Hardwareanforderungen für Project Quay: RAM, CPU, Speicherplatz, Uploads und persistente Daten
Plane Projekt Quay mit bedarfsgerechter ZimaOS-Dimensionierung, Backups und praktischer Hardwareauswahl für RAM, CPU, persistenten Speicher und Dienstabhängigkeiten.
Project Quay hardware requirements at a glance
Quay is a container registry project. The linked upstream repository defines its supported deployment. For a container registry or artifact distribution service, size metadata, image layers, caches, scanning workers and the selected object/filesystem backend separately. Replication and cache copies do not replace independent recovery copies.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity.
Persist user files, application metadata, upload staging, previews where generated and independent backups.
Required services
Use the supported upstream runtime and complete service topology for the selected release. The repository references PostgreSQL, Redis / Valkey. These may be optional integrations or alternatives; install only services required by your chosen deployment.
Main sizing variable
parallel transfers, file size, metadata operations, previews and configured storage-backend latency
Practical Zima starting point
Plan the complete Project Quay workload before selecting a server.
    Choose the exact edition, stable release and supported container/runtime. Use the supported upstream runtime and complete service topology for the selected release. The repository references PostgreSQL, Redis / Valkey. These may be optional integrations or alternatives; install only services required by your chosen deployment.
    Test a representative busy operation: parallel transfers, file size, metadata operations, previews and configured storage-backend latency Record peak resident memory, CPU, disk latency and completion time, including other containers.
    Place active state on reliable persistent storage. Persist user files, application metadata, upload staging, previews where generated and independent backups. Budget working space for an upgrade or import and test recovery before relying on the deployment.
    Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment. For a container registry or artifact distribution service, size metadata, image layers, caches, scanning workers and the selected object/filesystem backend separately. Replication and cache copies do not replace independent recovery copies.
  • Supported upstream runtime and architecture
  • Realistic peak activity
Reviewed November 4, 2026 against the linked upstream deployment documentation. Numerical values retain their stated minimum, recommendation or example scope; select release-compatible instructions before installation.
Review Project Quay official requirements
For a container registry or artifact distribution service, size metadata, image layers, caches, scanning workers and the selected object/filesystem backend separately. Replication and cache copies do not replace independent recovery copies. Numerical examples above retain their stated deployment scope; co-hosted services and independent backups need additional capacity.
RAM guidanceNo fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below.Official guidance keeps its original test, recommendation or example scope.
CPU guidanceNo fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity.Core counts do not predict a fixed user, device or document capacity.
Storage planningPersist user files, application metadata, upload staging, previews where generated and independent backups.Installation space is separate from retained content, working files and backups.
Service topologyUse the supported upstream runtime and complete service topology for the selected release. The repository references PostgreSQL, Redis / Valkey. These may be optional integrations or alternatives; install only services required by your chosen deployment.Include every stateful companion service in the host budget.
Persistent statePersist user files, application metadata, upload staging, previews where generated and independent backups.An image rebuild or container replacement is not a backup.
Deployment boundaryFor a container registry or artifact distribution service, size metadata, image layers, caches, scanning workers and the selected object/filesystem backend separately. Replication and cache copies do not replace independent recovery copies.Check the linked project instructions for the selected edition and release.
Use observed Project Quay workload pressure to decide when an upgrade is warranted.
parallel transfers, file size, metadata operations, previews and configured storage-backend latency Time the job and identify CPU, storage or external-service waits before replacing hardware.
Persist user files, application metadata, upload staging, previews where generated and independent backups. Track primary state and backup retention separately.
Use suitable active storage
Fix the observed bottleneck
Verify the supported upstream deployment
For a container registry or artifact distribution service, size metadata, image layers, caches, scanning workers and the selected object/filesystem backend separately. Replication and cache copies do not replace independent recovery copies. Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment.
Review upstream deployment guidance ↗
Review Project Quay deployment details ↗
Which Zima hardware fits Project Quay?
Which workload best matches your Project Quay deployment?
Modest Project Quay deployment
ZimaBoard 2 832 Modest Project Quay workload parallel transfers, file size, metadata operations, previews and configured storage-backend latency
ZimaBoard 2 1664 More processing or shared-service headroom Use the supported upstream runtime and complete service topology for the selected release. The repository references PostgreSQL, Redis / Valkey. These may be optional integrations or alternatives; install only services required by your chosen deployment.
Answers to Project Quay RAM, CPU, storage, Docker, database and ZimaOS sizing questions.
How much RAM should I plan for Project Quay?
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below. Include ZimaOS, the application and its companion services rather than reserving the entire machine for one container.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity. The workload to test is: parallel transfers, file size, metadata operations, previews and configured storage-backend latency
Persist user files, application metadata, upload staging, previews where generated and independent backups. Preserve a consistent database/file set and verify that your recovery procedure restores a working application.
Can I deploy it on ZimaOS?
For a container registry or artifact distribution service, size metadata, image layers, caches, scanning workers and the selected object/filesystem backend separately. Replication and cache copies do not replace independent recovery copies. Measure the same representative operation before and after a configuration or hardware change.
What sources informed this Project Quay hardware guide?
This guide was reviewed against the linked project deployment documentation on November 4, 2026. Zima device choices are editorial workload guidance, separate from upstream requirements and measured performance.
  1. Project Quay official setup / requirements
  2. Project Quay configuration / deployment
  3. Project Quay official repository and releases
  4. ZimaBoard 2 specifications
  5. Project Quay image source: public project material
