indexed bytes/fields, indexing batches, filters, search concurrency and query complexity Time the job and identify CPU, storage or external-service waits before replacing hardware.
Imports, processing and simultaneous users.noplag-engine Hardwareanforderungen: RAM, CPU, Speicherplatz und Indexgröße und Abfragelast
Plane RAM, CPU, persistenten Speicher und Service-Abhängigkeiten für die noplag-Engine mit einer workloadbasierten ZimaOS-Dimensionierung, Backups und praktischen Hardware-Empfehlungen.
noplag-engine hardware requirements at a glance
Detect matching and near-matching text; corpus size, indexes and concurrent comparison jobs determine host resources. Indexing, source collection, parsing and queries have distinct working sets. Include data, rebuild workspace and concurrency. Browser workers and a separate search backend need their own budgets.
- RAM
- No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below.
- CPU
- No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity.
- Storage
- Persist ingested source documents, indexes, snapshots and indexing configuration. Keep matching application state and recoverable copies outside the primary failure domain.
- Required services
- Use the supported noplag-engine runtime and complete upstream deployment topology. Indexing, source collection, parsing and queries have distinct working sets. Include data, rebuild workspace and concurrency. Browser workers and a separate search backend need their own budgets. The reviewed repository references PostgreSQL; include each only where required by the selected mode, rather than assuming every reference is mandatory.
- Main sizing variable
- indexed bytes/fields, indexing batches, filters, search concurrency and query complexity
- Practical Zima starting point
- ZimaBoard 2 1664 with SSD-backed active state is an editorial starting point for modest use. Include the OS and all companion services; it is not a measured capacity guarantee.
Plan the complete noplag-engine workload before selecting a server.
Official requirements
Choose the exact edition, stable release and supported container/runtime. Use the supported noplag-engine runtime and complete upstream deployment topology. Indexing, source collection, parsing and queries have distinct working sets. Include data, rebuild workspace and concurrency. Browser workers and a separate search backend need their own budgets. The reviewed repository references PostgreSQL; include each only where required by the selected mode, rather than assuming every reference is mandatory.
Confirm your needs
Test a representative busy operation: indexed bytes/fields, indexing batches, filters, search concurrency and query complexity Record peak resident memory, CPU, disk latency and completion time, including other containers.
Leave room to grow
Place active state on reliable persistent storage. Persist ingested source documents, indexes, snapshots and indexing configuration. Keep matching application state and recoverable copies outside the primary failure domain. Budget working space for an upgrade or import and test recovery before relying on the deployment.
Run it on ZimaOS
Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment. Detect matching and near-matching text; corpus size, indexes and concurrent comparison jobs determine host resources. Index memory is not the same as raw document size. Benchmark an actual dataset and leave room for rebuilds; example dataset measurements are not universal RAM multipliers. Indexing, source collection, parsing and queries have distinct working sets. Include data, rebuild workspace and concurrency. Browser workers and a separate search backend need their own budgets.
- Exact edition and stable release
- Supported upstream runtime and architecture
- All required companion services
- Realistic peak activity
- Persistent data and file ownership
- Free host ports and reachable URLs
- Working space and backup retention
- Successful database/file restore
Reviewed November 23, 2026 against the linked upstream deployment documentation. Numerical values retain their stated minimum, recommendation or example scope; select release-compatible instructions before installation.
Detect matching and near-matching text; corpus size, indexes and concurrent comparison jobs determine host resources. Index memory is not the same as raw document size. Benchmark an actual dataset and leave room for rebuilds; example dataset measurements are not universal RAM multipliers. Indexing, source collection, parsing and queries have distinct working sets. Include data, rebuild workspace and concurrency. Browser workers and a separate search backend need their own budgets. Numerical examples above retain their stated deployment scope; co-hosted services and independent backups need additional capacity.
| RAM guidance | No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below. | Official guidance keeps its original test, recommendation or example scope. |
| CPU guidance | No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity. | Core counts do not predict a fixed user, device or document capacity. |
| Storage planning | Persist ingested source documents, indexes, snapshots and indexing configuration. Keep matching application state and recoverable copies outside the primary failure domain. | Installation space is separate from retained content, working files and backups. |
| Service topology | Use the supported noplag-engine runtime and complete upstream deployment topology. Indexing, source collection, parsing and queries have distinct working sets. Include data, rebuild workspace and concurrency. Browser workers and a separate search backend need their own budgets. The reviewed repository references PostgreSQL; include each only where required by the selected mode, rather than assuming every reference is mandatory. | Include every stateful companion service in the host budget. |
| Persistent state | Persist ingested source documents, indexes, snapshots and indexing configuration. Keep matching application state and recoverable copies outside the primary failure domain. | An image rebuild or container replacement is not a backup. |
| Deployment boundary | Detect matching and near-matching text; corpus size, indexes and concurrent comparison jobs determine host resources. Index memory is not the same as raw document size. Benchmark an actual dataset and leave room for rebuilds; example dataset measurements are not universal RAM multipliers. Indexing, source collection, parsing and queries have distinct working sets. Include data, rebuild workspace and concurrency. Browser workers and a separate search backend need their own budgets. | Check the linked project instructions for the selected edition and release. |
Use observed noplag-engine workload pressure to decide when an upgrade is warranted.
Shared hosts and background work.Persist ingested source documents, indexes, snapshots and indexing configuration. Keep matching application state and recoverable copies outside the primary failure domain. Track primary state and backup retention separately.
Long-lived installations and growing collections.Plan hardware growth with confidence
Use suitable active storage
SATA or PCIe SSD according to measured data growth.Add memory for the complete stack
ZimaBoard 2 1664 or ZimaCube 2 Pro according to the measured constraint.Separate capacity from compute
ZimaCube 2 when a broader multi-drive workload justifies it.Fix the observed bottleneck
Check service configuration, I/O and network behavior before selecting a stronger CPU.Can it run on ZimaOS?
Verify the supported upstream deployment
Detect matching and near-matching text; corpus size, indexes and concurrent comparison jobs determine host resources. Index memory is not the same as raw document size. Benchmark an actual dataset and leave room for rebuilds; example dataset measurements are not universal RAM multipliers. Indexing, source collection, parsing and queries have distinct working sets. Include data, rebuild workspace and concurrency. Browser workers and a separate search backend need their own budgets. Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment.
Review upstream deployment guidance ↗Use the official noplag-engine deployment instructions
Keep the selected stable release, persistent paths and companion services aligned with upstream documentation.
Review noplag-engine official installation ↗Check workload-specific deployment details
Review noplag-engine deployment details ↗Which Zima hardware fits noplag-engine?
Which workload best matches your noplag-engine deployment?
- Workload optionZimaBoard 2 1664
- Workload optionZimaCube 2 Pro
| ZimaBoard 2 1664 | Modest noplag-engine workload | indexed bytes/fields, indexing batches, filters, search concurrency and query complexity |
This is an editorial host choice, not an official app minimum or a guaranteed user/device capacity. | Get Now |
| ZimaCube 2 Pro | More processing or shared-service headroom | Use the supported noplag-engine runtime and complete upstream deployment topology. Indexing, source collection, parsing and queries have distinct working sets. Include data, rebuild workspace and concurrency. Browser workers and a separate search backend need their own budgets. The reviewed repository references PostgreSQL; include each only where required by the selected mode, rather than assuming every reference is mandatory. |
Size the combined stack and active working set; more RAM does not fix remote API limits or missing dependencies. | Get Now |
“ZimaCube 2: Not just another NAS, tested with 25TB storage, local AI agents, 4K transcoding, and real homelab workflows.”Read full review
“The ZimaBoard 2 is a compact x86 server board that can be turned into a mini NAS, home server, media box, or self-hosting hub.”Read full review
“ZimaCube 2: A modern, high-performance NAS with plenty of room to grow—built for users who want more than basic storage.”Read full review
“Coverage focused on ZimaCube 2's open hardware foundation, no monthly fee, and self-hosting flexibility.”Read full review
Answers to noplag-engine RAM, CPU, storage, Docker, database and ZimaOS sizing questions.
How much RAM should I plan for noplag-engine?
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below. Include ZimaOS, the application and its companion services rather than reserving the entire machine for one container.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity. The workload to test is: indexed bytes/fields, indexing batches, filters, search concurrency and query complexity
Persist ingested source documents, indexes, snapshots and indexing configuration. Keep matching application state and recoverable copies outside the primary failure domain. Preserve a consistent database/file set and verify that your recovery procedure restores a working application.
Can I deploy it on ZimaOS?
Detect matching and near-matching text; corpus size, indexes and concurrent comparison jobs determine host resources. Index memory is not the same as raw document size. Benchmark an actual dataset and leave room for rebuilds; example dataset measurements are not universal RAM multipliers. Indexing, source collection, parsing and queries have distinct working sets. Include data, rebuild workspace and concurrency. Browser workers and a separate search backend need their own budgets. Measure the same representative operation before and after a configuration or hardware change.
What sources informed this noplag-engine hardware guide?
This guide was reviewed against the linked project deployment documentation on November 23, 2026. Zima device choices are editorial workload guidance, separate from upstream requirements and measured performance.
