request concurrency, query complexity, plugin work and response size Time the job and identify CPU, storage or external-service waits before replacing hardware.
Imports, processing and simultaneous users.Hardwareanforderungen für die MQTT-Weboberfläche: RAM, CPU, Speicherplatz & Anfragen & verbundene Backends
Planen Sie RAM, CPU, persistenten Speicher und Dienstabhängigkeiten für das MQTT-Webinterface – mit einer workloadbasierten Dimensionierung von ZimaOS, Backups und praktischen Hardware-Empfehlungen.
MQTT Web Interface hardware requirements at a glance
Lightweight web interface for MQTT visualization The browser interface connects to a separately configured MQTT broker. Subscriptions, message rate and browser visualization differ from broker persistence, retained messages and device traffic; budget broker and UI roles independently.
- RAM
- No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below.
- CPU
- No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity.
- Storage
- Persist API/gateway configuration, schemas, credentials, policy and metadata state.
- Required services
- Use the supported upstream runtime and complete MQTT Web Interface topology for the selected release. The browser interface connects to a separately configured MQTT broker. Subscriptions, message rate and browser visualization differ from broker persistence, retained messages and device traffic; budget broker and UI roles independently.
- Main sizing variable
- request concurrency, query complexity, plugin work and response size
- Practical Zima starting point
- ZimaBoard 2 832 with SSD-backed active state is an editorial starting point for modest use. Include the OS and all companion services; it is not a measured capacity guarantee.
Plan the complete MQTT Web Interface workload before selecting a server.
Official requirements
Choose the exact edition, stable release and supported container/runtime. Use the supported upstream runtime and complete MQTT Web Interface topology for the selected release. The browser interface connects to a separately configured MQTT broker. Subscriptions, message rate and browser visualization differ from broker persistence, retained messages and device traffic; budget broker and UI roles independently.
Confirm your needs
Test a representative busy operation: request concurrency, query complexity, plugin work and response size Record peak resident memory, CPU, disk latency and completion time, including other containers.
Leave room to grow
Place active state on reliable persistent storage. Persist API/gateway configuration, schemas, credentials, policy and metadata state. Budget working space for an upgrade or import and test recovery before relying on the deployment.
Run it on ZimaOS
Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment. The browser interface connects to a separately configured MQTT broker. Subscriptions, message rate and browser visualization differ from broker persistence, retained messages and device traffic; budget broker and UI roles independently.
- Exact edition and stable release
- Supported upstream runtime and architecture
- All required companion services
- Realistic peak activity
- Persistent data and file ownership
- Free host ports and reachable URLs
- Working space and backup retention
- Successful database/file restore
Reviewed November 17, 2026 against the linked upstream deployment documentation. Numerical values retain their stated minimum, recommendation or example scope; select release-compatible instructions before installation.
The browser interface connects to a separately configured MQTT broker. Subscriptions, message rate and browser visualization differ from broker persistence, retained messages and device traffic; budget broker and UI roles independently. Numerical examples above retain their stated deployment scope; co-hosted services and independent backups need additional capacity.
| RAM guidance | No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below. | Official guidance keeps its original test, recommendation or example scope. |
| CPU guidance | No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity. | Core counts do not predict a fixed user, device or document capacity. |
| Storage planning | Persist API/gateway configuration, schemas, credentials, policy and metadata state. | Installation space is separate from retained content, working files and backups. |
| Service topology | Use the supported upstream runtime and complete MQTT Web Interface topology for the selected release. The browser interface connects to a separately configured MQTT broker. Subscriptions, message rate and browser visualization differ from broker persistence, retained messages and device traffic; budget broker and UI roles independently. | Include every stateful companion service in the host budget. |
| Persistent state | Persist API/gateway configuration, schemas, credentials, policy and metadata state. | An image rebuild or container replacement is not a backup. |
| Deployment boundary | The browser interface connects to a separately configured MQTT broker. Subscriptions, message rate and browser visualization differ from broker persistence, retained messages and device traffic; budget broker and UI roles independently. | Check the linked project instructions for the selected edition and release. |
Use observed MQTT Web Interface workload pressure to decide when an upgrade is warranted.
Shared hosts and background work.Persist API/gateway configuration, schemas, credentials, policy and metadata state. Track primary state and backup retention separately.
Long-lived installations and growing collections.Plan hardware growth with confidence
Use suitable active storage
SATA or PCIe SSD according to measured data growth.Add memory for the complete stack
ZimaBoard 2 832 or ZimaBoard 2 1664 according to the measured constraint.Separate capacity from compute
ZimaCube 2 when a broader multi-drive workload justifies it.Fix the observed bottleneck
Check service configuration, I/O and network behavior before selecting a stronger CPU.Can it run on ZimaOS?
Verify the supported upstream deployment
The browser interface connects to a separately configured MQTT broker. Subscriptions, message rate and browser visualization differ from broker persistence, retained messages and device traffic; budget broker and UI roles independently. Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment.
Review upstream deployment guidance ↗Use the official MQTT Web Interface deployment instructions
Keep the selected stable release, persistent paths and companion services aligned with upstream documentation.
Review MQTT Web Interface official installation ↗Check workload-specific deployment details
Review MQTT Web Interface deployment details ↗Which Zima hardware fits MQTT Web Interface?
Which workload best matches your MQTT Web Interface deployment?
- Workload optionZimaBoard 2 832
- Workload optionZimaBoard 2 1664
| ZimaBoard 2 832 | Modest MQTT Web Interface workload | request concurrency, query complexity, plugin work and response size |
This is an editorial host choice, not an official app minimum or a guaranteed user/device capacity. | Get Now |
| ZimaBoard 2 1664 | More processing or shared-service headroom | Use the supported upstream runtime and complete MQTT Web Interface topology for the selected release. The browser interface connects to a separately configured MQTT broker. Subscriptions, message rate and browser visualization differ from broker persistence, retained messages and device traffic; budget broker and UI roles independently. |
Size the combined stack and active working set; more RAM does not fix remote API limits or missing dependencies. | Get Now |
“ZimaCube 2: Not just another NAS, tested with 25TB storage, local AI agents, 4K transcoding, and real homelab workflows.”Read full review
“The ZimaBoard 2 is a compact x86 server board that can be turned into a mini NAS, home server, media box, or self-hosting hub.”Read full review
“ZimaCube 2: A modern, high-performance NAS with plenty of room to grow—built for users who want more than basic storage.”Read full review
“Coverage focused on ZimaCube 2's open hardware foundation, no monthly fee, and self-hosting flexibility.”Read full review
Answers to MQTT Web Interface RAM, CPU, storage, Docker, database and ZimaOS sizing questions.
How much RAM should I plan for MQTT Web Interface?
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below. Include ZimaOS, the application and its companion services rather than reserving the entire machine for one container.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity. The workload to test is: request concurrency, query complexity, plugin work and response size
Persist API/gateway configuration, schemas, credentials, policy and metadata state. Preserve a consistent database/file set and verify that your recovery procedure restores a working application.
Can I deploy it on ZimaOS?
The browser interface connects to a separately configured MQTT broker. Subscriptions, message rate and browser visualization differ from broker persistence, retained messages and device traffic; budget broker and UI roles independently. Measure the same representative operation before and after a configuration or hardware change.
What sources informed this MQTT Web Interface hardware guide?
This guide was reviewed against the linked project deployment documentation on November 17, 2026. Zima device choices are editorial workload guidance, separate from upstream requirements and measured performance.
