parallel jobs, task duration, browser sessions and separately executed scripts Time the job and identify CPU, storage or external-service waits before replacing hardware.
Imports, processing and simultaneous users.Hardwareanforderungen für open-flow: RAM, CPU, Speicher und Worker sowie gleichzeitige Jobs
Planen Sie RAM, CPU, persistenten Speicher und Service-Abhängigkeiten mit einer workloadbasierten ZimaOS-Dimensionierung, Backups und praktischen Hardware-Empfehlungen.
open-flow hardware requirements at a glance
Run agent-oriented automation workflows; tool execution, concurrent jobs and selected model engines require separate budgets. The controller, retained run state and jobs it starts need separate budgets. Include browser sessions, containers or VMs only when enabled; local inference and external-provider limits are independent. Verify the supported host privileges and topology rather than treating an idle panel as the complete stack.
- RAM
- No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below.
- CPU
- No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity.
- Storage
- Persist workflow definitions, credentials, job metadata, logs and retained input/output artifacts. Keep matching application state and recoverable copies outside the primary failure domain.
- Required services
- Use the supported open-flow runtime and complete upstream deployment topology. The controller, retained run state and jobs it starts need separate budgets. Include browser sessions, containers or VMs only when enabled; local inference and external-provider limits are independent. Verify the supported host privileges and topology rather than treating an idle panel as the complete stack.
- Main sizing variable
- parallel jobs, task duration, browser sessions and separately executed scripts
- Practical Zima starting point
- Conditional lab, data-storage or supporting-service hardware only; a complete production deployment requires a separately verified host meeting the upstream requirements. Run agent-oriented automation workflows; tool execution, concurrent jobs and selected model engines require separate budgets. A scheduler is smaller than the jobs it starts. Include worker processes, browser/model integrations and external API limits; bound concurrency before adding more workers. The controller, retained run state and jobs it starts need separate budgets. Include browser sessions, containers or VMs only when enabled; local inference and external-provider limits are independent. Verify the supported host privileges and topology rather than treating an idle panel as the complete stack.
Plan the complete open-flow workload before selecting a server.
Official requirements
Choose the exact edition, stable release and supported container/runtime. Use the supported open-flow runtime and complete upstream deployment topology. The controller, retained run state and jobs it starts need separate budgets. Include browser sessions, containers or VMs only when enabled; local inference and external-provider limits are independent. Verify the supported host privileges and topology rather than treating an idle panel as the complete stack.
Confirm your needs
Test a representative busy operation: parallel jobs, task duration, browser sessions and separately executed scripts Record peak resident memory, CPU, disk latency and completion time, including other containers.
Leave room to grow
Place active state on reliable persistent storage. Persist workflow definitions, credentials, job metadata, logs and retained input/output artifacts. Keep matching application state and recoverable copies outside the primary failure domain. Budget working space for an upgrade or import and test recovery before relying on the deployment.
Run it on ZimaOS
Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment. Run agent-oriented automation workflows; tool execution, concurrent jobs and selected model engines require separate budgets. A scheduler is smaller than the jobs it starts. Include worker processes, browser/model integrations and external API limits; bound concurrency before adding more workers. The controller, retained run state and jobs it starts need separate budgets. Include browser sessions, containers or VMs only when enabled; local inference and external-provider limits are independent. Verify the supported host privileges and topology rather than treating an idle panel as the complete stack.
- Exact edition and stable release
- Supported upstream runtime and architecture
- All required companion services
- Realistic peak activity
- Persistent data and file ownership
- Free host ports and reachable URLs
- Working space and backup retention
- Successful database/file restore
Reviewed November 24, 2026 against the linked upstream deployment documentation. Numerical values retain their stated minimum, recommendation or example scope; select release-compatible instructions before installation.
Run agent-oriented automation workflows; tool execution, concurrent jobs and selected model engines require separate budgets. A scheduler is smaller than the jobs it starts. Include worker processes, browser/model integrations and external API limits; bound concurrency before adding more workers. The controller, retained run state and jobs it starts need separate budgets. Include browser sessions, containers or VMs only when enabled; local inference and external-provider limits are independent. Verify the supported host privileges and topology rather than treating an idle panel as the complete stack. Numerical examples above retain their stated deployment scope; co-hosted services and independent backups need additional capacity.
| RAM guidance | No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below. | Official guidance keeps its original test, recommendation or example scope. |
| CPU guidance | No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity. | Core counts do not predict a fixed user, device or document capacity. |
| Storage planning | Persist workflow definitions, credentials, job metadata, logs and retained input/output artifacts. Keep matching application state and recoverable copies outside the primary failure domain. | Installation space is separate from retained content, working files and backups. |
| Service topology | Use the supported open-flow runtime and complete upstream deployment topology. The controller, retained run state and jobs it starts need separate budgets. Include browser sessions, containers or VMs only when enabled; local inference and external-provider limits are independent. Verify the supported host privileges and topology rather than treating an idle panel as the complete stack. | Include every stateful companion service in the host budget. |
| Persistent state | Persist workflow definitions, credentials, job metadata, logs and retained input/output artifacts. Keep matching application state and recoverable copies outside the primary failure domain. | An image rebuild or container replacement is not a backup. |
| Deployment boundary | Run agent-oriented automation workflows; tool execution, concurrent jobs and selected model engines require separate budgets. A scheduler is smaller than the jobs it starts. Include worker processes, browser/model integrations and external API limits; bound concurrency before adding more workers. The controller, retained run state and jobs it starts need separate budgets. Include browser sessions, containers or VMs only when enabled; local inference and external-provider limits are independent. Verify the supported host privileges and topology rather than treating an idle panel as the complete stack. | Check the linked project instructions for the selected edition and release. |
Use observed open-flow workload pressure to decide when an upgrade is warranted.
Shared hosts and background work.Persist workflow definitions, credentials, job metadata, logs and retained input/output artifacts. Keep matching application state and recoverable copies outside the primary failure domain. Track primary state and backup retention separately.
Long-lived installations and growing collections.Plan hardware growth with confidence
Use suitable active storage
SATA or PCIe SSD according to measured data growth.Add memory for the complete stack
ZimaBoard 2 832 or ZimaBoard 2 1664 according to the measured constraint.Separate capacity from compute
ZimaCube 2 when a broader multi-drive workload justifies it.Fix the observed bottleneck
Check service configuration, I/O and network behavior before selecting a stronger CPU.Can it run on ZimaOS?
Verify the supported upstream deployment
Run agent-oriented automation workflows; tool execution, concurrent jobs and selected model engines require separate budgets. A scheduler is smaller than the jobs it starts. Include worker processes, browser/model integrations and external API limits; bound concurrency before adding more workers. The controller, retained run state and jobs it starts need separate budgets. Include browser sessions, containers or VMs only when enabled; local inference and external-provider limits are independent. Verify the supported host privileges and topology rather than treating an idle panel as the complete stack. Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment.
Review upstream deployment guidance ↗Use the official open-flow deployment instructions
Keep the selected stable release, persistent paths and companion services aligned with upstream documentation.
Review open-flow official installation ↗Check workload-specific deployment details
Review open-flow deployment details ↗Which Zima hardware fits open-flow?
Which workload best matches your open-flow deployment?
- Supporting hardware onlyZimaBoard 2 832
| ZimaBoard 2 832 | Conditional lab or supporting-service role | parallel jobs, task duration, browser sessions and separately executed scripts |
Conditional lab, data-storage or supporting-service hardware only; a complete production deployment requires a separately verified host meeting the upstream requirements. Run agent-oriented automation workflows; tool execution, concurrent jobs and selected model engines require separate budgets. A scheduler is smaller than the jobs it starts. Include worker processes, browser/model integrations and external API limits; bound concurrency before adding more workers. The controller, retained run state and jobs it starts need separate budgets. Include browser sessions, containers or VMs only when enabled; local inference and external-provider limits are independent. Verify the supported host privileges and topology rather than treating an idle panel as the complete stack. | Get Now |
| ZimaBoard 2 1664 | Conditional lab or supporting-service role | Use the supported open-flow runtime and complete upstream deployment topology. The controller, retained run state and jobs it starts need separate budgets. Include browser sessions, containers or VMs only when enabled; local inference and external-provider limits are independent. Verify the supported host privileges and topology rather than treating an idle panel as the complete stack. |
“ZimaCube 2: Not just another NAS, tested with 25TB storage, local AI agents, 4K transcoding, and real homelab workflows.”Read full review
“The ZimaBoard 2 is a compact x86 server board that can be turned into a mini NAS, home server, media box, or self-hosting hub.”Read full review
“ZimaCube 2: A modern, high-performance NAS with plenty of room to grow—built for users who want more than basic storage.”Read full review
“Coverage focused on ZimaCube 2's open hardware foundation, no monthly fee, and self-hosting flexibility.”Read full review
Answers to open-flow RAM, CPU, storage, Docker, database and ZimaOS sizing questions.
How much RAM should I plan for open-flow?
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below. Include ZimaOS, the application and its companion services rather than reserving the entire machine for one container.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity. The workload to test is: parallel jobs, task duration, browser sessions and separately executed scripts
Persist workflow definitions, credentials, job metadata, logs and retained input/output artifacts. Keep matching application state and recoverable copies outside the primary failure domain. Preserve a consistent database/file set and verify that your recovery procedure restores a working application.
Accelerator needs depend on the selected inference, synthesis, browser or media backend. Run agent-oriented automation workflows; tool execution, concurrent jobs and selected model engines require separate budgets. A scheduler is smaller than the jobs it starts. Include worker processes, browser/model integrations and external API limits; bound concurrency before adding more workers. The controller, retained run state and jobs it starts need separate budgets. Include browser sessions, containers or VMs only when enabled; local inference and external-provider limits are independent. Verify the supported host privileges and topology rather than treating an idle panel as the complete stack.
Can I deploy it on ZimaOS?
Run agent-oriented automation workflows; tool execution, concurrent jobs and selected model engines require separate budgets. A scheduler is smaller than the jobs it starts. Include worker processes, browser/model integrations and external API limits; bound concurrency before adding more workers. The controller, retained run state and jobs it starts need separate budgets. Include browser sessions, containers or VMs only when enabled; local inference and external-provider limits are independent. Verify the supported host privileges and topology rather than treating an idle panel as the complete stack. Measure the same representative operation before and after a configuration or hardware change.
What sources informed this open-flow hardware guide?
This guide was reviewed against the linked project deployment documentation on November 24, 2026. Zima device choices are editorial workload guidance, separate from upstream requirements and measured performance.
