event ingestion, data retention, query scans, refresh frequency and dashboard concurrency Time the job and identify CPU, storage or external-service waits before replacing hardware.
Imports, processing and simultaneous users.Hardwareanforderungen für den Next-CWV-Monitor: RAM, CPU, Speicher und Datenerfassung, Abfragen und Aufbewahrung
Planung des nächsten CWV: Überwachen Sie RAM, CPU, persistenten Speicher und Service-Abhängigkeiten mit einer workloadbasierten ZimaOS-Dimensionierung, Backups und praktischen Hardware-Empfehlungen.
Next CWV Monitor hardware requirements at a glance
Collect web performance observations; RUM event volume, retention and reporting queries determine database growth. Ingestion cadence, active queries, data retention and background analysis determine growth. Separate dashboard delivery from analytical storage, collection browsers and model calls; provider limits and example benchmarks do not establish full-host capacity.
- RAM
- No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below.
- CPU
- No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity.
- Storage
- Persist events, metadata, analytical database/indexes, imported data and retained reports. Preserve a matched set and keep independent recovery copies.
- Required services
- Use the supported Next CWV Monitor runtime and full upstream deployment topology. Ingestion cadence, active queries, data retention and background analysis determine growth. Separate dashboard delivery from analytical storage, collection browsers and model calls; provider limits and example benchmarks do not establish full-host capacity. The reviewed repository references ClickHouse; include each only when required by the selected mode, not simply because the name appears in the repository.
- Main sizing variable
- event ingestion, data retention, query scans, refresh frequency and dashboard concurrency
- Practical Zima starting point
- Conditional lab, data-storage or supporting-service hardware only; a complete production deployment requires a separately verified host meeting the upstream requirements. Collect web performance observations; RUM event volume, retention and reporting queries determine database growth. The query/analytical backend can dominate both RAM and storage. Sample or expire unnecessary events and benchmark a real reporting query before increasing resources. Ingestion cadence, active queries, data retention and background analysis determine growth. Separate dashboard delivery from analytical storage, collection browsers and model calls; provider limits and example benchmarks do not establish full-host capacity. The full monitor includes a ClickHouse-backed service and a separate small client SDK. The browser SDK bundle size does not size the database or server.
Plan the complete Next CWV Monitor workload before selecting a server.
Official requirements
Choose the exact edition, stable release and supported container/runtime. Use the supported Next CWV Monitor runtime and full upstream deployment topology. Ingestion cadence, active queries, data retention and background analysis determine growth. Separate dashboard delivery from analytical storage, collection browsers and model calls; provider limits and example benchmarks do not establish full-host capacity. The reviewed repository references ClickHouse; include each only when required by the selected mode, not simply because the name appears in the repository.
Confirm your needs
Test a representative busy operation: event ingestion, data retention, query scans, refresh frequency and dashboard concurrency Record peak resident memory, CPU, disk latency and completion time, including other containers.
Leave room to grow
Place active state on reliable persistent storage. Persist events, metadata, analytical database/indexes, imported data and retained reports. Preserve a matched set and keep independent recovery copies. Budget working space for an upgrade or import and test recovery before relying on the deployment.
Run it on ZimaOS
Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment. Collect web performance observations; RUM event volume, retention and reporting queries determine database growth. The query/analytical backend can dominate both RAM and storage. Sample or expire unnecessary events and benchmark a real reporting query before increasing resources. Ingestion cadence, active queries, data retention and background analysis determine growth. Separate dashboard delivery from analytical storage, collection browsers and model calls; provider limits and example benchmarks do not establish full-host capacity. The full monitor includes a ClickHouse-backed service and a separate small client SDK. The browser SDK bundle size does not size the database or server.
- Exact edition and stable release
- Supported upstream runtime and architecture
- All required companion services
- Realistic peak activity
- Persistent data and file ownership
- Free host ports and reachable URLs
- Working space and backup retention
- Successful database/file restore
Reviewed November 24, 2026 against the linked upstream deployment documentation. Numerical values retain their stated minimum, recommendation or example scope; select release-compatible instructions before installation.
Collect web performance observations; RUM event volume, retention and reporting queries determine database growth. The query/analytical backend can dominate both RAM and storage. Sample or expire unnecessary events and benchmark a real reporting query before increasing resources. Ingestion cadence, active queries, data retention and background analysis determine growth. Separate dashboard delivery from analytical storage, collection browsers and model calls; provider limits and example benchmarks do not establish full-host capacity. The full monitor includes a ClickHouse-backed service and a separate small client SDK. The browser SDK bundle size does not size the database or server. Numerical examples above retain their stated deployment scope; co-hosted services and independent backups need additional capacity.
| RAM guidance | No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below. | Official guidance keeps its original test, recommendation or example scope. |
| CPU guidance | No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity. | Core counts do not predict a fixed user, device or document capacity. |
| Storage planning | Persist events, metadata, analytical database/indexes, imported data and retained reports. Preserve a matched set and keep independent recovery copies. | Installation space is separate from retained content, working files and backups. |
| Service topology | Use the supported Next CWV Monitor runtime and full upstream deployment topology. Ingestion cadence, active queries, data retention and background analysis determine growth. Separate dashboard delivery from analytical storage, collection browsers and model calls; provider limits and example benchmarks do not establish full-host capacity. The reviewed repository references ClickHouse; include each only when required by the selected mode, not simply because the name appears in the repository. | Include every stateful companion service in the host budget. |
| Persistent state | Persist events, metadata, analytical database/indexes, imported data and retained reports. Preserve a matched set and keep independent recovery copies. | An image rebuild or container replacement is not a backup. |
| Deployment boundary | Collect web performance observations; RUM event volume, retention and reporting queries determine database growth. The query/analytical backend can dominate both RAM and storage. Sample or expire unnecessary events and benchmark a real reporting query before increasing resources. Ingestion cadence, active queries, data retention and background analysis determine growth. Separate dashboard delivery from analytical storage, collection browsers and model calls; provider limits and example benchmarks do not establish full-host capacity. The full monitor includes a ClickHouse-backed service and a separate small client SDK. The browser SDK bundle size does not size the database or server. | Check the linked project instructions for the selected edition and release. |
Use observed Next CWV Monitor workload pressure to decide when an upgrade is warranted.
Shared hosts and background work.Persist events, metadata, analytical database/indexes, imported data and retained reports. Preserve a matched set and keep independent recovery copies. Track primary state and backup retention separately.
Long-lived installations and growing collections.Plan hardware growth with confidence
Use suitable active storage
SATA or PCIe SSD according to measured data growth.Add memory for the complete stack
ZimaBoard 2 1664 or ZimaCube 2 Pro according to the measured constraint.Separate capacity from compute
ZimaCube 2 when a broader multi-drive workload justifies it.Fix the observed bottleneck
Check service configuration, I/O and network behavior before selecting a stronger CPU.Can it run on ZimaOS?
Verify the supported upstream deployment
Collect web performance observations; RUM event volume, retention and reporting queries determine database growth. The query/analytical backend can dominate both RAM and storage. Sample or expire unnecessary events and benchmark a real reporting query before increasing resources. Ingestion cadence, active queries, data retention and background analysis determine growth. Separate dashboard delivery from analytical storage, collection browsers and model calls; provider limits and example benchmarks do not establish full-host capacity. The full monitor includes a ClickHouse-backed service and a separate small client SDK. The browser SDK bundle size does not size the database or server. Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment.
Review upstream deployment guidance ↗Use the official Next CWV Monitor deployment instructions
Keep the selected stable release, persistent paths and companion services aligned with upstream documentation.
Review Next CWV Monitor official installation ↗Check workload-specific deployment details
Review Next CWV Monitor deployment details ↗Which Zima hardware fits Next CWV Monitor?
Which workload best matches your Next CWV Monitor deployment?
- Supporting hardware onlyZimaBoard 2 1664
| ZimaBoard 2 1664 | Conditional lab or supporting-service role | event ingestion, data retention, query scans, refresh frequency and dashboard concurrency |
Conditional lab, data-storage or supporting-service hardware only; a complete production deployment requires a separately verified host meeting the upstream requirements. Collect web performance observations; RUM event volume, retention and reporting queries determine database growth. The query/analytical backend can dominate both RAM and storage. Sample or expire unnecessary events and benchmark a real reporting query before increasing resources. Ingestion cadence, active queries, data retention and background analysis determine growth. Separate dashboard delivery from analytical storage, collection browsers and model calls; provider limits and example benchmarks do not establish full-host capacity. The full monitor includes a ClickHouse-backed service and a separate small client SDK. The browser SDK bundle size does not size the database or server. | Get Now |
| ZimaCube 2 Pro | Conditional lab or supporting-service role | Use the supported Next CWV Monitor runtime and full upstream deployment topology. Ingestion cadence, active queries, data retention and background analysis determine growth. Separate dashboard delivery from analytical storage, collection browsers and model calls; provider limits and example benchmarks do not establish full-host capacity. The reviewed repository references ClickHouse; include each only when required by the selected mode, not simply because the name appears in the repository. |
“ZimaCube 2: Not just another NAS, tested with 25TB storage, local AI agents, 4K transcoding, and real homelab workflows.”Read full review
“The ZimaBoard 2 is a compact x86 server board that can be turned into a mini NAS, home server, media box, or self-hosting hub.”Read full review
“ZimaCube 2: A modern, high-performance NAS with plenty of room to grow—built for users who want more than basic storage.”Read full review
“Coverage focused on ZimaCube 2's open hardware foundation, no monthly fee, and self-hosting flexibility.”Read full review
Answers to Next CWV Monitor RAM, CPU, storage, Docker, database and ZimaOS sizing questions.
How much RAM should I plan for Next CWV Monitor?
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below. Include ZimaOS, the application and its companion services rather than reserving the entire machine for one container.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity. The workload to test is: event ingestion, data retention, query scans, refresh frequency and dashboard concurrency
Persist events, metadata, analytical database/indexes, imported data and retained reports. Preserve a matched set and keep independent recovery copies. Preserve a consistent database/file set and verify that your recovery procedure restores a working application.
Can I deploy it on ZimaOS?
Collect web performance observations; RUM event volume, retention and reporting queries determine database growth. The query/analytical backend can dominate both RAM and storage. Sample or expire unnecessary events and benchmark a real reporting query before increasing resources. Ingestion cadence, active queries, data retention and background analysis determine growth. Separate dashboard delivery from analytical storage, collection browsers and model calls; provider limits and example benchmarks do not establish full-host capacity. The full monitor includes a ClickHouse-backed service and a separate small client SDK. The browser SDK bundle size does not size the database or server. Measure the same representative operation before and after a configuration or hardware change.
What sources informed this Next CWV Monitor hardware guide?
This guide was reviewed against the linked project deployment documentation on November 24, 2026. Zima device choices are editorial workload guidance, separate from upstream requirements and measured performance.
