Hardwareanforderungen für Project Calico: RAM, CPU, Speicher, Clusternetzwerk und Datenverkehr
Planen Sie RAM, CPU, persistenten Speicher und Service-Abhängigkeiten für Project Calico mit einer workloadbasierten ZimaOS-Dimensionierung, Backups und praktischer Hardwareauswahl.
Project Calico hardware requirements at a glance
Project Calico provides cloud native network functionality. Use its upstream deployment instructions to identify the supported runtime and service topology. This is host or cluster networking infrastructure. Validate supported CNI/OVS/eBPF or routing mode, kernel modules, network interfaces and privileges for the chosen project; include the cluster and workload network budget.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity.
Persist network policies, certificates, controller configuration and recoverable cluster configuration.
Required services
Follow the supported upstream runtime and complete Project Calico deployment topology for the selected release. This is host or cluster networking infrastructure. Validate supported CNI/OVS/eBPF or routing mode, kernel modules, network interfaces and privileges for the chosen project; include the cluster and workload network budget.
Main sizing variable
connections, packet/request rate, policy count, encryption and control-plane churn
Practical Zima starting point
Conditional lab, data-storage or supporting-service hardware only; a complete production deployment requires a separately verified host meeting the upstream requirements. This is host or cluster networking infrastructure. Validate supported CNI/OVS/eBPF or routing mode, kernel modules, network interfaces and privileges for the chosen project; include the cluster and workload network budget.
Plan the complete Project Calico workload before selecting a server.
    Choose the exact edition, stable release and supported container/runtime. Follow the supported upstream runtime and complete Project Calico deployment topology for the selected release. This is host or cluster networking infrastructure. Validate supported CNI/OVS/eBPF or routing mode, kernel modules, network interfaces and privileges for the chosen project; include the cluster and workload network budget.
    Test a representative busy operation: connections, packet/request rate, policy count, encryption and control-plane churn Record peak resident memory, CPU, disk latency and completion time, including other containers.
    Place active state on reliable persistent storage. Persist network policies, certificates, controller configuration and recoverable cluster configuration. Budget working space for an upgrade or import and test recovery before relying on the deployment.
    Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment. This is host or cluster networking infrastructure. Validate supported CNI/OVS/eBPF or routing mode, kernel modules, network interfaces and privileges for the chosen project; include the cluster and workload network budget.
  • Supported upstream runtime and architecture
  • Realistic peak activity
Reviewed November 11, 2026 against the linked upstream deployment documentation. Numerical values retain their stated minimum, recommendation or example scope; select release-compatible instructions before installation.
Review Project Calico official requirements
This is host or cluster networking infrastructure. Validate supported CNI/OVS/eBPF or routing mode, kernel modules, network interfaces and privileges for the chosen project; include the cluster and workload network budget. Numerical examples above retain their stated deployment scope; co-hosted services and independent backups need additional capacity.
RAM guidanceNo fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below.Official guidance keeps its original test, recommendation or example scope.
CPU guidanceNo fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity.Core counts do not predict a fixed user, device or document capacity.
Storage planningPersist network policies, certificates, controller configuration and recoverable cluster configuration.Installation space is separate from retained content, working files and backups.
Service topologyFollow the supported upstream runtime and complete Project Calico deployment topology for the selected release. This is host or cluster networking infrastructure. Validate supported CNI/OVS/eBPF or routing mode, kernel modules, network interfaces and privileges for the chosen project; include the cluster and workload network budget.Include every stateful companion service in the host budget.
Persistent statePersist network policies, certificates, controller configuration and recoverable cluster configuration.An image rebuild or container replacement is not a backup.
Deployment boundaryThis is host or cluster networking infrastructure. Validate supported CNI/OVS/eBPF or routing mode, kernel modules, network interfaces and privileges for the chosen project; include the cluster and workload network budget.Check the linked project instructions for the selected edition and release.
Use observed Project Calico workload pressure to decide when an upgrade is warranted.
connections, packet/request rate, policy count, encryption and control-plane churn Time the job and identify CPU, storage or external-service waits before replacing hardware.
Persist network policies, certificates, controller configuration and recoverable cluster configuration. Track primary state and backup retention separately.
Use suitable active storage
Fix the observed bottleneck
Verify the supported upstream deployment
This is host or cluster networking infrastructure. Validate supported CNI/OVS/eBPF or routing mode, kernel modules, network interfaces and privileges for the chosen project; include the cluster and workload network budget. Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment.
Review upstream deployment guidance ↗
Review Project Calico deployment details ↗
Which Zima hardware fits Project Calico?
Which workload best matches your Project Calico deployment?
Conditional lab or supporting storage use only
  • Supporting hardware onlyZimaBoard 2 832
ZimaBoard 2 832 Conditional lab or supporting-service role connections, packet/request rate, policy count, encryption and control-plane churn
Conditional lab, data-storage or supporting-service hardware only; a complete production deployment requires a separately verified host meeting the upstream requirements. This is host or cluster networking infrastructure. Validate supported CNI/OVS/eBPF or routing mode, kernel modules, network interfaces and privileges for the chosen project; include the cluster and workload network budget. Get Now
ZimaBoard 2 1664 Conditional lab or supporting-service role Follow the supported upstream runtime and complete Project Calico deployment topology for the selected release. This is host or cluster networking infrastructure. Validate supported CNI/OVS/eBPF or routing mode, kernel modules, network interfaces and privileges for the chosen project; include the cluster and workload network budget.
Answers to Project Calico RAM, CPU, storage, Docker, database and ZimaOS sizing questions.
How much RAM should I plan for Project Calico?
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below. Include ZimaOS, the application and its companion services rather than reserving the entire machine for one container.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity. The workload to test is: connections, packet/request rate, policy count, encryption and control-plane churn
Persist network policies, certificates, controller configuration and recoverable cluster configuration. Preserve a consistent database/file set and verify that your recovery procedure restores a working application.
Can I deploy it on ZimaOS?
This is host or cluster networking infrastructure. Validate supported CNI/OVS/eBPF or routing mode, kernel modules, network interfaces and privileges for the chosen project; include the cluster and workload network budget. Measure the same representative operation before and after a configuration or hardware change.
What sources informed this Project Calico hardware guide?
This guide was reviewed against the linked project deployment documentation on November 11, 2026. Zima device choices are editorial workload guidance, separate from upstream requirements and measured performance.
  1. Project Calico official setup / requirements
  2. Project Calico configuration / deployment
  3. Project Calico official repository and releases
  4. ZimaBoard 2 specifications
  5. Project Calico image source: public project material
