event ingestion, data retention, query scans, refresh frequency and dashboard concurrency Time the job and identify CPU, storage or external-service waits before replacing hardware.
Imports, processing and simultaneous users.Kimai-Hardwareanforderungen: RAM, CPU, Speicher & Datenerfassung, Abfragen & Aufbewahrung
Plane RAM, CPU, persistenten Speicher und Service-Abhängigkeiten für Kimai anhand der Workload mit passender Dimensionierung für ZimaOS, Backups und praktischen Hardware-Empfehlungen.
Kimai hardware requirements at a glance
Track work time and print out a summary of your activities on demand. Time entries, reporting/export jobs, attachments and plugins determine practical demand. Persist database/configuration and verify supported PHP/runtime requirements for the selected release.
- RAM
- No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below.
- CPU
- No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity.
- Storage
- Persist events, metadata, analytical database/indexes, imported data and retained reports.
- Required services
- Use the supported upstream runtime and complete service topology for the selected release. The repository references MariaDB / MySQL. These may be optional integrations or alternatives; install only services required by your chosen deployment.
- Main sizing variable
- event ingestion, data retention, query scans, refresh frequency and dashboard concurrency
- Practical Zima starting point
- ZimaBoard 2 1664 with SSD-backed active state is an editorial starting point for modest use. Include the OS and all companion services; it is not a measured capacity guarantee.
Plan the complete Kimai workload before selecting a server.
Official requirements
Choose the exact edition, stable release and supported container/runtime. Use the supported upstream runtime and complete service topology for the selected release. The repository references MariaDB / MySQL. These may be optional integrations or alternatives; install only services required by your chosen deployment.
Confirm your needs
Test a representative busy operation: event ingestion, data retention, query scans, refresh frequency and dashboard concurrency Record peak resident memory, CPU, disk latency and completion time, including other containers.
Leave room to grow
Place active state on reliable persistent storage. Persist events, metadata, analytical database/indexes, imported data and retained reports. Budget working space for an upgrade or import and test recovery before relying on the deployment.
Run it on ZimaOS
Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment. Time entries, reporting/export jobs, attachments and plugins determine practical demand. Persist database/configuration and verify supported PHP/runtime requirements for the selected release.
- Exact edition and stable release
- Supported upstream runtime and architecture
- All required companion services
- Realistic peak activity
- Persistent data and file ownership
- Free host ports and reachable URLs
- Working space and backup retention
- Successful database/file restore
Reviewed November 2, 2026 against the linked upstream deployment documentation. Numerical values retain their stated minimum, recommendation or example scope; select release-compatible instructions before installation.
Time entries, reporting/export jobs, attachments and plugins determine practical demand. Persist database/configuration and verify supported PHP/runtime requirements for the selected release. Numerical examples above retain their stated deployment scope; co-hosted services and independent backups need additional capacity.
| RAM guidance | No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below. | Official guidance keeps its original test, recommendation or example scope. |
| CPU guidance | No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity. | Core counts do not predict a fixed user, device or document capacity. |
| Storage planning | Persist events, metadata, analytical database/indexes, imported data and retained reports. | Installation space is separate from retained content, working files and backups. |
| Service topology | Use the supported upstream runtime and complete service topology for the selected release. The repository references MariaDB / MySQL. These may be optional integrations or alternatives; install only services required by your chosen deployment. | Include every stateful companion service in the host budget. |
| Persistent state | Persist events, metadata, analytical database/indexes, imported data and retained reports. | An image rebuild or container replacement is not a backup. |
| Deployment boundary | Time entries, reporting/export jobs, attachments and plugins determine practical demand. Persist database/configuration and verify supported PHP/runtime requirements for the selected release. | Check the linked project instructions for the selected edition and release. |
Use observed Kimai workload pressure to decide when an upgrade is warranted.
Shared hosts and background work.Persist events, metadata, analytical database/indexes, imported data and retained reports. Track primary state and backup retention separately.
Long-lived installations and growing collections.Plan hardware growth with confidence
Use suitable active storage
SATA or PCIe SSD according to measured data growth.Add memory for the complete stack
ZimaBoard 2 1664 or ZimaCube 2 Pro according to the measured constraint.Separate capacity from compute
ZimaCube 2 when a broader multi-drive workload justifies it.Fix the observed bottleneck
Check service configuration, I/O and network behavior before selecting a stronger CPU.Can it run on ZimaOS?
Verify the supported upstream deployment
Time entries, reporting/export jobs, attachments and plugins determine practical demand. Persist database/configuration and verify supported PHP/runtime requirements for the selected release. Follow the supported upstream runtime, operating system and complete service topology for the selected release. On ZimaOS, consider Custom Install only when a maintained compatible amd64 image and every required host capability have been verified. Otherwise use a separately supported Linux environment; this guide does not certify an unverified container deployment.
Review upstream deployment guidance ↗Use the official Kimai deployment instructions
Keep the selected stable release, persistent paths and companion services aligned with upstream documentation.
Review Kimai official installation ↗Check workload-specific deployment details
Review Kimai deployment details ↗Which Zima hardware fits Kimai?
Which workload best matches your Kimai deployment?
- Workload optionZimaBoard 2 1664
- Workload optionZimaCube 2 Pro
| ZimaBoard 2 1664 | Modest Kimai workload | event ingestion, data retention, query scans, refresh frequency and dashboard concurrency |
This is an editorial host choice, not an official app minimum or a guaranteed user/device capacity. | Get Now |
| ZimaCube 2 Pro | More processing or shared-service headroom | Use the supported upstream runtime and complete service topology for the selected release. The repository references MariaDB / MySQL. These may be optional integrations or alternatives; install only services required by your chosen deployment. |
Size the combined stack and active working set; more RAM does not fix remote API limits or missing dependencies. | Get Now |
“ZimaCube 2: Not just another NAS, tested with 25TB storage, local AI agents, 4K transcoding, and real homelab workflows.”Read full review
“The ZimaBoard 2 is a compact x86 server board that can be turned into a mini NAS, home server, media box, or self-hosting hub.”Read full review
“ZimaCube 2: A modern, high-performance NAS with plenty of room to grow—built for users who want more than basic storage.”Read full review
“Coverage focused on ZimaCube 2's open hardware foundation, no monthly fee, and self-hosting flexibility.”Read full review
Answers to Kimai RAM, CPU, storage, Docker, database and ZimaOS sizing questions.
How much RAM should I plan for Kimai?
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Size the full stack during the busy operation described below. Include ZimaOS, the application and its companion services rather than reserving the entire machine for one container.
No fixed numerical whole-host figure is inferred here; follow the selected release and deployment requirements. Measure CPU use during realistic activity. The workload to test is: event ingestion, data retention, query scans, refresh frequency and dashboard concurrency
Persist events, metadata, analytical database/indexes, imported data and retained reports. Preserve a consistent database/file set and verify that your recovery procedure restores a working application.
Can I deploy it on ZimaOS?
Time entries, reporting/export jobs, attachments and plugins determine practical demand. Persist database/configuration and verify supported PHP/runtime requirements for the selected release. Measure the same representative operation before and after a configuration or hardware change.
What sources informed this Kimai hardware guide?
This guide was reviewed against the linked project deployment documentation on November 2, 2026. Zima device choices are editorial workload guidance, separate from upstream requirements and measured performance.
