weight precision, parameter count, context length, KV cache, concurrent sequences and tokens per second Time the job and identify CPU, storage or external-service waits before replacing hardware.
Imports, processing and simultaneous users.Maya-Anforderungen an die Hardware für Inferenz: RAM, CPU, Speicherplatz und Modellgröße & Inferenz
Plane für Maya Inference RAM, CPU, persistenten Speicher und Service-Abhängigkeiten mit einer an der Arbeitslast orientierten Dimensionierung von ZimaOS, Backups und praktischen Hardware-Empfehlungen.
Maya Inference hardware requirements at a glance
Operate a local model inference engine; verify exact model weights, context, accelerators and device layout before selecting compute. Qualify the actual model engine and accelerator first. Add weights, runtime buffers, context state and concurrency; RAM and VRAM are different resources. A compact NAS is only a conditional storage/control role unless the selected inference worker has been separately verified.
- RAM
- No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below.
- CPU
- No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity.
- Storage
- Persist model weights, tokenizer/configuration, downloaded artifacts and any server state. Keep matching application state and recoverable copies outside the primary failure domain.
- Required services
- Use the supported Maya Inference runtime and complete upstream deployment topology. Qualify the actual model engine and accelerator first. Add weights, runtime buffers, context state and concurrency; RAM and VRAM are different resources. A compact NAS is only a conditional storage/control role unless the selected inference worker has been separately verified.
- Main sizing variable
- weight precision, parameter count, context length, KV cache, concurrent sequences and tokens per second
- Practical Zima starting point
- Conditional lab, data-storage or supporting-service hardware only; a complete production deployment requires a separately verified host meeting the upstream requirements. Operate a local model inference engine; verify exact model weights, context, accelerators and device layout before selecting compute. Select a supported CPU/GPU backend first. Add model weights, runtime buffers and KV cache; host RAM and GPU VRAM are different budgets. Zima hardware is not a validated CUDA inference host. Qualify the actual model engine and accelerator first. Add weights, runtime buffers, context state and concurrency; RAM and VRAM are different resources. A compact NAS is only a conditional storage/control role unless the selected inference worker has been separately verified.
Plan the complete Maya Inference workload before selecting a server.
Official requirements
Choose the exact edition, stable release and supported container/runtime. Use the supported Maya Inference runtime and complete upstream deployment topology. Qualify the actual model engine and accelerator first. Add weights, runtime buffers, context state and concurrency; RAM and VRAM are different resources. A compact NAS is only a conditional storage/control role unless the selected inference worker has been separately verified.
Confirm your needs
Test a representative busy operation: weight precision, parameter count, context length, KV cache, concurrent sequences and tokens per second Record peak resident memory, CPU, disk latency and completion time, including other containers.
Leave room to grow
Place active state on reliable persistent storage. Persist model weights, tokenizer/configuration, downloaded artifacts and any server state. Keep matching application state and recoverable copies outside the primary failure domain. Budget working space for an upgrade or import and test recovery before relying on the deployment.
Run it on ZimaOS
Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment. Operate a local model inference engine; verify exact model weights, context, accelerators and device layout before selecting compute. Select a supported CPU/GPU backend first. Add model weights, runtime buffers and KV cache; host RAM and GPU VRAM are different budgets. Zima hardware is not a validated CUDA inference host. Qualify the actual model engine and accelerator first. Add weights, runtime buffers, context state and concurrency; RAM and VRAM are different resources. A compact NAS is only a conditional storage/control role unless the selected inference worker has been separately verified.
- Exact edition and stable release
- Supported upstream runtime and architecture
- All required companion services
- Realistic peak activity
- Persistent data and file ownership
- Free host ports and reachable URLs
- Working space and backup retention
- Successful database/file restore
Reviewed November 24, 2026 against the linked upstream deployment documentation. Numerical values retain their stated minimum, recommendation or example scope; select release-compatible instructions before installation.
Operate a local model inference engine; verify exact model weights, context, accelerators and device layout before selecting compute. Select a supported CPU/GPU backend first. Add model weights, runtime buffers and KV cache; host RAM and GPU VRAM are different budgets. Zima hardware is not a validated CUDA inference host. Qualify the actual model engine and accelerator first. Add weights, runtime buffers, context state and concurrency; RAM and VRAM are different resources. A compact NAS is only a conditional storage/control role unless the selected inference worker has been separately verified. Numerical examples above retain their stated deployment scope; co-hosted services and independent backups need additional capacity.
| RAM guidance | No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below. | Official guidance keeps its original test, recommendation or example scope. |
| CPU guidance | No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity. | Core counts do not predict a fixed user, device or document capacity. |
| Storage planning | Persist model weights, tokenizer/configuration, downloaded artifacts and any server state. Keep matching application state and recoverable copies outside the primary failure domain. | Installation space is separate from retained content, working files and backups. |
| Service topology | Use the supported Maya Inference runtime and complete upstream deployment topology. Qualify the actual model engine and accelerator first. Add weights, runtime buffers, context state and concurrency; RAM and VRAM are different resources. A compact NAS is only a conditional storage/control role unless the selected inference worker has been separately verified. | Include every stateful companion service in the host budget. |
| Persistent state | Persist model weights, tokenizer/configuration, downloaded artifacts and any server state. Keep matching application state and recoverable copies outside the primary failure domain. | An image rebuild or container replacement is not a backup. |
| Deployment boundary | Operate a local model inference engine; verify exact model weights, context, accelerators and device layout before selecting compute. Select a supported CPU/GPU backend first. Add model weights, runtime buffers and KV cache; host RAM and GPU VRAM are different budgets. Zima hardware is not a validated CUDA inference host. Qualify the actual model engine and accelerator first. Add weights, runtime buffers, context state and concurrency; RAM and VRAM are different resources. A compact NAS is only a conditional storage/control role unless the selected inference worker has been separately verified. | Check the linked project instructions for the selected edition and release. |
Use observed Maya Inference workload pressure to decide when an upgrade is warranted.
Shared hosts and background work.Persist model weights, tokenizer/configuration, downloaded artifacts and any server state. Keep matching application state and recoverable copies outside the primary failure domain. Track primary state and backup retention separately.
Long-lived installations and growing collections.Plan hardware growth with confidence
Use suitable active storage
SATA or PCIe SSD according to measured data growth.Add memory for the complete stack
ZimaBoard 2 1664 or ZimaCube 2 Pro according to the measured constraint.Separate capacity from compute
ZimaCube 2 when a broader multi-drive workload justifies it.Fix the observed bottleneck
Check service configuration, I/O and network behavior before selecting a stronger CPU.Can it run on ZimaOS?
Verify the supported upstream deployment
Operate a local model inference engine; verify exact model weights, context, accelerators and device layout before selecting compute. Select a supported CPU/GPU backend first. Add model weights, runtime buffers and KV cache; host RAM and GPU VRAM are different budgets. Zima hardware is not a validated CUDA inference host. Qualify the actual model engine and accelerator first. Add weights, runtime buffers, context state and concurrency; RAM and VRAM are different resources. A compact NAS is only a conditional storage/control role unless the selected inference worker has been separately verified. Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment.
Review upstream deployment guidance ↗Use the official Maya Inference deployment instructions
Keep the selected stable release, persistent paths and companion services aligned with upstream documentation.
Review Maya Inference official installation ↗Check workload-specific deployment details
Review Maya Inference deployment details ↗Which Zima hardware fits Maya Inference?
Which workload best matches your Maya Inference deployment?
- Supporting hardware onlyZimaBoard 2 1664
| ZimaBoard 2 1664 | Conditional lab or supporting-service role | Retained assets, configurations and a verified compatible control layer; heavy inference/generation runs on its own supported worker. |
Conditional lab, data-storage or supporting-service hardware only; a complete production deployment requires a separately verified host meeting the upstream requirements. Operate a local model inference engine; verify exact model weights, context, accelerators and device layout before selecting compute. Select a supported CPU/GPU backend first. Add model weights, runtime buffers and KV cache; host RAM and GPU VRAM are different budgets. Zima hardware is not a validated CUDA inference host. Qualify the actual model engine and accelerator first. Add weights, runtime buffers, context state and concurrency; RAM and VRAM are different resources. A compact NAS is only a conditional storage/control role unless the selected inference worker has been separately verified. | Get Now |
| ZimaCube 2 Pro | Conditional lab or supporting-service role | Retained assets, configurations and a verified compatible control layer; heavy inference/generation runs on its own supported worker. |
“ZimaCube 2: Not just another NAS, tested with 25TB storage, local AI agents, 4K transcoding, and real homelab workflows.”Read full review
“The ZimaBoard 2 is a compact x86 server board that can be turned into a mini NAS, home server, media box, or self-hosting hub.”Read full review
“ZimaCube 2: A modern, high-performance NAS with plenty of room to grow—built for users who want more than basic storage.”Read full review
“Coverage focused on ZimaCube 2's open hardware foundation, no monthly fee, and self-hosting flexibility.”Read full review
Answers to Maya Inference RAM, CPU, storage, Docker, database and ZimaOS sizing questions.
How much RAM should I plan for Maya Inference?
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below. Include ZimaOS, the application and its companion services rather than reserving the entire machine for one container.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity. The workload to test is: weight precision, parameter count, context length, KV cache, concurrent sequences and tokens per second
Persist model weights, tokenizer/configuration, downloaded artifacts and any server state. Keep matching application state and recoverable copies outside the primary failure domain. Preserve a consistent database/file set and verify that your recovery procedure restores a working application.
Can I deploy it on ZimaOS?
Operate a local model inference engine; verify exact model weights, context, accelerators and device layout before selecting compute. Select a supported CPU/GPU backend first. Add model weights, runtime buffers and KV cache; host RAM and GPU VRAM are different budgets. Zima hardware is not a validated CUDA inference host. Qualify the actual model engine and accelerator first. Add weights, runtime buffers, context state and concurrency; RAM and VRAM are different resources. A compact NAS is only a conditional storage/control role unless the selected inference worker has been separately verified. Measure the same representative operation before and after a configuration or hardware change.
What sources informed this Maya Inference hardware guide?
This guide was reviewed against the linked project deployment documentation on November 24, 2026. Zima device choices are editorial workload guidance, separate from upstream requirements and measured performance.
