active editors/users, realtime updates, imports, search and attached files Time the job and identify CPU, storage or external-service waits before replacing hardware.
Imports, processing and simultaneous users.Hardwareanforderungen für Simple Machines Forum: RAM, CPU, Speicherplatz, gleichzeitige Nutzer und gemeinsam genutzte Datensätze
Planen Sie RAM, CPU, persistenten Speicher und Dienstabhängigkeiten für Simple Machines Forum mit einer an der Arbeitslast orientierten ZimaOS-Dimensionierung, Backups und praktischen Hardwareempfehlungen.
Simple Machines Forum hardware requirements at a glance
Free, professional grade software package that allows you to set up your own online community within minutes. Budget supported PHP/database, posts, search/indexing, plugins, attachments and background mail together. Account count alone does not predict active forum memory or throughput.
- RAM
- No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below.
- CPU
- No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity.
- Storage
- Persist projects, user records, messages/documents, uploaded assets and background-job state.
- Required services
- Use the supported upstream runtime and complete service topology for the selected release.
- Main sizing variable
- active editors/users, realtime updates, imports, search and attached files
- Practical Zima starting point
- ZimaBoard 2 832 with SSD-backed active state is an editorial starting point for modest use. Include the OS and all companion services; it is not a measured capacity guarantee.
Plan the complete Simple Machines Forum workload before selecting a server.
Official requirements
Choose the exact edition, stable release and supported container/runtime. Use the supported upstream runtime and complete service topology for the selected release.
Confirm your needs
Test a representative busy operation: active editors/users, realtime updates, imports, search and attached files Record peak resident memory, CPU, disk latency and completion time, including other containers.
Leave room to grow
Place active state on reliable persistent storage. Persist projects, user records, messages/documents, uploaded assets and background-job state. Budget working space for an upgrade or import and test recovery before relying on the deployment.
Run it on ZimaOS
Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment. Budget supported PHP/database, posts, search/indexing, plugins, attachments and background mail together. Account count alone does not predict active forum memory or throughput.
- Exact edition and stable release
- Supported upstream runtime and architecture
- All required companion services
- Realistic peak activity
- Persistent data and file ownership
- Free host ports and reachable URLs
- Working space and backup retention
- Successful database/file restore
Reviewed November 2, 2026 against the linked upstream deployment documentation. Numerical values retain their stated minimum, recommendation or example scope; select release-compatible instructions before installation.
Budget supported PHP/database, posts, search/indexing, plugins, attachments and background mail together. Account count alone does not predict active forum memory or throughput. Numerical examples above retain their stated deployment scope; co-hosted services and independent backups need additional capacity.
| RAM guidance | No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below. | Official guidance keeps its original test, recommendation or example scope. |
| CPU guidance | No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity. | Core counts do not predict a fixed user, device or document capacity. |
| Storage planning | Persist projects, user records, messages/documents, uploaded assets and background-job state. | Installation space is separate from retained content, working files and backups. |
| Service topology | Use the supported upstream runtime and complete service topology for the selected release. | Include every stateful companion service in the host budget. |
| Persistent state | Persist projects, user records, messages/documents, uploaded assets and background-job state. | An image rebuild or container replacement is not a backup. |
| Deployment boundary | Budget supported PHP/database, posts, search/indexing, plugins, attachments and background mail together. Account count alone does not predict active forum memory or throughput. | Check the linked project instructions for the selected edition and release. |
Use observed Simple Machines Forum workload pressure to decide when an upgrade is warranted.
Shared hosts and background work.Persist projects, user records, messages/documents, uploaded assets and background-job state. Track primary state and backup retention separately.
Long-lived installations and growing collections.Plan hardware growth with confidence
Use suitable active storage
SATA or PCIe SSD according to measured data growth.Add memory for the complete stack
ZimaBoard 2 832 or ZimaBoard 2 1664 according to the measured constraint.Separate capacity from compute
ZimaCube 2 when a broader multi-drive workload justifies it.Fix the observed bottleneck
Check service configuration, I/O and network behavior before selecting a stronger CPU.Can it run on ZimaOS?
Verify the supported upstream deployment
Budget supported PHP/database, posts, search/indexing, plugins, attachments and background mail together. Account count alone does not predict active forum memory or throughput. Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment.
Review upstream deployment guidance ↗Use the official Simple Machines Forum deployment instructions
Keep the selected stable release, persistent paths and companion services aligned with upstream documentation.
Review Simple Machines Forum official installation ↗Check workload-specific deployment details
Review Simple Machines Forum deployment details ↗Which Zima hardware fits Simple Machines Forum?
Which workload best matches your Simple Machines Forum deployment?
- Workload optionZimaBoard 2 832
- Workload optionZimaBoard 2 1664
| ZimaBoard 2 832 | Modest Simple Machines Forum workload | active editors/users, realtime updates, imports, search and attached files |
This is an editorial host choice, not an official app minimum or a guaranteed user/device capacity. | Get Now |
| ZimaBoard 2 1664 | More processing or shared-service headroom | Use the supported upstream runtime and complete service topology for the selected release. |
Size the combined stack and active working set; more RAM does not fix remote API limits or missing dependencies. | Get Now |
“ZimaCube 2: Not just another NAS, tested with 25TB storage, local AI agents, 4K transcoding, and real homelab workflows.”Read full review
“The ZimaBoard 2 is a compact x86 server board that can be turned into a mini NAS, home server, media box, or self-hosting hub.”Read full review
“ZimaCube 2: A modern, high-performance NAS with plenty of room to grow—built for users who want more than basic storage.”Read full review
“Coverage focused on ZimaCube 2's open hardware foundation, no monthly fee, and self-hosting flexibility.”Read full review
Answers to Simple Machines Forum RAM, CPU, storage, Docker, database and ZimaOS sizing questions.
How much RAM should I plan for Simple Machines Forum?
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below. Include ZimaOS, the application and its companion services rather than reserving the entire machine for one container.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity. The workload to test is: active editors/users, realtime updates, imports, search and attached files
Persist projects, user records, messages/documents, uploaded assets and background-job state. Preserve a consistent database/file set and verify that your recovery procedure restores a working application.
Can I deploy it on ZimaOS?
Budget supported PHP/database, posts, search/indexing, plugins, attachments and background mail together. Account count alone does not predict active forum memory or throughput. Measure the same representative operation before and after a configuration or hardware change.
What sources informed this Simple Machines Forum hardware guide?
This guide was reviewed against the linked project deployment documentation on November 2, 2026. Zima device choices are editorial workload guidance, separate from upstream requirements and measured performance.
