Hardwareanforderungen der Drive-Suite: RAM, CPU, Speicherplatz & Speicherrollen & wiederherstellbare Daten
Planen Sie RAM, CPU, persistenten Speicher und Dienstabhängigkeiten für die Drive Suite mit einer workload-basierten Dimensionierung von ZimaOS, Backups und praxisnahen Hardwareempfehlungen.
La Suite Drive hardware requirements at a glance
Collaborative file storage with retained documents, identity and release-specific application services. Content bytes and metadata/indexes grow independently. Include concurrent transfers, import staging, retention and recovery space; application-level replication or synchronization is not an independent backup. Retain keys when recovery depends on encryption.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity.
Persist retained files/objects, application metadata/configuration, configured indexes and independent recoverable copies.
Required services
Use the supported upstream La Suite Drive runtime and service topology. Content bytes and metadata/indexes grow independently. Include concurrent transfers, import staging, retention and recovery space; application-level replication or synchronization is not an independent backup. Retain keys when recovery depends on encryption.
Main sizing variable
file/object count and size, concurrent transfers, metadata operations and configured indexing/processing jobs
Practical Zima starting point
Plan the complete La Suite Drive workload before selecting a server.
    Choose the exact edition, stable release and supported container/runtime. Use the supported upstream La Suite Drive runtime and service topology. Content bytes and metadata/indexes grow independently. Include concurrent transfers, import staging, retention and recovery space; application-level replication or synchronization is not an independent backup. Retain keys when recovery depends on encryption.
    Test a representative busy operation: file/object count and size, concurrent transfers, metadata operations and configured indexing/processing jobs Record peak resident memory, CPU, disk latency and completion time, including other containers.
    Place active state on reliable persistent storage. Persist retained files/objects, application metadata/configuration, configured indexes and independent recoverable copies. Budget working space for an upgrade or import and test recovery before relying on the deployment.
    Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment. Collaborative file storage with retained documents, identity and release-specific application services. Content bytes and metadata/indexes grow independently. Include concurrent transfers, import staging, retention and recovery space; application-level replication or synchronization is not an independent backup. Retain keys when recovery depends on encryption.
  • Supported upstream runtime and architecture
  • Realistic peak activity
Reviewed November 18, 2026 against the linked upstream deployment documentation. Numerical values retain their stated minimum, recommendation or example scope; select release-compatible instructions before installation.
Review La Suite Drive official requirements
Collaborative file storage with retained documents, identity and release-specific application services. Content bytes and metadata/indexes grow independently. Include concurrent transfers, import staging, retention and recovery space; application-level replication or synchronization is not an independent backup. Retain keys when recovery depends on encryption. Numerical examples above retain their stated deployment scope; co-hosted services and independent backups need additional capacity.
RAM guidanceNo fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below.Official guidance keeps its original test, recommendation or example scope.
CPU guidanceNo fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity.Core counts do not predict a fixed user, device or document capacity.
Storage planningPersist retained files/objects, application metadata/configuration, configured indexes and independent recoverable copies.Installation space is separate from retained content, working files and backups.
Service topologyUse the supported upstream La Suite Drive runtime and service topology. Content bytes and metadata/indexes grow independently. Include concurrent transfers, import staging, retention and recovery space; application-level replication or synchronization is not an independent backup. Retain keys when recovery depends on encryption.Include every stateful companion service in the host budget.
Persistent statePersist retained files/objects, application metadata/configuration, configured indexes and independent recoverable copies.An image rebuild or container replacement is not a backup.
Deployment boundaryCollaborative file storage with retained documents, identity and release-specific application services. Content bytes and metadata/indexes grow independently. Include concurrent transfers, import staging, retention and recovery space; application-level replication or synchronization is not an independent backup. Retain keys when recovery depends on encryption.Check the linked project instructions for the selected edition and release.
Use observed La Suite Drive workload pressure to decide when an upgrade is warranted.
file/object count and size, concurrent transfers, metadata operations and configured indexing/processing jobs Time the job and identify CPU, storage or external-service waits before replacing hardware.
Persist retained files/objects, application metadata/configuration, configured indexes and independent recoverable copies. Track primary state and backup retention separately.
Use suitable active storage
Fix the observed bottleneck
Verify the supported upstream deployment
Collaborative file storage with retained documents, identity and release-specific application services. Content bytes and metadata/indexes grow independently. Include concurrent transfers, import staging, retention and recovery space; application-level replication or synchronization is not an independent backup. Retain keys when recovery depends on encryption. Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment.
Review upstream deployment guidance ↗
Review La Suite Drive deployment details ↗
Which Zima hardware fits La Suite Drive?
Which workload best matches your La Suite Drive deployment?
Modest La Suite Drive deployment
ZimaBoard 2 832 Modest La Suite Drive workload file/object count and size, concurrent transfers, metadata operations and configured indexing/processing jobs
ZimaBoard 2 1664 More processing or shared-service headroom Use the supported upstream La Suite Drive runtime and service topology. Content bytes and metadata/indexes grow independently. Include concurrent transfers, import staging, retention and recovery space; application-level replication or synchronization is not an independent backup. Retain keys when recovery depends on encryption.
Answers to La Suite Drive RAM, CPU, storage, Docker, database and ZimaOS sizing questions.
How much RAM should I plan for La Suite Drive?
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below. Include ZimaOS, the application and its companion services rather than reserving the entire machine for one container.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity. The workload to test is: file/object count and size, concurrent transfers, metadata operations and configured indexing/processing jobs
Persist retained files/objects, application metadata/configuration, configured indexes and independent recoverable copies. Preserve a consistent database/file set and verify that your recovery procedure restores a working application.
Can I deploy it on ZimaOS?
Collaborative file storage with retained documents, identity and release-specific application services. Content bytes and metadata/indexes grow independently. Include concurrent transfers, import staging, retention and recovery space; application-level replication or synchronization is not an independent backup. Retain keys when recovery depends on encryption. Measure the same representative operation before and after a configuration or hardware change.
What sources informed this La Suite Drive hardware guide?
This guide was reviewed against the linked project deployment documentation on November 18, 2026. Zima device choices are editorial workload guidance, separate from upstream requirements and measured performance.
  1. La Suite Drive official setup / requirements
  2. La Suite Drive configuration / deployment
  3. La Suite Drive official repository and releases
  4. ZimaBoard 2 specifications
  5. La Suite Drive image source: public project material
