PrintStash-Hardwareanforderungen: RAM, CPU, Speicherplatz & Uploads & dauerhafte Daten
Planen Sie RAM, CPU, persistenten Speicher und Dienstabhängigkeiten von PrintStash mit einer workloadbasierten ZimaOS-Dimensionierung, Backups und praktischen Hardware-Empfehlungen.
PrintStash hardware requirements at a glance
3D-print design files, slicer metadata and printer-workflow assets. Content bytes, metadata, transfer staging and previews grow independently. Preserve originals and matching application state together, with upgrade/import workspace and independent recovery copies. Synchronization and replicas do not themselves provide independent backup.
Upstream suggests 1 GB RAM to start, and 2 GB or more for larger meshes. Add host/service headroom.
No fixed numerical whole-host figure is inferred; measure the supported release and complete workload.
Design files, previews, metadata and recovery copies require separate storage.
Required services
Use the documented PrintStash runtime and selected service topology. Content bytes, metadata, transfer staging and previews grow independently. Preserve originals and matching application state together, with upgrade/import workspace and independent recovery copies. Synchronization and replicas do not themselves provide independent backup. Upstream references include PostgreSQL, SQLite. Verify which apply to your selected mode; a mention is not a mandatory dependency.
Main sizing variable
parallel transfers, file size, metadata operations, previews and configured storage-backend latency
Practical Zima starting point
Plan the complete PrintStash workload before selecting a server.
    Choose the exact edition, stable release and supported container/runtime. Use the documented PrintStash runtime and selected service topology. Content bytes, metadata, transfer staging and previews grow independently. Preserve originals and matching application state together, with upgrade/import workspace and independent recovery copies. Synchronization and replicas do not themselves provide independent backup. Upstream references include PostgreSQL, SQLite. Verify which apply to your selected mode; a mention is not a mandatory dependency.
    Test a representative busy operation: parallel transfers, file size, metadata operations, previews and configured storage-backend latency Record peak resident memory, CPU, disk latency and completion time, including other containers.
    Place active state on reliable persistent storage. Persist user files, application metadata, upload staging, previews where generated and independent backups. Budget working space for an upgrade or import and test recovery before relying on the deployment.
    Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment. 3D-print design files, slicer metadata and printer-workflow assets. Content bytes, metadata, transfer staging and previews grow independently. Preserve originals and matching application state together, with upgrade/import workspace and independent recovery copies. Synchronization and replicas do not themselves provide independent backup.
  • Supported upstream runtime and architecture
  • Realistic peak activity
Reviewed November 20, 2026 against the linked upstream deployment documentation. Numerical values retain their stated minimum, recommendation or example scope; select release-compatible instructions before installation.
Review PrintStash official requirements
3D-print design files, slicer metadata and printer-workflow assets. Content bytes, metadata, transfer staging and previews grow independently. Preserve originals and matching application state together, with upgrade/import workspace and independent recovery copies. Synchronization and replicas do not themselves provide independent backup. Numerical examples above retain their stated deployment scope; co-hosted services and independent backups need additional capacity.
RAM guidanceUpstream suggests 1 GB RAM to start, and 2 GB or more for larger meshes. Add host/service headroom.Official guidance keeps its original test, recommendation or example scope.
CPU guidanceNo fixed numerical whole-host figure is inferred; measure the supported release and complete workload.Core counts do not predict a fixed user, device or document capacity.
Storage planningDesign files, previews, metadata and recovery copies require separate storage.Installation space is separate from retained content, working files and backups.
Service topologyUse the documented PrintStash runtime and selected service topology. Content bytes, metadata, transfer staging and previews grow independently. Preserve originals and matching application state together, with upgrade/import workspace and independent recovery copies. Synchronization and replicas do not themselves provide independent backup. Upstream references include PostgreSQL, SQLite. Verify which apply to your selected mode; a mention is not a mandatory dependency.Include every stateful companion service in the host budget.
Persistent statePersist user files, application metadata, upload staging, previews where generated and independent backups.An image rebuild or container replacement is not a backup.
Deployment boundary3D-print design files, slicer metadata and printer-workflow assets. Content bytes, metadata, transfer staging and previews grow independently. Preserve originals and matching application state together, with upgrade/import workspace and independent recovery copies. Synchronization and replicas do not themselves provide independent backup. Check the linked project instructions for the selected edition and release.
Use observed PrintStash workload pressure to decide when an upgrade is warranted.
parallel transfers, file size, metadata operations, previews and configured storage-backend latency Time the job and identify CPU, storage or external-service waits before replacing hardware.
Persist user files, application metadata, upload staging, previews where generated and independent backups. Track primary state and backup retention separately.
Use suitable active storage
Fix the observed bottleneck
Verify the supported upstream deployment
3D-print design files, slicer metadata and printer-workflow assets. Content bytes, metadata, transfer staging and previews grow independently. Preserve originals and matching application state together, with upgrade/import workspace and independent recovery copies. Synchronization and replicas do not themselves provide independent backup. Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment.
Review upstream deployment guidance ↗
Review PrintStash deployment details ↗
Which Zima hardware fits PrintStash?
Which workload best matches your PrintStash deployment?
Modest PrintStash deployment
ZimaBoard 2 832 Modest PrintStash workload parallel transfers, file size, metadata operations, previews and configured storage-backend latency
ZimaBoard 2 1664 More processing or shared-service headroom Use the documented PrintStash runtime and selected service topology. Content bytes, metadata, transfer staging and previews grow independently. Preserve originals and matching application state together, with upgrade/import workspace and independent recovery copies. Synchronization and replicas do not themselves provide independent backup. Upstream references include PostgreSQL, SQLite. Verify which apply to your selected mode; a mention is not a mandatory dependency.
Answers to PrintStash RAM, CPU, storage, Docker, database and ZimaOS sizing questions.
How much RAM should I plan for PrintStash?
Upstream suggests 1 GB RAM to start, and 2 GB or more for larger meshes. Add host/service headroom. Include ZimaOS, the application and its companion services rather than reserving the entire machine for one container.
No fixed numerical whole-host figure is inferred; measure the supported release and complete workload. The workload to test is: parallel transfers, file size, metadata operations, previews and configured storage-backend latency
Persist user files, application metadata, upload staging, previews where generated and independent backups. Preserve a consistent database/file set and verify that your recovery procedure restores a working application.
Can I deploy it on ZimaOS?
3D-print design files, slicer metadata and printer-workflow assets. Content bytes, metadata, transfer staging and previews grow independently. Preserve originals and matching application state together, with upgrade/import workspace and independent recovery copies. Synchronization and replicas do not themselves provide independent backup. Measure the same representative operation before and after a configuration or hardware change.
What sources informed this PrintStash hardware guide?
This guide was reviewed against the linked project deployment documentation on November 20, 2026. Zima device choices are editorial workload guidance, separate from upstream requirements and measured performance.
  1. PrintStash official setup / requirements
  2. PrintStash configuration / deployment
  3. PrintStash official repository and releases
  4. ZimaBoard 2 specifications
  5. PrintStash image source: public project material
