attachments and import/report workers need a consistent recovery set. Test representative data imports and reports rather than assuming registered-account count predicts load. Third-party financial or job integrations are independent services; hardware sizing does not establish financial or regulatory outcomes. Upstream repository references include PostgreSQL, SQLite, Redis / Valkey. Confirm which are required in your selected mode rather than enabling all references by default.Include every stateful companion service in the host budget.
Persistent statePersist business database, uploaded documents, attachments, configuration and scheduled-job state.An image rebuild or container replacement is not a backup.
Deployment boundaryAccounting records in the supported multi-user Server Edition, with desktop clients treated separately. Persistent records, attachments and import/report workers need a consistent recovery set. Test representative data imports and reports rather than assuming registered-account count predicts load. Third-party financial or job integrations are independent services; hardware sizing does not establish financial or regulatory outcomes. Use its multi-user Server Edition for the server role. Desktop-only features are separate, and Linux Docker support is optional. Persistent accounting data and attachments must be backed up consistently.Check the linked project instructions for the selected edition and release.
Use observed Slowbooks Pro workload pressure to decide when an upgrade is warranted.
active modules, simultaneous transactions, reports, imports and background jobs Time the job and identify CPU, storage or external-service waits before replacing hardware.
Persist business database, uploaded documents, attachments, configuration and scheduled-job state. Track primary state and backup retention separately.
Use suitable active storage
Fix the observed bottleneck
Verify the supported upstream deployment
Accounting records in the supported multi-user Server Edition, with desktop clients treated separately. Persistent records, attachments and import/report workers need a consistent recovery set. Test representative data imports and reports rather than assuming registered-account count predicts load. Third-party financial or job integrations are independent services; hardware sizing does not establish financial or regulatory outcomes. Use its multi-user Server Edition for the server role. Desktop-only features are separate, and Linux Docker support is optional. Persistent accounting data and attachments must be backed up consistently. Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment.
Review upstream deployment guidance ↗
Review Slowbooks Pro deployment details ↗
Which Zima hardware fits Slowbooks Pro?
Which workload best matches your Slowbooks Pro deployment?
Modest Slowbooks Pro deployment
ZimaBoard 2 1664 Modest Slowbooks Pro workload active modules, simultaneous transactions, reports, imports and background jobs
ZimaCube 2 Pro More processing or shared-service headroom Use the supported upstream Slowbooks Pro runtime and service topology. Persistent records, attachments and import/report workers need a consistent recovery set. Test representative data imports and reports rather than assuming registered-account count predicts load. Third-party financial or job integrations are independent services; hardware sizing does not establish financial or regulatory outcomes. Upstream repository references include PostgreSQL, SQLite, Redis / Valkey. Confirm which are required in your selected mode rather than enabling all references by default.
16 GB
10GbE plus 2.5GbE
Answers to Slowbooks Pro RAM, CPU, storage, Docker, database and ZimaOS sizing questions.
How much RAM should I plan for Slowbooks Pro?
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below. Include ZimaOS, the application and its companion services rather than reserving the entire machine for one container.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity. The workload to test is: active modules, simultaneous transactions, reports, imports and background jobs
Persist business database, uploaded documents, attachments, configuration and scheduled-job state. Preserve a consistent database/file set and verify that your recovery procedure restores a working application.
Can I deploy it on ZimaOS?
Accounting records in the supported multi-user Server Edition, with desktop clients treated separately. Persistent records, attachments and import/report workers need a consistent recovery set. Test representative data imports and reports rather than assuming registered-account count predicts load. Third-party financial or job integrations are independent services; hardware sizing does not establish financial or regulatory outcomes. Use its multi-user Server Edition for the server role. Desktop-only features are separate, and Linux Docker support is optional. Persistent accounting data and attachments must be backed up consistently. Measure the same representative operation before and after a configuration or hardware change.
What sources informed this Slowbooks Pro hardware guide?
This guide was reviewed against the linked project deployment documentation on November 18, 2026. Zima device choices are editorial workload guidance, separate from upstream requirements and measured performance.
  1. Slowbooks Pro official setup / requirements
  2. Slowbooks Pro configuration / deployment
  3. Slowbooks Pro official repository and releases
  4. ZimaBoard 2 specifications
  5. Slowbooks Pro image source: public project material
