document imports, parsing/OCR, embedding batches, retrieval queries and simultaneous model calls Time the job and identify CPU, storage or external-service waits before replacing hardware.
Imports, processing and simultaneous users.Hardwareanforderungen für den Knowledge-Graph-Extractor: RAM, CPU, Speicherplatz und Dokumentenverarbeitung sowie KI-Backends
Plane die RAM-, CPU-, dauerhaften Speicher- und Service-Abhängigkeiten für den Knowledge-Graph-Extractor, einschließlich einer an der Arbeitslast orientierten Dimensionierung von ZimaOS, Backups und praktischen Hardware-Empfehlungen.
Knowledge Graph Extractor hardware requirements at a glance
Document ingestion and graph extraction using a separately provisioned model worker. Ingestion, parsing/OCR, embeddings, retrieval storage and generation have separate working sets. Dataset size, re-indexing and concurrent questions change peaks. A remote provider or independently hosted model is not included in the application-server memory budget.
- RAM
- App and inference worker have independent host-memory budgets; GPU VRAM is not interchangeable with system RAM.
- CPU
- The documented model worker uses an NVIDIA L4 with 24 GB VRAM; qualify that separate backend.
- Storage
- The documented setup downloads roughly 17 GB model artifacts; add documents, extracted state, images and backups.
- Required services
- Use the documented Knowledge Graph Extractor runtime and selected service topology. Ingestion, parsing/OCR, embeddings, retrieval storage and generation have separate working sets. Dataset size, re-indexing and concurrent questions change peaks. A remote provider or independently hosted model is not included in the application-server memory budget.
- Main sizing variable
- document imports, parsing/OCR, embedding batches, retrieval queries and simultaneous model calls
- Practical Zima starting point
- Conditional lab, data-storage or supporting-service hardware only; a complete production deployment requires a separately verified host meeting the upstream requirements. Document ingestion and graph extraction using a separately provisioned model worker. Ingestion, parsing/OCR, embeddings, retrieval storage and generation have separate working sets. Dataset size, re-indexing and concurrent questions change peaks. A remote provider or independently hosted model is not included in the application-server memory budget. The documented model worker uses an NVIDIA L4 with 24 GB VRAM and roughly 17 GB of downloaded model artifacts. A compact NAS may supply verified storage/control services, but is not a certified substitute for that GPU worker.
Plan the complete Knowledge Graph Extractor workload before selecting a server.
Official requirements
Choose the exact edition, stable release and supported container/runtime. Use the documented Knowledge Graph Extractor runtime and selected service topology. Ingestion, parsing/OCR, embeddings, retrieval storage and generation have separate working sets. Dataset size, re-indexing and concurrent questions change peaks. A remote provider or independently hosted model is not included in the application-server memory budget.
Confirm your needs
Test a representative busy operation: document imports, parsing/OCR, embedding batches, retrieval queries and simultaneous model calls Record peak resident memory, CPU, disk latency and completion time, including other containers.
Leave room to grow
Place active state on reliable persistent storage. Persist original documents, parsed content, embeddings/indexes, application database and model configuration. Budget working space for an upgrade or import and test recovery before relying on the deployment.
Run it on ZimaOS
Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment. Document ingestion and graph extraction using a separately provisioned model worker. Ingestion, parsing/OCR, embeddings, retrieval storage and generation have separate working sets. Dataset size, re-indexing and concurrent questions change peaks. A remote provider or independently hosted model is not included in the application-server memory budget. The documented model worker uses an NVIDIA L4 with 24 GB VRAM and roughly 17 GB of downloaded model artifacts. A compact NAS may supply verified storage/control services, but is not a certified substitute for that GPU worker.
- Exact edition and stable release
- Supported upstream runtime and architecture
- All required companion services
- Realistic peak activity
- Persistent data and file ownership
- Free host ports and reachable URLs
- Working space and backup retention
- Successful database/file restore
Reviewed November 20, 2026 against the linked upstream deployment documentation. Numerical values retain their stated minimum, recommendation or example scope; select release-compatible instructions before installation.
Document ingestion and graph extraction using a separately provisioned model worker. Ingestion, parsing/OCR, embeddings, retrieval storage and generation have separate working sets. Dataset size, re-indexing and concurrent questions change peaks. A remote provider or independently hosted model is not included in the application-server memory budget. The documented model worker uses an NVIDIA L4 with 24 GB VRAM and roughly 17 GB of downloaded model artifacts. A compact NAS may supply verified storage/control services, but is not a certified substitute for that GPU worker. Numerical examples above retain their stated deployment scope; co-hosted services and independent backups need additional capacity.
| RAM guidance | App and inference worker have independent host-memory budgets; GPU VRAM is not interchangeable with system RAM. | Official guidance keeps its original test, recommendation or example scope. |
| CPU guidance | The documented model worker uses an NVIDIA L4 with 24 GB VRAM; qualify that separate backend. | Core counts do not predict a fixed user, device or document capacity. |
| Storage planning | The documented setup downloads roughly 17 GB model artifacts; add documents, extracted state, images and backups. | Installation space is separate from retained content, working files and backups. |
| Service topology | Use the documented Knowledge Graph Extractor runtime and selected service topology. Ingestion, parsing/OCR, embeddings, retrieval storage and generation have separate working sets. Dataset size, re-indexing and concurrent questions change peaks. A remote provider or independently hosted model is not included in the application-server memory budget. | Include every stateful companion service in the host budget. |
| Persistent state | Persist original documents, parsed content, embeddings/indexes, application database and model configuration. | An image rebuild or container replacement is not a backup. |
| Deployment boundary | Document ingestion and graph extraction using a separately provisioned model worker. Ingestion, parsing/OCR, embeddings, retrieval storage and generation have separate working sets. Dataset size, re-indexing and concurrent questions change peaks. A remote provider or independently hosted model is not included in the application-server memory budget. The documented model worker uses an NVIDIA L4 with 24 GB VRAM and roughly 17 GB of downloaded model artifacts. A compact NAS may supply verified storage/control services, but is not a certified substitute for that GPU worker. | Check the linked project instructions for the selected edition and release. |
Use observed Knowledge Graph Extractor workload pressure to decide when an upgrade is warranted.
Shared hosts and background work.Persist original documents, parsed content, embeddings/indexes, application database and model configuration. Track primary state and backup retention separately.
Long-lived installations and growing collections.Plan hardware growth with confidence
Use suitable active storage
SATA or PCIe SSD according to measured data growth.Add memory for the complete stack
ZimaBoard 2 1664 or ZimaCube 2 Pro according to the measured constraint.Separate capacity from compute
ZimaCube 2 when a broader multi-drive workload justifies it.Fix the observed bottleneck
Check service configuration, I/O and network behavior before selecting a stronger CPU.Can it run on ZimaOS?
Verify the supported upstream deployment
Document ingestion and graph extraction using a separately provisioned model worker. Ingestion, parsing/OCR, embeddings, retrieval storage and generation have separate working sets. Dataset size, re-indexing and concurrent questions change peaks. A remote provider or independently hosted model is not included in the application-server memory budget. The documented model worker uses an NVIDIA L4 with 24 GB VRAM and roughly 17 GB of downloaded model artifacts. A compact NAS may supply verified storage/control services, but is not a certified substitute for that GPU worker. Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment.
Review upstream deployment guidance ↗Use the official Knowledge Graph Extractor deployment instructions
Keep the selected stable release, persistent paths and companion services aligned with upstream documentation.
Review Knowledge Graph Extractor official installation ↗Check workload-specific deployment details
Review Knowledge Graph Extractor deployment details ↗Which Zima hardware fits Knowledge Graph Extractor?
Which workload best matches your Knowledge Graph Extractor deployment?
- Supporting hardware onlyZimaBoard 2 1664
| ZimaBoard 2 1664 | Conditional lab or supporting-service role | document imports, parsing/OCR, embedding batches, retrieval queries and simultaneous model calls |
Conditional lab, data-storage or supporting-service hardware only; a complete production deployment requires a separately verified host meeting the upstream requirements. Document ingestion and graph extraction using a separately provisioned model worker. Ingestion, parsing/OCR, embeddings, retrieval storage and generation have separate working sets. Dataset size, re-indexing and concurrent questions change peaks. A remote provider or independently hosted model is not included in the application-server memory budget. The documented model worker uses an NVIDIA L4 with 24 GB VRAM and roughly 17 GB of downloaded model artifacts. A compact NAS may supply verified storage/control services, but is not a certified substitute for that GPU worker. | Get Now |
| ZimaCube 2 Pro | Conditional lab or supporting-service role | Use the documented Knowledge Graph Extractor runtime and selected service topology. Ingestion, parsing/OCR, embeddings, retrieval storage and generation have separate working sets. Dataset size, re-indexing and concurrent questions change peaks. A remote provider or independently hosted model is not included in the application-server memory budget. |
“ZimaCube 2: Not just another NAS, tested with 25TB storage, local AI agents, 4K transcoding, and real homelab workflows.”Read full review
“The ZimaBoard 2 is a compact x86 server board that can be turned into a mini NAS, home server, media box, or self-hosting hub.”Read full review
“ZimaCube 2: A modern, high-performance NAS with plenty of room to grow—built for users who want more than basic storage.”Read full review
“Coverage focused on ZimaCube 2's open hardware foundation, no monthly fee, and self-hosting flexibility.”Read full review
Answers to Knowledge Graph Extractor RAM, CPU, storage, Docker, database and ZimaOS sizing questions.
How much RAM should I plan for Knowledge Graph Extractor?
App and inference worker have independent host-memory budgets; GPU VRAM is not interchangeable with system RAM. Include ZimaOS, the application and its companion services rather than reserving the entire machine for one container.
The documented model worker uses an NVIDIA L4 with 24 GB VRAM; qualify that separate backend. The workload to test is: document imports, parsing/OCR, embedding batches, retrieval queries and simultaneous model calls
Persist original documents, parsed content, embeddings/indexes, application database and model configuration. Preserve a consistent database/file set and verify that your recovery procedure restores a working application.
Accelerator needs depend on the selected inference, synthesis, browser or media backend. Document ingestion and graph extraction using a separately provisioned model worker. Ingestion, parsing/OCR, embeddings, retrieval storage and generation have separate working sets. Dataset size, re-indexing and concurrent questions change peaks. A remote provider or independently hosted model is not included in the application-server memory budget. The documented model worker uses an NVIDIA L4 with 24 GB VRAM and roughly 17 GB of downloaded model artifacts. A compact NAS may supply verified storage/control services, but is not a certified substitute for that GPU worker.
Can I deploy it on ZimaOS?
Document ingestion and graph extraction using a separately provisioned model worker. Ingestion, parsing/OCR, embeddings, retrieval storage and generation have separate working sets. Dataset size, re-indexing and concurrent questions change peaks. A remote provider or independently hosted model is not included in the application-server memory budget. The documented model worker uses an NVIDIA L4 with 24 GB VRAM and roughly 17 GB of downloaded model artifacts. A compact NAS may supply verified storage/control services, but is not a certified substitute for that GPU worker. Measure the same representative operation before and after a configuration or hardware change.
What sources informed this Knowledge Graph Extractor hardware guide?
This guide was reviewed against the linked project deployment documentation on November 20, 2026. Zima device choices are editorial workload guidance, separate from upstream requirements and measured performance.
